Castrol Chain Wax...
veeeffarr
PostPosted: 12:38 - 10 May 2006    Post subject: Castrol Chain Wax... Reply with quote
... Has a new formula.
Much less thick, sprays on real nice and doesn't seem to fling much at all.
Highly recommended.
JonB
Afraid of Mileage
PostPosted: 13:20 - 10 May 2006    Post subject: Reply with quote
It made my chain and rear wheel go mouldy. Neutral
craigs23
Mr Muscle
Ditto, has the new formula got rid of the geen road grime mess it turns your chain into after a week of use?
veeeffarr
PostPosted: 13:22 - 10 May 2006    Post subject: Reply with quote
I had that too, and I'm on a full enclosure.
It's not a thick white wax any more, it's quite thin and covers nice.
the grim reaper
PostPosted: 13:27 - 10 May 2006    Post subject: Reply with quote
The problem I found with chain wax is that it collects in your front sprocket cover, collects loads of little stones etc and turns into a really good grinding paste.
I'll stick to chain lube and use it sparingly, ta.
Grim
Sarge-Devil
PostPosted: 16:34 - 10 May 2006    Post subject: Reply with quote
Your suppossed to spray it on a clean chain and let it dry
It was white when applied...but went yellow/green after a short time.
But it wont stop rust build up....you need to clean that off 1st.
2006 Blue Honda Hornet 600
JGY6000
PostPosted: 19:22 - 10 May 2006    Post subject: Reply with quote
used to use it but it made a mess, all yellow and looked shit, fitted a scottoiler to my new chain and it always looks clean and well lubed
Rookie
PostPosted: 19:26 - 10 May 2006    Post subject: Reply with quote
White spirit and a toothbrush followed by Halfords spray-on grease does a great job for me. Aside from having to wipe off the swingarm from the white spirit, it comes up looking great.
trevoriv
PostPosted: 19:27 - 10 May 2006    Post subject: Reply with quote
I use Wurth dry chain lube, its supposed to be decent and ive had no probs so far apart from every time i take the bike to a garage they give it me back with the chain covered in Castrol Chain Wax saying your chain looked a bit dry mate so i lubed it for you Evil or Very Mad
Swines!
kawakid
PostPosted: 00:05 - 11 May 2006    Post subject: Reply with quote
My stuff costs a quid from morrisons. (browny gold can)
Seems fine to me.
And yes its not a WD40 its a chain lubricant, i'm on my 2nd tin now.
I've a twin and a 4.
pj25
PostPosted: 00:40 - 11 May 2006    Post subject: Reply with quote
The best way i find to lube my chain, is to lube it with ordinary gear oil first then spray it with the castrol wax as i find the wax to be a bit dry on it's own.
wasnt me, honest!!!!!
tokarev
PostPosted: 00:44 - 11 May 2006    Post subject: Reply with quote
That's exactly what I do and it seems to work quite well. Thumbs Up
After spraying on the castrol chain wax I rub it into the chain with an old toothbrush to make sure it gets in everywhere....doesn't seem to turn green or yellow that way and the chain also looks nicely lubricated afterwards.
pj25
PostPosted: 00:49 - 11 May 2006    Post subject: Reply with quote
Also a good tool for cleaning your chain is them battery operated fairy power brushe's. iv still got the scar from when i nicked her one out the kitchen had my eye on it for age's. blamin the kids didnt work. Laughing
Gears
PostPosted: 01:17 - 11 May 2006    Post subject: Reply with quote
Holts chain lube, that stuff is amazing, comes out green an thickish then turns into liquidish and gets all over the chain, leave it an hour after spraying it and you have next to nothing flicking off the chain that stuff is a godsend.
Ride Safe
im so laid back im horizontal.
R.I.P lil Rs125
Crashings proof that your trying
veeeffarr
PostPosted: 01:22 - 11 May 2006    Post subject: Reply with quote
Ride Safe
It's horrible shit that, got half a can left.
Seriously, try the new Castrol stuff, its the nuts Thumbs Up
Gears
PostPosted: 01:31 - 11 May 2006    Post subject: Reply with quote
Haven't tryed the new castrol stuff, the old stuff was utter bollocks though, i ended up using it to create campfires with its flammable contents.
Ride Safe
R.I.P lil Rs125
syris
PostPosted: 10:22 - 11 May 2006    Post subject: Reply with quote
I've started using Castrol 'Chain Spray O-R', its not as heavy as their chain wax and doesn't turn that green colour. Sick It's also easier to clean off.
Skunkcap Freddie
PostPosted: 16:49 - 11 May 2006    Post subject: Reply with quote
i certainly wouldn't use the stuff again. doesn't work terribly well. used it all the time and my chain still had rust spots on it. and thats cleanin the chain using a toothbrush and then another tooth brush to apply it. and then spraying it on and workin it in with a toothbrush aswell. highly unimpressed with it .
Northern Irish Biker? www.nibikers.com
Jack_Cheese
PostPosted: 17:10 - 11 May 2006    Post subject: Reply with quote
Putoline hi-tech ceramic wax is the shizzle you need. Very expensive for what it is, but it goes on evenly, and stays put, virtually no fling. It dries into a white paste almost instantly, but its nice and slippery.
That castrol stuff just turns to shit and stains your driveway really really bad.
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
Skunkcap Freddie
PostPosted: 20:02 - 11 May 2006    Post subject: Reply with quote
and goes green in the rain
MattEMulsion
PostPosted: 23:14 - 11 May 2006    Post subject: Reply with quote
I haven't tried the new stuff but the old stuff was crap. I now use Motul Factory Line, which I think is 10 times better than Castrol Chain Wax. It doesn't look a mess on your chain like the Castrol did and it seems to generally do a better job of actually lubricating your chain.
By the way if anyone wants to buy some unused cheap tins of Castrol Chain Wax then I have a small stock that is somewhat surplus to requirements...
Yamaha YZF-R6
The last post was made 20 years, 49 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 7.04 - MySQL Queries: 13 - Page Size: 108.39 Kb
