| zxr-rob |
 zxr-rob Derestricted Danger
| Rookie |
 Rookie World Chat Champion
| syl |
 syl World Chat Champion
 Posted: 18:52 - 14 May 2006 Post subject: |
Hairspray, apparantly. Slippery when wet but helps the new grips stay on when dry.
Same for getting the old ones off - or use an air hose. ____________________ Current bike: Kawasaki Z750S |
| phantomtek |
 phantomtek Lil Joe Tek
| zxr-rob |
| ram_doom |
 ram_doom World Chat Champion
 Posted: 19:03 - 14 May 2006 Post subject: |
Hairspray method worked for me  ____________________ TL1000s, KDX200 |
| KLR600 |
 KLR600 World Chat Champion
 Posted: 19:17 - 14 May 2006 Post subject: |
The best stuff I've discovered that works for this (I work in a mountain bike shop) is the rubber solution in mountain bike puncture repair kits. Put a bit on the bar and a bit in the grip and twist the grip when you put it on so it goes all over the bar and it'll set really well and won't budge in the rain. (You have to be quick and do it before the rubber solution goes off though!)
But saying that, the twisty throttle body thing on a motorbike is plastic so I don't know if it'd be as good but I do know it's the best stuff I've used for mountain bikes.
HTH ____________________ Now: '00 Kawasaki ZRX1100R - Past: '84 Yamaha DT125, '89 Kawasaki KLR600, '97 Yamaha XJ600N
<Take Cool Photos!> |
| stinkwheel |
| proximity |
 proximity Crazy Courier
| stinkwheel |
 Posted: 21:10 - 14 May 2006 Post subject: |
See if you can slide the straw from a WD40 can between the grip and the bar. Then give it a healthy scoosh. If the grip has a solid end, make a hole in it to break the vaccuum. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| proximity |
| tonyyzf |
 tonyyzf Brolly Dolly
| syl |
 Posted: 22:40 - 14 May 2006 Post subject: |
Use an air hose to shove air under pressure between the grip and the bar. It'll act a bit like a hovercraft and slide off easily, so I'm told. ____________________ Current bike: Kawasaki Z750S |
| DukeRed |
 DukeRed World Chat Champion
 Posted: 01:53 - 15 May 2006 Post subject: |
Have you tried turning them on to full power and trying it then?
I've tried to get heated grips off twice and have had no luck without breaking them. If you're fitting other heated grips I would say only glue the one on the throttle tube so you can take the other one off. ____________________ Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com |
| spinglass |
 spinglass Borekit Bruiser
| Simple |
 Simple World Chat Champion
 Posted: 13:24 - 15 May 2006 Post subject: |
My dad just pulls them off and pushes em on,
but thats what you get for being a farmer type - oo ar
beware when pulling the throttle grip off that it may be glued on, and that you may rip the throttle body off if you share heman tpe strength like my dad
washing up liquid... isnt that bad for rubber?  ____________________ Insta - FemFeral |
| syl |
| Simple |
| Cillit-BANG |
 Cillit-BANG World Chat Champion
 Posted: 17:08 - 15 May 2006 Post subject: |
I've always been pro hair-spray but last time I used it, it was crap. It's possibly because it was still quite cold and wouldn't evaporate properly. After 2 days the grip was still spinning on the throttle side. I whipped it off, cleaned it, rubbed some white spirit in it, popped it back on and within 5 mins it had dried out and was stuck solid.
OFF Slip under thin screwdriver blade, then push wd40 tube alongside. Spray and twist. Easy.
ON Clean off any residue from bars, lube grip with a drop or two of white spirit, slide on, wait 5 mins.
The last post was made 20 years, 171 days ago. Instead of replying here, would creating a new thread be more useful? |
