Tyre pressure thoughts...
Dark
PostPosted: 16:43 - 08 May 2006    Post subject: Tyre pressure thoughts... Reply with quote
Has anyone else thought about how differing tyre pressures affect your bikes handling?
I've been struggling to find the optimum suspension setup for the past 4 or 5 weeks, its getting closer with each adjustment, but its just occurred to me that i should also be taking in to count my tyre pressures.
My Bikes in order:- Yamaha RXS100 / Suzuki X7 250 / Yamaha RD350LC / Kawasaki
KR1S 250 / Kawasaki ZXR750 H2 / Honda C50 / Kawasaki ZX7R P5 / Kawasaki ZX10R / Suzuki GSXR 400 / Honda CBR1100 Blackbird & Yamaha FZR 600
dainesefreak
PostPosted: 16:46 - 08 May 2006    Post subject: Reply with quote
Yep. Thumbs Up
Funnily enough I got to this point on the Blade last week, even downloaded a suspension setup guide but then messed with the tyre pressure and was happy enough at that. What tyres are you running?
Dark
PostPosted: 16:50 - 08 May 2006    Post subject: Reply with quote
Metzeler Racetec K0's at the moment. If i remember rightly the last pressure check revealed they had 36psi front and rear.
Dark
PostPosted: 16:52 - 08 May 2006    Post subject: Reply with quote
Tyre pressure makes a huge difference, as I found when I let mine get down to 50% of what they should have been. The quality of the handling after I pumped them back up was remarkable.
I'm a bit sceptical about what the owners manual suggest though. Seems quite a bit too hard to me
dainesefreak
PostPosted: 17:01 - 08 May 2006    Post subject: Reply with quote
Can't find the ZX10R listed on their website but I've found the CBR1000RR and would imagine they are similar. Recommended settings are 2.5 bar (36 PSi) and 2.9 bar (42 PSi) which is the same as my Pirelli Diablos. I tend to run a 36 PSi front and a 39/40 PSi rear. Have a play and see what you think.
Dark
PostPosted: 17:06 - 08 May 2006    Post subject: Reply with quote
Uncanny, i've just found that information out too.
There are people on the ZX10R forums that are running pressures in the mid 20 PSI range Shocked
I also used to run my old ZX7R 30 psi front and rear.
So 36psi front and 42psi rear sounds way too hard to me
I'm going to drop my pressures and see what effect it has i reckon.
McGee
O RLY?
PostPosted: 17:08 - 08 May 2006    Post subject: Reply with quote
36 front and back Wink
Its pronounced Jixxer!
dainesefreak
PostPosted: 17:10 - 08 May 2006    Post subject: Reply with quote
I find the Blade a bit rear end slidey if the pressure is too low on the rear, but then I'm only a 10 stoner.
Dark
PostPosted: 17:19 - 08 May 2006    Post subject: Reply with quote
I agree, a low rear tyre tends to make the bike a bit bouncy out of the turns.
I also reckon a front tyre thats too hard tends to feel like the front is pushing and wants to tuck.
akaDAVE
PostPosted: 17:33 - 08 May 2006    Post subject: Reply with quote
I've noticed a big difference when the pressures have dropped over time and I've put them back there's a drastic change.
The shape of the tyre determines how the bike steers so when it's squashing and moving over bumps it's so much different.
GSXR600
mr.z
PostPosted: 17:45 - 08 May 2006    Post subject: Reply with quote
Thats it, when a tyres pressure is low the tyre "moves" more, so while going arround a corner the tyre flexs more than it should be.. and when the tyre is over inflated the road contact area is reduced..
(both can perminently damage the tyre btw)
+Bearing in mind japanese riders are likely to weigh about 8stone..
tricky buisness really.. needs allot of playing about with..
Dark
PostPosted: 17:49 - 08 May 2006    Post subject: Reply with quote
It certainly is, i'm trying to find an article on th net and not having much luck
mr.z
PostPosted: 17:53 - 08 May 2006    Post subject: Reply with quote
tell you what is fun... haveing air in your front forks and rear shock AND tyres to play with Shocked (and knowing no ammout of fiddleing will make it handle propperly Laughing )
Dark
PostPosted: 18:34 - 08 May 2006    Post subject: Reply with quote
Now that doesn't sound like fun Shocked
This weekends chores:-
1. Got some more ideas for suspension settings after many hours of reading over the last rainy weekend
2. Experiment with some lower tyre pressures
3. Adjust out the free play in the throttle
Believe it or not the adjusters are not near the twist grip like on most bikes, one is behind one side of the fairing and the other is under the tank!! what a bloody stupid place to put them! Evil or Very Mad
GearboxGeezer
PostPosted: 18:45 - 08 May 2006    Post subject: Reply with quote
I dont really see the point in testing differnt types out for the road, just make sure there pretty hard. Theres so many differnt surfaces on uk roads youll just be chacing yourself round in circules, Suspension I can see the point of that.
