Clutch window, what material to use for the window?
Klause
PostPosted: 20:55 - 22 May 2006    Post subject: Clutch window, what material to use for the window? Reply with quote
I picked up a clutch cover at BMF for stupidly cheap. I'm going to cut out a hole and make a window to see all the spinny stuff.
But, what do I use for the window? It has to put up with ducati vibs, UK potholes, oil and heat.
Current bikes: 1960 Triumph 5ta x2, TTR600RE, KTM200EXC, Cagiva Elephant 900ie.
mr jamez
PostPosted: 21:20 - 22 May 2006    Post subject: Reply with quote
I know a few people who have got windows/screens for their cars from this place, they might be able to make up something pretty cool. Anyway, I pasted the info on the plastics they have. Oh and...Razz
https://www.plastics4performance.co.uk/faq.asp
PLEXIGLAS (Perspex) is the most common material used. It is approximately three times stronger than glass of the same thickness and it has an easy to maintain surface. This surface allows minor scratches to polish out, but it can suffer from stress cracking, especially when it is mechanically fixed to the car. IDEAL FOR HILLCLIMB, SPRINT OR TRACKDAY CARS WHERE CONTACT IS MINIMAL
FLEXI-GLASS is our very own specification high impact acrylic sheet designed for motorsports. A cross between Perspex and Polycarbonate it gives you approx seventy five times the impact strength of standard Perspex. It is more scratch resistant than standard polycarbonate and it is tough, weather resistant and UV protected, which means it will give exceptional service as a replacement window. OUR PREFERED CHOICE FOR CIRCUIT RACING, RALLY, RALLY CROSS ETC.
PETG is a new material, which is again, extremely tough with superb optical properties and very resistant to chemical attack. It is primarily used when the need for Thermoform screens arises. We have this material colour matched to our polycarbonate.
POLYCARBONATE The toughest of materials is almost impossible to break under normal conditions. It is 250+ more impact resistant than glass; however its one fault lies in its relatively soft surface and inability to allow scratches to be polished out.IDEAL FOR ROUGH USAGE SUCH AS FOREST RALLY OR RALLY CROSS CARS.
Bezzer
PostPosted: 21:30 - 22 May 2006    Post subject: Reply with quote
You've got a lathe I take it to make the housing to fit the window because trying to fit one direct to the actual engine casing is not a good idea.P lenty have tried and made a real balls up of it trying to get everything to look right and more importantly seal right as you haven' got a flat surface to work on. I'm just in the middle of doing one myself but its a housing one that will sit proud of the cover, you also have to have the housing ally welded to the casing to make it leakproof.
I'm waffling on because I can't remember for the life of me the name of the perspex stuff that's highly recommended to use Mr. Green When I remember I'll let you know Confused
PS it wasn't any of the above
Klause
PostPosted: 22:23 - 22 May 2006    Post subject: Reply with quote
The ducati one already has threads in the casing for sound deading plates/rubber. So my idea is to use that. I got the case in mint condition for £20 so not fussed if I balls it up.
Bezzer I'll rate you useful when you remember Razz
cagiva gezzer
PostPosted: 22:35 - 22 May 2006    Post subject: Reply with quote
Isn't the monster a dry clutch, hence it won't matter that much if it doesn't seal?
Bezzer
PostPosted: 23:23 - 22 May 2006    Post subject: Reply with quote
I remembered Idea it's Makrolon, bit stronger than Lexan but didn't click about it being a dry clutch so really either will do as they're both bulletproof type stuff, Makrolon was a bit better for oil resistance as well.
Klause
PostPosted: 21:53 - 23 May 2006    Post subject: Reply with quote
No, but yes.
600's and 750's are wet clutches. The rest are dry... FOOL! Mr. Green
*Edit*
Just bought some POLYCARBONATE SHEET (lexan) 5mm thick and A3 size for £9 posted. Should hopefully get some pictures up soon of my creation Thumbs Up
DAYS
PostPosted: 14:47 - 24 May 2006    Post subject: Reply with quote
what you want is lexen here is mine tls been done now for close to 15000klm and still as clear as the day it was done
https://i37.photobucket.com/albums/e75/davetls/IMGP1100.jpg
https://i37.photobucket.com/albums/e75/davetls/IMGP1101.jpg
https://i37.photobucket.com/albums/e75/davetls/IMGP1095.jpg
you have 2 hands 2 feet 2 eyes 2 nuts why the hell do you need 4 cyclenders
Klause
PostPosted: 00:12 - 25 May 2006    Post subject: Reply with quote
Wouldn't have pictures of the inside would you, or know how it was mounted and sealed etc??
DAYS
PostPosted: 07:31 - 25 May 2006    Post subject: Reply with quote
mate i dont sorry but it was milled down to fit but also had a lip of about 20mm that was still inside for the glue for memery it was
8mm thick lexen but the clutch cover was only 4mm thick so it was milled down to fit flush with the face of the cover and was over hanging on the inside good luck with it you now you can allways cut the face out of your cover and leave a 10mm ring of the face there and fix the lexen to the face the billet ones they make for tls/tlr are made like this
https://i37.photobucket.com/albums/e75/davetls/DSC00337.jpg
https://i37.photobucket.com/albums/e75/davetls/P1010797.jpg
Klause
PostPosted: 10:34 - 25 May 2006    Post subject: Reply with quote
Cheers DAYS, might have a try at cutting my case today. My lexan sheet arrived today. Thumbs Up
DAYS
PostPosted: 11:25 - 25 May 2006    Post subject: Reply with quote
mate just take your time you need to find dead center of your cover when you cut or it will look like crap mate and good luck some pics when you get it done to would be good Thumbs Up Thumbs Up
Bezzer
PostPosted: 11:36 - 25 May 2006    Post subject: Reply with quote
Too true, I ended up making a template first, mounted the cover to a piece of thick plywood then experimented trying to get dead centre, it took a while to get it spot on. When I got it put a spindle in the template centre hole so I could then spin the whole lot in a lathe to cut the hole true.
Klause
PostPosted: 11:51 - 25 May 2006    Post subject: Reply with quote
Ok, well mines gonna look on the piss! Laughing
Klause
PostPosted: 14:46 - 25 May 2006    Post subject: Reply with quote
See https://www.bikechatforums.com/viewtopic.php?p=998634#998634 for pictures.
The last post was made 20 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 87.38 Kb
