Advice on Paddock Stands?
Ted
PostPosted: 22:45 - 09 May 2006    Post subject: Advice on Paddock Stands? Reply with quote
Erm... simple one fellas... I need a cheapo rear paddock stand, so...
A) Has anyone on here got one for sale?
B) If not, is this one any good... https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=8061563426
carlnicholson...
PostPosted: 22:48 - 09 May 2006    Post subject: Reply with quote
Rivington Barn Motorcycles in Horwich do one for £20. Where are you in the country?
"THOSE WHO RISK NOTHING, DO NOTHING, ACHIEVE NOTHING, BECOME NOTHING."
Ted
PostPosted: 22:56 - 09 May 2006    Post subject: Reply with quote
Herts & Essex border, just into Essex. Nr. Saffron Walden/Stansted inc. Airport, etc... Middle of no-where really!
Jack_Cheese
PostPosted: 23:00 - 09 May 2006    Post subject: Reply with quote
Get a hooked one, and get bobbins on your bike. Far safer than swingarm cups.
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
Ted
PostPosted: 23:02 - 09 May 2006    Post subject: Reply with quote
I'm glad you said that Jack... I forgot to ask!
carlnicholson...
PostPosted: 23:18 - 09 May 2006    Post subject: Reply with quote
Bobbins are much more secure, but cups have never failed me yet.
Rivington is many, many miles away mate, and their postage would make is dearer then the one you found. The one you found is worth what he's asking, even with the postage. If I had the cash spare, and didn't live round the corner from Rivi Barn motorcycles, I'ld have it myself!
Vin
PostPosted: 00:32 - 10 May 2006    Post subject: Re: Advice on Paddock Stands? Reply with quote
That looks like the stand I got of Ebay. It came with bolts missing! It lifts my TZR250 OK but I wouldn't want anything much heavier on it.
LustyLew
PostPosted: 00:49 - 10 May 2006    Post subject: Reply with quote
There's a few like that lurking on ebay from different sellers. Pretty much all the same. Used it to lift my 600 Bandit and my SV650.
Only bugger I had was I had to remove my can on the bandit before it would lift as the top would catch it. I suspect that fitting a bobbin adaptor would get around this.
Not bad for a little over £20 all in.
syl
PostPosted: 00:53 - 10 May 2006    Post subject: Reply with quote
I've got one of those, and it's fine.
I also got bobbins (R&G) and hooks (with the stand) - it's far easier to put the bike up with the cups by yourself than it is to put it up with the hooks/bobbins, especially on the first half dozen attempts.
Current bike: Kawasaki Z750S
Ted
PostPosted: 11:17 - 11 May 2006    Post subject: Reply with quote
Cheers guys... I'll go for the eBay one... the dude has about 44 to shift so I don't have to hurry!
I only need it for lisfting a 125cc, bit larger than most 125s, but no heavier than a 250cc.
How easy would it be to change the cups for hooks and bobbins... or is that impossible?
Cheers.
John C
PostPosted: 11:25 - 11 May 2006    Post subject: Reply with quote
For my NSR125 I used a trolley jack under the rear shock to raise the back and I made my own paddock stand for the front with some box section mild steel and some haphazard welding. Thumbs Up
Ted
PostPosted: 11:31 - 11 May 2006    Post subject: Reply with quote
Unfortunately I dont have a welder... or I would have done that as well! I never thought about the trolley jack.... might give it a shot...
John C
PostPosted: 11:38 - 11 May 2006    Post subject: Reply with quote
I imagine each bike is a bit different but on the NSR it turned it into a tripod (front wheel, side stand, jack) leaving the back wheel off the ground.
I could get it high enough to remove the back wheel no problem.
Ted
PostPosted: 11:46 - 11 May 2006    Post subject: Reply with quote
Might be worth a go... I need to somehow sort the chain out... Bit on the saggy side! Still not sure how much slack there should be... trouble tryin to get the manual for it...
John C
PostPosted: 12:35 - 11 May 2006    Post subject: Reply with quote
About 25-35mm should be ok.
Allow for the suspension, it will tighten as you sit on it.
It's better to have it too loose than too tight!
code guru
PostPosted: 13:42 - 11 May 2006    Post subject: Reply with quote
i bought this one for my rieju rs1 and my nsr
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=8054599532&rd=1&sspagename=STRK%3AMEWN%3AIT&rd=1
it works well
KevlarPants
PostPosted: 14:43 - 11 May 2006    Post subject: Reply with quote
That looks very similar to the set I just bough of ebay, different vendor though.
Haven't used them as I'm not sure how to assemble the wheels for the rear one.
Embarassed
Ted
PostPosted: 21:32 - 16 May 2006    Post subject: Reply with quote
Is it worth getting a front stand as well?
The last post was made 20 years, 141 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 95.88 Kb
