| colin1 |
 colin1 Captain Safety
 Posted: 00:23 - 21 May 2006 Post subject: qustions about race cans with removable baffles |
i am thinking of getting a race can if i see one for a good price on ebay
i already have a standard can, and so was thinking of getting a race can for occasional use when i want to be noisy.
recently one has popped up on ebay with removable baffle
it seems a great idea for me if im not wanting to be noisy all the time
https://i10.ebayimg.com/03/i/07/2c/48/54_1_b.JPG
I guess it should be easy to whip the baffle in and out, but how easy ? will it mean undoing bolts and stuff, or is it just pulling it out of the open end of the exhaust and putting it back in the same way ?
with baffle in, will it be more noisy than a stanard can ?
i know a race can will normally make a bike run leaner, will having the baffle in make it the same fuel air mix as a standard can or somewhere between standard and race ?
any other info appreciated ____________________ colin1 is officially faster than god |
| Chiz |
 Chiz Trackday Trickster
| Noggin |
 Noggin Traffic Copper
| edd |
 edd Nearly there...
 Posted: 01:02 - 21 May 2006 Post subject: |
usually the removable baffle is held in place with a small bolt at the end of the can. Undo the bolt and pull the baffle out, 30 second job.
Also yeah you can get 3 points if the police are being arseholes, I think they need the noise test equipment to convict you but dont quote me on that. ____________________ Bluespark Automotive - Diesel Tuning for Performance and Economy |
| colin1 |
| edd |
 edd Nearly there...
 Posted: 01:44 - 21 May 2006 Post subject: |
a full exhaust system can use pressure waves to enchance gas flow from the exhaust ports, ideally one pulse as the exhaust valve opens to start flow off, and one right as its closing to scavenge the last of the gases. This could make the engine more efficient, however you are just looking at a can, which will offer less restriction, and make your bike slightly leaner. To maintain correct air/fuel you will want to increase fuelling (either by upjetting a carbed bike, or remapping an EFI bike) increasing fuel doesnt really make sense as an economy move to me. TBH i wouldnt worry about it, it will be cool and sound better, need you consider more? ____________________ Bluespark Automotive - Diesel Tuning for Performance and Economy |
| EuropeanNC30R... |
 EuropeanNC30R... Gay Hairdresser
 Posted: 03:50 - 21 May 2006 Post subject: |
I've got a Scorpion removable baffle exhaust, the baffle got removed 10 seconds after fitting, and hasn't been in since. (The e-mark stays on the can so it looks legit).
It's basically a race-can with a crude bolt in baffle. If you don't rejet, a freer flowing race can may make your bike run a touch lean, causing better fuel consumption, though too lean and your engine will definitely suffer. For what its worth, the engine on my VFR has been running with a race can without rejetting for the last 20,000 miles, now on about 50k, and it's still sweet as a nut. Touch wood  |
| craigs23 |
 craigs23 Mr Muscle
| G |
 G The Voice of Reason
| strag |
 strag World Chat Champion
| ram_doom |
 ram_doom World Chat Champion
| Cillit-BANG |
 Cillit-BANG World Chat Champion
| instigator |
 instigator Super Spammer
| G |
 Posted: 12:52 - 21 May 2006 Post subject: |
Marjay's triumph.
The other million probably didn't have it checked on a dyno .
I'm sure most are generally ok, but something to be aware of. |
| Noggin |
| colin1 |
| Philly46 |
 Philly46 Spanner Monkey
| Kickstart |
 Kickstart The Oracle
 Posted: 00:11 - 22 May 2006 Post subject: |
The Bandit with the Akrapovic system with the baffle in is noisier than the stock system, and with the baffle out one hell of a lot noisier.
Putting the baffle in lost the bike 7hp on a dyno run (144 without the baffle that day, 137 with the baffle). However bigger effect is that running with the baffle in is flat spots low down as it was set up for the baffle being out.
On the Akrapovic the baffle is held in place with a single small bolt. Quite a few are held in with a circlip instead.
| impaler |
 impaler Crazy Courier
 Posted: 00:44 - 22 May 2006 Post subject: |
Sorry for hijacking the thread but I wonder if someone could clarify the point made about the punishment for having a loud can.
When I bought my new bike it came with Termignoni cans on - clearly marked 'race use only' and clearly very loud. Given that it also came with the standard cans, and that I have an unnatural sense of social responsibility and fear of the police, the standard cans went back on in seconds.
Is it still just a £30 fine if you're stopped with cans specifically marked 'race use only', or can you get points for taking the piss? Obviously there are also insurance issues. ____________________ Monster m600
Web, blog, Bikepics page
An optimist will tell you the glass is half full. The pessimist, half empty. The engineer will tell you the glass is twice the size it needs to be. |
| strag |
| colin1 |
| innominate |
 innominate Brolly Dolly
| Kickstart |
| the grim reaper |
 the grim reaper World Chat Champion
| MarJay |
 MarJay But it's British!
The last post was made 20 years, 155 days ago. Instead of replying here, would creating a new thread be more useful? |
