| Dark |
 Dark World Chat Champion
| dainesefreak |
 dainesefreak World Chat Champion
 Posted: 16:46 - 08 May 2006 Post subject: |
Yep.
Funnily enough I got to this point on the Blade last week, even downloaded a suspension setup guide but then messed with the tyre pressure and was happy enough at that. What tyres are you running? |
| Dark |
| Dark |
| dainesefreak |
| Dark |
 Posted: 17:06 - 08 May 2006 Post subject: |
Uncanny, i've just found that information out too.
There are people on the ZX10R forums that are running pressures in the mid 20 PSI range
I also used to run my old ZX7R 30 psi front and rear.
So 36psi front and 42psi rear sounds way too hard to me
I'm going to drop my pressures and see what effect it has i reckon. ____________________ My Bikes in order:- Yamaha RXS100 / Suzuki X7 250 / Yamaha RD350LC / Kawasaki
KR1S 250 / Kawasaki ZXR750 H2 / Honda C50 / Kawasaki ZX7R P5 / Kawasaki ZX10R / Suzuki GSXR 400 / Honda CBR1100 Blackbird & Yamaha FZR 600 |
| McGee |
 McGee O RLY?
| dainesefreak |
| Dark |
| akaDAVE |
 akaDAVE World Chat Champion
| mr.z |
 mr.z World Chat Champion
 Posted: 17:45 - 08 May 2006 Post subject: |
Thats it, when a tyres pressure is low the tyre "moves" more, so while going arround a corner the tyre flexs more than it should be.. and when the tyre is over inflated the road contact area is reduced..
(both can perminently damage the tyre btw)
+Bearing in mind japanese riders are likely to weigh about 8stone..
tricky buisness really.. needs allot of playing about with.. ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| Dark |
| mr.z |
 Posted: 17:53 - 08 May 2006 Post subject: |
tell you what is fun... haveing air in your front forks and rear shock AND tyres to play with (and knowing no ammout of fiddleing will make it handle propperly ) ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| Dark |
 Posted: 18:34 - 08 May 2006 Post subject: |
Now that doesn't sound like fun
This weekends chores:-
1. Got some more ideas for suspension settings after many hours of reading over the last rainy weekend
2. Experiment with some lower tyre pressures
3. Adjust out the free play in the throttle
Believe it or not the adjusters are not near the twist grip like on most bikes, one is behind one side of the fairing and the other is under the tank!! what a bloody stupid place to put them!  ____________________ My Bikes in order:- Yamaha RXS100 / Suzuki X7 250 / Yamaha RD350LC / Kawasaki
| GearboxGeezer |
 GearboxGeezer World Chat Champion
| Dark |
| GearboxGeezer |
 Posted: 19:00 - 08 May 2006 Post subject: |
| Dark wrote: | | GearboxGeezer wrote: | I dont really see the point in testing differnt types out for the road, just make sure there pretty hard. Theres so many differnt surfaces on uk roads youll just be chacing yourself round in circules, Suspension I can see the point of that.
Out of interest, What does harderning the rear shock and softening the rear shock do? |
Hmm well in theory, the tyre is actually an integral part of the bikes suspension, due to the flex in it and this flex can be controlled by changing the pressures.
Softening the compression or preload?
Preload is used to set the optimum area of travel for the spring.
Compression is used to control how fast the spring compresses. |
Youve lost me....
And in karts we only use tyre pressures really to get the tyre to last long enough for the race, but not to long.
For example, We use lower tyre pressures if its a long race, this means the tyres take long to heat up but dont overheat and loose grip as much.
In a short race, We use Higher pressures to get the tyres warmed up quicker, so they are fast from the beggining. |
| John C |
 John C World Chat Champion
| GearboxGeezer |
| John C |
| Simple |
 Simple World Chat Champion
| HermanTheShee... |
 HermanTheShee... World Chat Champion
 Posted: 20:06 - 08 May 2006 Post subject: |
What do you guys use to adjust your tyre pressures?
Someone said the pumps in the petrol stations aren't very reliable.
Or are they ok?  ____________________ 2004 Suzuki GS500F > 2006 Suzuki SV650S
My real name isn't Herman |
| michael j |
 michael j World Chat Champion
| mr.z |
 Posted: 20:24 - 08 May 2006 Post subject: |
A recent round up in a magazine tested guages from £100 down to £5.. (will try diging it out)
The £5 halfords one was as accurate as the £100 jobbys
Had a mate try it against their work one (engineering place, very expensive gear and recently caliberated) and said it was spot on to within a tiny fraction of a psi up to 70...
The petrol station ones are very unreliable/badly caliberated.. that and the fact your warm tyres will be slightly higher pressure hot than cold, so its impossible to get a good reading anyways.. ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| WavyGravy |
 WavyGravy Scooby Slapper
The last post was made 20 years, 15 days ago. Instead of replying here, would creating a new thread be more useful? |
