Builders advice needed
andrew
Mister Road Rage
PostPosted: 15:15 - 23 May 2006    Post subject: Builders advice needed Reply with quote
I was wondering if anyone out there could help me. I'm about to fit the roof to my garage this weekend, but am a bit stuck on how i'm going to do it.
I wanted to use these;
https://www.screwfix.com/app/sfd/cat/pro.jsp?cId=101228&ts=87867&id=59983#
but don't know how well they will bolt to medium density air blocks. I like the look of them because i think they would be a whole lot easier than cutting out the blocks so i can mortar the roof beams in place. Will these and standard wall plugs be fine or do i have to use special plugs seeing as the blocks are medium density.
Thanks
Andrew
Walloper
PostPosted: 15:18 - 23 May 2006    Post subject: Reply with quote
Ask the supplier who sold the hangers.
Sorted. Thumbs Up
andrew
Mister Road Rage
PostPosted: 15:25 - 23 May 2006    Post subject: Reply with quote
Well they're on the internet and i don't reckon the muppets on the phone will have a clue what i'm on about. Very Happy
daz|n00by
The Internet
PostPosted: 18:36 - 23 May 2006    Post subject: Reply with quote
Just use a standard 2" 10 screw and fix them from the top down wards on to the top coarse of block work, they will hold fine as they are designed so that the hanger part on the top cant close in due to the tight fit of the joist.
In other words when the joist is pushed into the joist hanger they cant go anywhere apart from side to side but this is stopped by either the joist braces you will be putting in or the roofing board attached to each joist on top.
"Its Better To Burn Out Than Fade Away!!!!!!" "Lifes a bitch and then you Die"
"I`m a tool, one with just enough intelligence to know it, just enough spirit to resent it...but not enough backbone to do anything about it. " Siggi 2006 pure class. Smile
The Old Geeza
Back in my day...
PostPosted: 22:49 - 23 May 2006    Post subject: Reply with quote
Ah Yes...
2" 10 Screws. The best size screw ever invented Thumbs Up
They're my absolute favourite - honest Thumbs Up Smile Thumbs Up
You're a man after my own heart, Daz Thumbs Up
Horse Power was safer when the Horses had it!
daz|n00by
The Internet
PostPosted: 22:53 - 23 May 2006    Post subject: Reply with quote
well like i always say about 2" screws
IT MAY ONLY BE 2 " BUT I HAVE 13 STONE TO PUSH IT IN WITH;
The Old Geeza
Back in my day...
PostPosted: 23:08 - 23 May 2006    Post subject: Reply with quote
And don't forget, it'd got the girth of a No.10 too Thumbs Up
Razz
MikeH
PostPosted: 23:29 - 23 May 2006    Post subject: Re: Builders advice needed Reply with quote
Thanks
Andrew
I'm no builder but I've done my fair share over the years with various extensions & garages. You could screw them into the block, But, the problem is the top course of blocks (assuming this is a single storey) aren't tied to each other so you could end up with them coming adrift. You need to fix a wall plate along the top of the wall first to tie it all in and then nail the hangers off that or alternatively sit the joists onto the top of the wall plate, squew nail them into position and block in the gaps, covering when finished with a facia, not forgetting to strap inside using wall ties to prevent the roof being lifted off.
Mike
Busa Junkie
andrew
Mister Road Rage
PostPosted: 11:42 - 24 May 2006    Post subject: Re: Builders advice needed Reply with quote
Mike
I hadnt' thought about the top course not being stable with the joists attached, mainly because i thought once all the joists were in place they would hold the top course in place. I've got plenty of timber, would it be an option to bolt a bit of timber on top of the final course (to hold it alltogether) and then bolt the brackets through the timber and final course of bricks? Please say that makes sense? Very Happy
I didn't think about the roof coming out of the brackets either, i guess just to be safe it might be an idea to drill through the brackets and the timber joists and then bolt the two together?
Thanks for all your help guys.
MikeH
PostPosted: 13:34 - 24 May 2006    Post subject: Reply with quote
OK, your need a timber sitting on top of the wall, this can be fixed simply by using L shaped straps down the inside wall about every couple of meters nailed into the top of the timber and screwed and plugged into the wall.
Then hang the hangers off this timber again nailing into the timber and sit the joists into it again nailing them to the hangers.
