do i have a problem with my suzuki gearbox?
3806danny
PostPosted: 23:06 - 29 Apr 2006    Post subject: do i have a problem with my suzuki gearbox? Reply with quote
when its first started and riden the gears change smooth to easy,but then it tends to get a bit stiffer? is there some thing wrong the clutch may be? Laughing
Handsome
PostPosted: 23:20 - 29 Apr 2006    Post subject: Reply with quote
Have you tried changing the Oil.....
And check your Clutch Cable's tight.....
3806danny
PostPosted: 23:21 - 29 Apr 2006    Post subject: Reply with quote
yeah done it about 80 miles ago
Guest
PostPosted: 00:11 - 30 Apr 2006    Post subject: Reply with quote
But not too tight Wink
Suzuki boxes are famous for their reliability. My gearchange gets stiff sometimes and it's down to a build-up of crud where the lever pivots on the footrest and the change shaft comes through the sprocket cover.
Strip, clean and re-grease sorts it.
Bezzer
PostPosted: 00:58 - 30 Apr 2006    Post subject: Reply with quote
Thumbs Up He's right and particularly as yours is a Bandit, they're famous for it, get it cleaned up. If you leave it too long it gets really bad and the nylon/plastic bush in the gear lever can end up damaged when you try to remove the lever, you have to buy a complete gear lever then as they don't sell the bush on it's own Sad
3806danny
PostPosted: 10:27 - 30 Apr 2006    Post subject: Reply with quote
so i need to strip my gear box?
Ichy
PostPosted: 10:37 - 30 Apr 2006    Post subject: Reply with quote
No, just the gear linkage and maybe the clutch link. they are outside of the main gearbox.
3806danny
PostPosted: 10:43 - 30 Apr 2006    Post subject: Reply with quote
i think it is a bit dirty so that makes it stiff?
Bezzer
PostPosted: 16:15 - 30 Apr 2006    Post subject: Reply with quote
It isn't just a plain direct gearlever it's got the linkage as well which amplifies problems, crud builds up at different points, particularly in the lever pivot and it starts to jam just take the lever and linkage off and give it a good clean.
3806danny
PostPosted: 16:46 - 30 Apr 2006    Post subject: Reply with quote
thanks for the help
Guest
PostPosted: 18:07 - 30 Apr 2006    Post subject: Reply with quote
https://alpha-sports.com/spst/1999%20GSF600S/31.gif
where the pedal (34) pivots on the footrest and where shaft (26) comes through the sprocket cover.
You'll need to remove bolt 38 and pull the knuckle off the splines, then take the sprocket cover off and make sure the hole is clean (fine round file) and use fine emery to get any corrosion/muck off the shaft itself.
The last post was made 20 years, 182 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 67.08 Kb
