Use or Abuse? -Gear Change without Clutch...
Do you change gear without the clutch, and is clutchless gear change abuse?
I change gear without using the clutch & it's [b]not[/b] abuse.
53%
 53%  [ 35 ]
I change gear without using the clutch & it [b]is[/b] abuse.
3%
 3%  [ 2 ]
I [b]don't[/b] change gear without using the clutch & it's [b]not[/b] abuse.
21%
 21%  [ 14 ]
I [b]don't[/b] change gear without using the clutch & it [b]is[/b] abuse.
22%
 22%  [ 15 ]
Total Votes : 66
Ted
PostPosted: 22:17 - 13 May 2006    Post subject: Use or Abuse? -Gear Change without Clutch... Reply with quote
A couple of my mates were telling me that they gear change without using the clutch lever, one of them says it helps to know how in case of an emergency where you might need to change gear fast...
The other one just says he always does it moving up the box because it’s easier (lazy git!)
But are the gearboxes designed to do this, or are you just abusing the bike by doing so?
And do you gear change without clutch?
Basically, would you recommend it, or not recommend it?
Ted
PostPosted: 22:21 - 13 May 2006    Post subject: Reply with quote
Erm... guess I can't use BBcode in the poll option then!
phantomtek
Lil Joe Tek
If you do it right, it's not abuse. I would probably do it but my bike doesn't allow me to, so I don't.
If you do it wrong then I can imagine it damaging the gearbox over time.
MRX Steve
I never do it on my bike, have seen some pics from when people havnt used them on sports bikes and the transmission was knackered. I dont use the clutch when changing up on my quad but they are designed so they can be used without the clutch without causing to much damage.
Rieju MRX 50 Castrol Edition
Rob W
PostPosted: 22:27 - 13 May 2006    Post subject: Reply with quote
After my old man's gearbox went on his TL-R it put me off, and he didn't often up-change without the clutch. I've done it a few times, but to be honest it takes a split second with the clutch anyway so I cant really see the point.
Jack_Cheese
PostPosted: 22:30 - 13 May 2006    Post subject: Reply with quote
accidentally did a clutchless downshift, which went smooth as butter to my total absolute shock. Tried a clutchless upshift, but it wouldn't even leave gear, let alone move into the next. I'll avoid it 'till i need it for wheelies i think...
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
John C
PostPosted: 22:32 - 13 May 2006    Post subject: Reply with quote
On the ace I set off, get to about 1/2 a second before I want to change and pre-load the lever. Then as soon as I want to change I back of the throttle and it pops up into the next gear much smoother than using the clutch. I use a bit of clutch between 1st and second to smooth it out as it's quite snappy with 145bhp.
I never did it on my nsr though as I could change gear much smoother and just as fast using the clutch.
All depends on the bike and what your trying to achieve. Thumbs Up
jay12329
Dr. Evil
PostPosted: 22:39 - 13 May 2006    Post subject: Reply with quote
Clutchless going up the box, use the clutch when coming down. I also clutch 1-2nd.
Been dong it for 2 years and 14,000miles on one bike with no problems.
J
Cillit-BANG
PostPosted: 22:47 - 13 May 2006    Post subject: Reply with quote
As Jay; clutch 1-2nd to avoid the jerkyness, but always go up the box without the clutch after that. If done properly it doesn't do any harm at all to the gearbox. It can take a few rides to get the feel for it though.
2nd nature now.
Always clutch down though.
FFIW, there are countless topics on this and worth a search.
PostPosted: 22:48 - 13 May 2006    Post subject: Reply with quote
On my old GPZ500s I used to regularly both up and downshift without the clutch. Including a 2 week period where I had no clutch cable and the revs were not exactly perfect every time (especially when crunching it into first while paddling the bike along).
The engine has now done 60k miles and is in my KLE500. It is starting to show signs of wear on the external gearshift mechanism, doesn't hook-up for the downshifts every time.
Haven't had a look at it yet but I bet it is just the end of one of the forks that turns the selector drum rounding over slightly. Should be able to fix it by filing it square again. Failing that, by replacing the fork itself which I don't anticipate being too expensive.
Clutch is also starting to slip. I'm certain this is due to wear because the plates were getting close to the service limit last time I checked them (with was abot 25k miles ago). I'm replacing the plates and springs while I have the oil drained down.
tony532
PostPosted: 23:16 - 13 May 2006    Post subject: Reply with quote
clutchless upshifts are fine.
you dont want to be changing down the gears without using the clutch though.