Out of interest, What does harderning the rear shock and softening the rear shock do?
Dark
PostPosted: 18:56 - 08 May 2006    Post subject: Reply with quote
Hmm well in theory, the tyre is actually an integral part of the bikes suspension, due to the flex in it and this flex can be controlled by changing the pressures.
Softening the compression or preload?
Preload is used to set the optimum area of travel for the spring.
Compression is used to control how fast the spring compresses.
GearboxGeezer
PostPosted: 19:00 - 08 May 2006    Post subject: Reply with quote
Youve lost me....
And in karts we only use tyre pressures really to get the tyre to last long enough for the race, but not to long.
For example, We use lower tyre pressures if its a long race, this means the tyres take long to heat up but dont overheat and loose grip as much.
In a short race, We use Higher pressures to get the tyres warmed up quicker, so they are fast from the beggining.
John C
PostPosted: 19:17 - 08 May 2006    Post subject: Reply with quote
Siggi wrote:
I have 42 in the rear, 36 in the front, and the bike handles like a dream. Thumbs Up
I've gone for 37, 42, but then my ace is a little heavier.
After leaving it in town for 5 minutes to go to the bank somebody had let the back tyre pressure town to 20psi. Evil or Very Mad
Not knowing, I set off and after 5 minutes was seriously concered that something had gone wrong.
Checked/refilled them the next day and it was a different bike.
GearboxGeezer
PostPosted: 19:21 - 08 May 2006    Post subject: Reply with quote
I woulda thought some1 would of noticed some dick fucking about and letting tyres down in the middle of a town.... You sure u ant got a slow flatty?
John C
PostPosted: 19:38 - 08 May 2006    Post subject: Reply with quote
Probably ped boi's with helmets that didn't look out of place
No, they knicked my tax disc too. Got new tyres now anyway.
Simple
PostPosted: 19:43 - 08 May 2006    Post subject: Reply with quote
my front is 21psi my rear 26psi, should be 33 and 36 I think ( will check) when I go to get petrol I'll give them some air, havn't noticed decrease in handling as I'm riding it to college rather than out for a sunday spin.
will fill tyres and report back.
Insta - FemFeral
HermanTheShee...
PostPosted: 20:06 - 08 May 2006    Post subject: Reply with quote
What do you guys use to adjust your tyre pressures?
Someone said the pumps in the petrol stations aren't very reliable.
Or are they ok? Thumbs Up
2004 Suzuki GS500F > 2006 Suzuki SV650S
My real name isn't Herman
michael j
PostPosted: 20:08 - 08 May 2006    Post subject: Reply with quote
36 F and 42 R on mine, before I bought a TPG the back went down to 35 and the bike handled like a pig
Ducati 996
mr.z
PostPosted: 20:24 - 08 May 2006    Post subject: Reply with quote
A recent round up in a magazine tested guages from £100 down to £5.. (will try diging it out)
The £5 halfords one was as accurate as the £100 jobbys Thumbs Up
Had a mate try it against their work one (engineering place, very expensive gear and recently caliberated) and said it was spot on to within a tiny fraction of a psi up to 70... Thumbs Up
The petrol station ones are very unreliable/badly caliberated.. that and the fact your warm tyres will be slightly higher pressure hot than cold, so its impossible to get a good reading anyways..
WavyGravy
PostPosted: 20:26 - 08 May 2006    Post subject: Reply with quote
low tyre pressures will reduce your tyres life substantially.
garage tyre inflators are inspected frequently, its a safety thing.
its an accepted practice to let a couple of psi out of your tyres in the autumn as it will give you a larger contact patch on greasy roads (AT SLOWER SPEEDS)
it follows that over inflating your tyres will give you less road resistance and a higher speed - at the expense of grip
1975 CB125s, 1991 GN250, 1990 Ducati Paso 906
"Don't wake him up - He's got insomnia - He's trying to sleep it off"
The last post was made 20 years, 15 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 3.28 - MySQL Queries: 13 - Page Size: 130.09 Kb
