Grease and Lubes ???
phill.c
PostPosted: 11:07 - 26 Apr 2006    Post subject: Grease and Lubes ??? Reply with quote
Hello,
My bike has been stood since December ive been doing a few jobs cleaning polishing and so on. What I want to know is before I put it back on the road do I need to use any grease or lubes for the the following:
Wheels spindles
Levers
Calipers
Throttle tube - just put a new one on
Cables.
If somebody could tell what I need to use for each one that would be great or if there is anything else I need to do.
Thanks
Phill.c
CBR400RR the funs started - Honda MTX 125 ongoing project when i can be arsed Smile
the grim reaper
PostPosted: 11:52 - 26 Apr 2006    Post subject: Reply with quote
Wheel spindles - high temp grease, NOT copper grease, the copper grease breaks down.
Levers - Same as spindles, if only because it is slightly better than copper grease.
Calipers - brake grease if you're talking about the pistons, high temp again if you're talking about sliding calipers
Throttle tube - ditto, don't use copper grease near electrical bits and pieces.
Cables - If they're teflon lined, you shouldn't need to lube them but, if you decide to anyway, do NOT use WD40, it causes the teflon to swell and makes them worse. 3-in-1 oil is probably best.
Grim
phill.c
PostPosted: 12:08 - 26 Apr 2006    Post subject: Reply with quote
thanks for that mate appreciate it Thumbs Up
PostPosted: 12:44 - 26 Apr 2006    Post subject: Reply with quote
Why's that then?
I deliberately put copper grease on electrical terminals, frame earths and battery posts to stop them corroding, have done for years.
A can of good old fashioned 3 in 1 oil is great for many little bits and pieces that need lubing, such as lever pivots, stand pivots, locks and suchlike.
The last post was made 20 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 41.07 Kb