Dom_
Points Mean Prizes
PostPosted: 23:32 - 13 May 2006    Post subject: Reply with quote
I go up and down the box without the clutch. Mainly because i'm lazy and it sounds cool when downshifting. Laughing
NSR Mick
PostPosted: 23:42 - 13 May 2006    Post subject: Reply with quote
Not as cool as blipping the throttle. Wink
edd
PostPosted: 01:31 - 14 May 2006    Post subject: Reply with quote
I clutchless upshift all the time, more often than not tbh. I clutchless downshift sometimes and ive never had a gearbox problem on any bike. Most of my mates change clutchless too and also havent had problems. Bikes have dog gearboxes (nearly always) so theres no reason it should be a problem. Rally cars with dog boxes can change gear clutchless. Further to the point, quickshifter systems work on the basis of a clutchless shift, and I'm pretty sure they wouldnt sell if they were in any way abusive to the bike.
As far as technique is concerned if anyone wants to try an upshift, just put some pressure on the gear pedal (it wont move so long as youve got the gas on) then when you want to change, back off the throttle for a fraction of a second. The next gear should just drop in and you can whack the power back on. Clutchless downshifting is harder to get right and if anyone has a better technique please enlighten me. I try to weight the gear pedal down then sharply blip the throttle, thus matching the revs and allowing it to drop in.
Bluespark Automotive - Diesel Tuning for Performance and Economy
NSR Mick
PostPosted: 01:33 - 14 May 2006    Post subject: Reply with quote
Your not matching the revs, your unloading the gearbox. Thumbs Up
Jamie.
PostPosted: 02:09 - 14 May 2006    Post subject: Reply with quote
If the revvs are high enough you dont need the clutch. Simple as
edd
PostPosted: 02:34 - 14 May 2006    Post subject: Reply with quote
Sorry I meant to be more clear. I understand that you are unloading the box when changing up or down but when changing down, so as not to get sharp engine braking I try to match the revs across the change if that makes any sense. Smile
you dont need high revs to change clutchless, you can change without touching the clutch at 6k if you like.
NSR Mick
PostPosted: 02:39 - 14 May 2006    Post subject: Reply with quote
Impossible, as unless you use the clutch your engine speed will not change thus making matching the revs impossible. Thumbs Up
h00dwink
PostPosted: 02:42 - 14 May 2006    Post subject: Reply with quote
don't think this causes a problem. only really do it upshifting. tbh you don't really notice yourself doing it as gear changing becomes 2nd nature after a while.
craigs23
Mr Muscle
PostPosted: 10:08 - 14 May 2006    Post subject: Reply with quote
Clutch it when using less than half throttle, or for downchanges, or for first through to second, clutchless otherwise. Never done any harm, swifter, smoother gear changes too.
WavyGravy
PostPosted: 10:39 - 14 May 2006    Post subject: Reply with quote
Upshifts are fine, i wouldnt do down shifts on a wet surface if the bike was leaning at all
1975 CB125s, 1991 GN250, 1990 Ducati Paso 906
"Don't wake him up - He's got insomnia - He's trying to sleep it off"
Jack_Cheese
PostPosted: 14:24 - 14 May 2006    Post subject: Reply with quote
I wouldn't even change gear whilst leaning and on a wet surface lol.
Jack
PostPosted: 14:47 - 14 May 2006    Post subject: Reply with quote
I don't do clutchless downshifts. That is a recipie for a knackered gearbox.
However, I have performed clutchless upshifts since I had my very first bike back in 1999.
I've never had a gearbox issue, and even on a bike such as the Buell which is reputed to have an awful gearbox, it works well.
As a rule I don't clutchless shift from first to second, but when I'm in the mood to go fast I usually clutchless shift up through the rest of the box especially when on motorway sliproads or something where acceleration is important.
I clutchlessly shift the RGV up through the box all the time and it seems to like it! Smile
Visitor Q
$25 whore
PostPosted: 15:37 - 14 May 2006    Post subject: Reply with quote
Clutchless up, clutch down.
It doesnt harm the gearbox.
Clutchless down WILL fuck it, unless you wait till very very low revs, and even then its not good.
stefano
PostPosted: 17:27 - 14 May 2006    Post subject: Reply with quote
Tried it on the bike a few times, both up and down. Always useful in case you lose the clutch, as I did a few times in a car I used to teach in. The technique I was taught was to have the revs at about 1500 to 1800 rpm and the gears go smoothly in, and he then went on to explain about spindles and other ratchets and I lost interest.
The car was a very worn Audi TT.
The last post was made 20 years, 168 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.73 - MySQL Queries: 15 - Page Size: 133.45 Kb
