Rear sprocket rubber supports
shammon
PostPosted: 10:33 - 14 May 2006    Post subject: Rear sprocket rubber supports Reply with quote
The rear sprocket has some play, its the rubber inserts which i think are the problem as its easy to see the play , going to be renewing the sprockets and chain this week anyway, but would like also to get new rubber inserts, as per usual need some help to locate them for a Yamaha 1989 xj600 pre diversion!... Will try the dealer tomorow, any idea also how much this is likely to cost? Wink
YAMAHA YZF 1000cc THUNDERACE- 'ƃuıןןǝds ʇnoqɐ ʇıɥs ɐ ǝʌıƃ ʇuop ı
WavyGravy
PostPosted: 11:44 - 14 May 2006    Post subject: Reply with quote
Dont know about Yamaha ones, but honda ones are about 3 to 5 quid each, (about £12-15 a set) it might help your search if you call them cush drive rubbers - LM spares do them for all types of japanese bikes, if you have the part number you'll stand more chance than just the model number of your bike as these type of components are often used on a number of models within the range.
Hells bells just saw theyre £40 for a set for an R1
1975 CB125s, 1991 GN250, 1990 Ducati Paso 906
"Don't wake him up - He's got insomnia - He's trying to sleep it off"
Zimbo
PostPosted: 12:06 - 14 May 2006    Post subject: Reply with quote
As above, they're called Cush Drive rubbers, try your local bike shop, they may need to order them but they will be able to get them.
shammon
PostPosted: 12:08 - 14 May 2006    Post subject: Reply with quote
Thumbs Up Thanks
mr jamez
PostPosted: 12:27 - 14 May 2006    Post subject: Reply with quote
Incase you didn't know, the sprocket will have play in it as the rubbers allow it to move, puts less stress through the transmission when you pit the bike in gear. Unless of course there is excessive play blah etc Smile
PostPosted: 13:29 - 14 May 2006    Post subject: Reply with quote
You'll also find that a lot of cush drive rubbers will be back to exactly the same as they were after a couple of hundred miles, leaving you wondering why you forked out for new ones.
It is common practice to pad the existing ones out using slices of inner tube to take up the slack. Works fine, costs nothing but time Thumbs Up. Both my kawasakis have this done
WavyGravy
PostPosted: 14:12 - 14 May 2006    Post subject: Reply with quote
It is common practice to pad the existing ones out using slices of inner tube to take up the slack. Works fine, costs nothing but time . Both my kawasakis have this done
Blimey! great tip! never thought of that!
flat spot
PostPosted: 14:55 - 14 May 2006    Post subject: Reply with quote
Get some new ones. Try Fowlers in Bristol. They are yam dealers.
PsychoHippy
Jammy Git
PostPosted: 16:09 - 14 May 2006    Post subject: Reply with quote
I replaced the cush rubbers on the ZZR a while ago - they cost me about £4 each. The rubber innertube sounds like a good idea though Thumbs Up
Not matter what you decide, make sure you do it sooner rather than later. Leave it too long and you can mess up you bearings (trust me, I've been there).
I spend all my money on bikes and beer, the rest I simply waste!
The last post was made 20 years, 94 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.45 - MySQL Queries: 15 - Page Size: 59.46 Kb
