90 miles...
Sephiroth
PostPosted: 18:51 - 24 May 2006    Post subject: 90 miles... Reply with quote
Is 90 miles to the tank (without reserve) alright for a GSF400?
Mr.Everready
PostPosted: 18:57 - 24 May 2006    Post subject: Reply with quote
Work it out yourself. How many litres do you put in to fill it ?
Sephiroth
PostPosted: 19:01 - 24 May 2006    Post subject: Reply with quote
Well I put 12 quid in to brim it, so thats roughly 12 litres in the tank.
How do I work it out?
regprescott
PostPosted: 19:06 - 24 May 2006    Post subject: Reply with quote
Next time you fill up note how many miles done/litres used and use this to do the working out for you https://www.torquecars.co.uk/Tuning/uk-mpg-calculator.php
fire
it sounds about right.... Confused
Write off! Honda NSR150 RR ('01) - Sold Cagiva Mito Evolution ('00) - Sold Honda NSR125 ('01) - Current Gasgas TXT 250 ('98) - Sold Kawasaki Z750 ('10) - Write off! Yamaha FZ1 ('09) - Current Ducati Streetfighter 848 ('14)
Sephiroth
PostPosted: 19:13 - 24 May 2006    Post subject: Reply with quote
34.1 mpg.
Just seems a bit different compared to the 125 Laughing.
JonB
Afraid of Mileage
PostPosted: 19:15 - 24 May 2006    Post subject: Reply with quote
Well my Bandit 600 does 160 miles before reserve. So I gotta feeling something is wrong. Confused
ram_doom
PostPosted: 19:18 - 24 May 2006    Post subject: Reply with quote
you put on weight seph? Get the carbs adjusted in Ray william's place Thumbs Up Mark is a good mechanic!
TL1000s, KDX200
Sephiroth
PostPosted: 19:21 - 24 May 2006    Post subject: Reply with quote
Weight? I haven't eaten in two days, I'm thinning away Shocked.
How much would it cost to get it sorted then?
Jamie.
PostPosted: 19:23 - 24 May 2006    Post subject: Reply with quote
57mpg on my 500
mr.z
PostPosted: 19:24 - 24 May 2006    Post subject: Reply with quote
Was talking to nath about mpg's on his four..
Consumption goes up rapidly as your average revs goes up, so where as i'll give my cx(500 twin) a propper spanking and it barely makes a dent in mpg figues (17litres will get me 180miles or so, more on the motorway) his cb550(four) starts drinking fuel at a shocking rate.. but then his does rev much higher!
Your 90 miles sounds faily good, but if your worried have a check of your plugs and check their condition, if they are looking a bit sooty/oily then you might be runing slightly rich (choke could be stuck slightly on for example) but dont think you should worry too much Wink
ram_doom
PostPosted: 19:28 - 24 May 2006    Post subject: Reply with quote
£30 odd quid for the carbs balanced and little jobs. Your fuel consumption sounds something like mine which cant be good Wink you been riding like a nutcase?
TL1000s, KDX200
Sephiroth
PostPosted: 19:30 - 24 May 2006    Post subject: Reply with quote
Just checked manual, it says this:
Capacities
Fuel tank, including reserve:
14.5L (3.8/3.2 US/Imp gal) E33 only
16.0L (4.23.5 US/Imp gal) others
Reserve 3.5L (0.9/0.8 US/Imp gal)
Shocked
Sephiroth
I was riding around gower at a speed of 80 most of the time Rolling Eyes
Only for about an hour or two.
craigs23
Mr Muscle
PostPosted: 19:31 - 24 May 2006    Post subject: Reply with quote
Even with frequent abuse to my Bandit 4's throttle stop, the bike reguarly returned over 135 miles before needing reserve. Somehow 34mpg doesn't sound right for a 'detuned' 400.
Sephiroth
PostPosted: 19:38 - 24 May 2006    Post subject: Reply with quote
So what do you recommend? My father just said that I wont be able to get much more fuel ecconomy from it Shocked.
Somehow I don't trust his judgement.
craigs23
Mr Muscle
PostPosted: 19:42 - 24 May 2006    Post subject: Reply with quote
Is it completely standard? (the standard system is a welded one piece as far as I know, could it have been replaced and therefore warrented a re-jet?) What's the engine speed at 80mph? What are the plugs like? Air filter condition? Fuel lines in good working order? Any petrol smells?
mr.z
PostPosted: 19:43 - 24 May 2006    Post subject: Reply with quote
Hmm spoke to a mate who had an import bandit 400, custom exhaust and jetted with k&n filter, dispite the serveer spanking it got it still gave 45mpg at worst, 50 on a good day.. (untill a rabbit got in the way and it got mashed allong with his arms)
If you can fdind a mechanice competant enough to tune it propperly then do that, if not try a dyno..
Is it restricted? thats a very plauseable reason for crappy fuel consumption?
Sephiroth
PostPosted: 19:49 - 24 May 2006    Post subject: Reply with quote
As far as I know it isn't restricted, but it might be saying that, I'll find out tomorrow (by seeing how fast I can go).
It's standard Craig, don't know what you mean by engine speed at 80 mph.
I'll have to give everything a check over tomorrow morning when it stops raining.
So I definately shouldn't be getting 32mpg?
KevTM
PostPosted: 21:14 - 24 May 2006    Post subject: Reply with quote
no ridden the 400 bandit in quite some time but i'm sure i got 130miles to a tank
Sephiroth
PostPosted: 21:16 - 24 May 2006    Post subject: Reply with quote
Well fooking gutted.
Even if I got new plugs, balanced carbs etc, that wouldn't make a dramatic difference would it? I mean, a whole 40 miles difference?
Jack_Cheese
PostPosted: 21:26 - 24 May 2006    Post subject: Reply with quote
It's nearly 50% extra! that means your bike is burning 1.5* the fuel it should be - seriously rich. Checked your plugs yet? If they're not black, i'll bend over forwards, bounce up into a triple sommersault and disappear up my own arse!
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
Sephiroth
PostPosted: 21:29 - 24 May 2006    Post subject: Reply with quote
I'll go for a little run and then check them, i'll report back to base soon.
Sephiroth
PostPosted: 22:12 - 24 May 2006    Post subject: Reply with quote
Well the spark plugs are as black as black can be.
Finglonga
PostPosted: 22:15 - 24 May 2006    Post subject: Reply with quote
https://www.mkiv.com/techarticles/read_plug/plugdiag.jpg
Andy Sez....
F.Y.Y.F.F.
The last post was made 20 years, 109 days ago. Instead of replying here, would creating a new thread be more useful?
Goto page 1, 2, 3, 4  Next
Page 1 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 122.89 Kb
