How not do an oil change...
jok
PostPosted: 18:35 - 30 Apr 2006    Post subject: How not do an oil change... Reply with quote
My CG needed an oil change (it was a little overdue), and I decided to read up on it and do it myself. It seemed easy enough, so off I went:
Place a bowl under the drain plug, unscrew it, pick out the filter, wait for oil to drain... "No problem, this is easy.", me thinks. Reassembled the filter and the spring, put the oil drain plug back on, and screwed it tight (with a torque wrench, no less). At this point I'm not sure if I'd just breathed too much of the oil fumes, but for some reason I was convinced that it was too tight, and proceeded to unscrew it again with another wrench to re-tighten it. Or rather, I thought I was unscrewing it.
No points for guessing what I actually did: screw it in even tighter, to the point where the rim around the plug that holds the rubber seal in place just sheared off. Doh!
Now, I left the drain plug in place (after loosening it slightly (really, this time)) and filled it up with oil again to the correct level. It's not leaking, as far as I can tell, and the o-ring is staying in place. I started her up very briefly and gave her some gentle revs, rechecked the oil level and it still looks OK.
I was tempted to risk riding it to the nearest garage to get a new plug, but in the end I decided to cut my losses and walk there tomorrow (and hope and pray that it's open Confused Praying).
The lesson learned: Counter-clockwise loosens. Always*. Not just the first time you unscrew it Embarassed.
I'll think I'll have a cup of tea now until I've calmed down a bit (and stopped swearing at myself Smile).
* Yes, I know there are some screws that can go the other way, but as a general rule...
CG125 (stolen->recovered!) || Wars do not decide who's right, only who's left.
0ddball
PostPosted: 18:51 - 30 Apr 2006    Post subject: Reply with quote
Put down the tools and step away from the motorcycle. We're ready to listen to your demands [/common sense police] Wink
Whosthedaddy
PostPosted: 19:15 - 30 Apr 2006    Post subject: Reply with quote
Righty tighty, lefty loosey Wink
thx1138
PostPosted: 19:17 - 30 Apr 2006    Post subject: . Reply with quote
I did once overtighten.... Rolling Eyes Evil or Very Mad This was almost 16 years ago...
My friends helped me out. Someone actually bodged a cork washer, and I rode home.
Next day, another mate, re-threaded, BY HAND! with some weird star shaped chisel thing and a hammer. Shocked
Whosthedaddy
PostPosted: 19:20 - 30 Apr 2006    Post subject: Reply with quote
I've overtightened nuts before causing them to snap and break off, I've still not learnt that it does'nt need one more turn Rolling Eyes
jok
PostPosted: 20:20 - 30 Apr 2006    Post subject: Reply with quote
Tight, tigther, snap Wink.
Whosthedaddy
PostPosted: 20:23 - 30 Apr 2006    Post subject: Reply with quote
The world goes extremely quiet and you replay what happened in slow motion whilst holding your head in your hands, then the jumping up and down starts, panic, swearing and shouting Wink
jok
PostPosted: 20:26 - 30 Apr 2006    Post subject: Reply with quote
Were you spying on me? Shifty
TOM M
PostPosted: 23:09 - 30 Apr 2006    Post subject: Reply with quote
Then the swearing begins Thumbs Up
Now owner of a 1200 Bandit
PostPosted: 23:18 - 30 Apr 2006    Post subject: Re: How not do an oil change... Reply with quote
And just to add to the story, I cracked a socket trying to undo a l/h thread bolt.
jok
PostPosted: 15:05 - 01 May 2006    Post subject: Reply with quote
The dealer I was hoping to get a new plug from is shut today, as seems to be ever other place I tried so far (no surprise on May Day, I guess). At this rate I'll be stuck until next weekend, all for lack of a £3 part Sad.
At least this way I'll have a whole week to contemplate the importance of being paying attention...
MRX Steve
PostPosted: 19:56 - 01 May 2006    Post subject: Reply with quote
I did some thing similar before on my quad, ended up destroying the thread on the oil tank. Had to retap it Embarassed
Rieju MRX 50 Castrol Edition
Phil_G
PostPosted: 23:17 - 01 May 2006    Post subject: Reply with quote
I had a sump nut snap off on me once and I ended up using (of all things) a spark plug as a sump plug once - it damn well worked too! Very Happy
Phil
1997 Kawasaki ER 500 A1:- Once again, Its merely crap Smile
veeeffarr
PostPosted: 23:21 - 01 May 2006    Post subject: Reply with quote
CG125 drain plug threads are massive though.
Redd
PostPosted: 23:25 - 01 May 2006    Post subject: Reply with quote
Managed to snap a rocker cover bolt the other week on my XJ600. Did it up carefully with my fingers then just gave it 'a wee nip'. Shouted over to my mate "It's not tightening, it just went loose". I'd snapped the bolt Embarassed
Fortunately we managed to take the cover back off, tap a small slotted screwdriver into the remains of the bolt and turned it back out the thread. Whew. Then Yamaha charged me £14 for a new bolt and another £5 for a rubber washer to go with it Evil or Very Mad We'd managed to get what was left of the bolt to bite on another thread, but it fell out along with the washer one night and covered my boots and trousers in oil Rolling Eyes
Lesson learned: if you don't know what you're doing, either get someone else to do/show you it or buy a torque wrench Thumbs Up
Professional Uberslacker
2006 Kawasaki Z1000 - Black at the front, airbrushed fade to red at the back.
1998 Kawasaki KDX 200 Enduro project bike
The last post was made 20 years, 161 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 91.12 Kb