Busa Junkie
MikeH
PostPosted: 13:45 - 24 May 2006    Post subject: Reply with quote
excuse amatuer drawing
Busa Junkie
Scouse
Whats wrong with just sitting the joists on top of your top course and bricking up the space in between them to hold them in place?
andrew
Mister Road Rage
PostPosted: 15:13 - 24 May 2006    Post subject: Reply with quote
Nothing i guess, the reason i was looking at using those brackets is because i thought i'd have to cut down the blocks and mortar the joists in place. The thing with this is that i've only been using an angle grinder and boulster, (sp) so don't know how easy it would be to get even/tidy cuts.
I think for sake of ease i'm going to go with your idea, i've gone up 10 blocks so i'll put the joists in place on top of the the blocks and build around them with bricks.
I'll put some photos up when i'm done. Very Happy
Cillit-BANG
PostPosted: 16:10 - 24 May 2006    Post subject: Reply with quote
Has your building control officer not given you any adivice?
To be perfectly honest, I think you may be wise getting a professional builder to spare an hour of his time to get you on the right track.
There really is a right way and wrong way to do it. Get it wrong and your whole roof will indeed risk being blown off. It needs to be tied into the wall using L-straps running down several courses. Fixing it just to the top row will offer very little stability.
I presume your not fitting any electrics? If you are, it is now a requirement to have the rest of the building's supply checked before any work can commence. In which case you may want to make sure your new garage is being build to the required standard before they come to inspect the wiring, as chances are it will be the same building control officer that checks both aspects.
Building regs are there for a reason, not just to put off potential diy projects Thumbs Up
And for what it's worth, 5x50's are the new 2"10's Razz The screw choice of champions.
andrew
Mister Road Rage
PostPosted: 18:02 - 24 May 2006    Post subject: Reply with quote
A couple of things, i haven't talked to and don't have a building control officer. The building is right at the back of my garden and is so small in relation to my garden that when the council building inspector came for my next door neighbours extension he didn't even bat an eyelid.
As for the roof blowing off, i have doubled up the blocks that are going to be supporting the roof, the double columns are then bolted together every other block, if i go the bracket route like i mentioned in the first post then i'm sure that bolting the joists to the bracket will offer more than enough stability. As well as this there will be 3 large cross joists being mounted to the side walls which again have been doubled up where supporting the joists.
On top of the joists i will be using weather treated plywood, covered in felt and sealant, the joists will have insulation between them and will be covered in plasterboard on the inside.
Theni was going to bolt each corner of the roof to the brickwork which again is doubled up in the corners.
I have seen LOTS of garages put up that have been bodged (sp) a lot more than this one so am not really worried about the roof taking off Wink
As for electrics, my mate is a sparky and is going to be running from the fuse box in the house, the cable will be run through inch thick truncking that is being run 1ft under the garden, this is waterproof and spade proof. I'm sure he will be complying to all regs. Very Happy
Cillit-BANG
PostPosted: 19:27 - 24 May 2006    Post subject: Reply with quote
Not unless he a) Has the existing house wiring checked and b) Has the new work certified and submitted to the relevent bodies.
Your absolutely right though, provided your not taking the piss, I don't have a problem with building things to what you are happy with. At the end of the day the nanny-state will have you get permision to take a crap before long.
I'm just here to make sure your aware of how to make things good by following tested building methods.
If your going to use the joist hangers, then I would lay flat a 4"x2" wall-plate (preferably in 1 peice of timber or half-lap the joints) over the top of the block-work and covering the top flap of the hanger. Then run an L-strap from this and down the wall at 4' intervals.
You will then need to ensure your joists stand up out of the hanger by 2" to line up with the top of this wall plate.
Have fun Thumbs Up
andrew
Mister Road Rage
PostPosted: 21:46 - 24 May 2006    Post subject: Reply with quote
Brilliant stuff. Thumbs Up
I appreciate your comments, to be honest i hadn't put that much thought into the roof and was really searching for the best way of doing it.
I think i'm going to go the way you suggested and use the brackets and mount them under a timber plate. Then using the l-pieces to secure it to the brickwork.
Thanks for your help, i'll no doubt be back on here when i get stuck. Wink
Scouse
PostPosted: 23:08 - 24 May 2006    Post subject: Reply with quote
I am one Wink
I do this sort of thing everyweek Razz
The last post was made 20 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 102.39 Kb
