works fine on full throttle but drop to half throttle =(
firefox
PostPosted: 21:24 - 23 May 2006    Post subject: works fine on full throttle but drop to half throttle =( Reply with quote
Well i had a problem with my engine not running at all well i got it started and it run fine until i dropped the revs below 6000rpm which is about half throttle, i was thinking maybe the throttle needle as this is what comes into use up to half throttle. Any help would be great
thanks in advance
( sure someone keeps breaking it everytime i get it fixed )
puremagic72
PostPosted: 23:00 - 23 May 2006    Post subject: Reply with quote
Does it sound a bit "poppy". cause mine is also doing this.
Baz. Thumbs Up Thumbs Up
Make; cbr929cc blade Year; 2001
Gsxr 750 2000, alstare Corona, Current bike 1999 R6
(1) Kids in the back seat cause accidents; accidents in the back seat cause kids.
firefox
PostPosted: 23:04 - 23 May 2006    Post subject: Reply with quote
yes lol, well my mate 125power is ment to be comming next week to look at it. i give up had the whole engine stripped down didnt sort it Sad
puremagic72
PostPosted: 06:19 - 24 May 2006    Post subject: Reply with quote
Wat bike you got?
edd
PostPosted: 08:44 - 24 May 2006    Post subject: Reply with quote
defo sounds like a carb problem, its not unknown for the needles on scooter carbs to get stuck. On most its a basic slide carb, the needles get stuck on the spring around them (or at least they have for me) though usually when they do they stick the throttle open. Id be checking your jets for a blockage if I were you, it can happen fairly easily with crap out of the fuel, especially when you have such small size jets.
good luck with it Thumbs Up
Bluespark Automotive - Diesel Tuning for Performance and Economy
Barry_M2
PostPosted: 10:18 - 24 May 2006    Post subject: Reply with quote
Blocked pilot jet(s) i'd say.
Remove your carb(s), get the float bowls off and revmove and clean all the jets.
firefox
PostPosted: 14:49 - 24 May 2006    Post subject: Reply with quote
Hi i had the carb off and none of the jets are blocked.
puremagic72
PostPosted: 20:03 - 25 May 2006    Post subject: Reply with quote
Might be the exhaust, maybe needs de-coking, or even a small hole somewhere.
Getting mine checked over next week.
firefox
PostPosted: 20:48 - 25 May 2006    Post subject: Reply with quote
my cable had slid off the needle so mines fixed Thumbs Up oh and it was also running far 2 rich.
the grim reaper
PostPosted: 22:55 - 25 May 2006    Post subject: Reply with quote
Could be the reeds playing up, dunno really, without more info. Could also be a sticky carb slide, OK on full throttle because the butterfly is open, flooding on part throttle because not enough air.
Grim
sickpup
Old Timer
PostPosted: 09:13 - 26 May 2006    Post subject: Reply with quote
What air filter are you running?
The last post was made 20 years, 146 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.05 - MySQL Queries: 13 - Page Size: 67.3 Kb
