What have you done to your bike today?
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... , 60, 61, 62  Next
hellkat
PostPosted: 19:13 - 30 Jun 2026    Post subject: Reply with quote
That's the one
(sorry, brain fart moment Laughing )
Feasty
PostPosted: 14:45 - 03 Jul 2026    Post subject: Reply with quote
So today (over the last week) I fitted a cheap AliExpress gear indicator to my TDM900, which didn't work.
I then used AI instructions to repeatedly try and fix it, moving the speed sensor connection to different places on different settings. It's now destined for the bin.
Conclusion:
1) AI likes to change it's instructions every time something doesn't work, making out you got it wrong in the first place, and responds in a patronising way when you point out it's clearly got something wrong.
2) Don't bother trying to use cheap Chinese gadgets unless you've got a LOT of spare time on your hands!
Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
Current: Yamaha TDM 900 (Comfy, light but big, power when needed).
PostPosted: 16:38 - 03 Jul 2026    Post subject: Reply with quote
*sigh*
AI will only produce a response that sounds like it *might* be correct. It is not a fountain of knowledge. Something obscure like a Chinese gear position indicator is likely to not have accessible manuals online, and so the AI WILL just make shit up. That's what it does. The tech companies call it 'hallucinations' but what it really is is a way of stopping the AI from announcing that it doesn't know everything.
Kawasaki Jimbo
PostPosted: 19:11 - 03 Jul 2026    Post subject: Reply with quote
Right now AI is researching human-authored sources. What happens two years down the line when it’s pulling ‘facts’ from an abundance of AI-authored material?
PostPosted: 19:14 - 03 Jul 2026    Post subject: Reply with quote
Aka Chinese whispers.. Neutral
PostPosted: 19:29 - 03 Jul 2026    Post subject: Reply with quote
Enshittification.
Kawasaki Jimbo
PostPosted: 20:11 - 03 Jul 2026    Post subject: Reply with quote
Yep, it’ll be dog poo.
My employer (for 3 more weeks until redundancy and retirement) expects that AI-produced material will be reviewed by humans before publication, but as staff with hard-won experience and understanding leave it means the newer, younger ones are denied those same opportunities to learn. How are they going to challenge what AI produces? Since we’re developing medicines it’s quite a scary thought.
PostPosted: 20:45 - 03 Jul 2026    Post subject: Reply with quote
Yes, people aren't going to be able to write or reason themselves. Drugs, I can see how good that could be. They can come up with molecular designs that are handed, and foldable proteins and all sorts. Finding out the structure of Haemoglobin took a team of scientists many many years. Nowadays a dedicated AI could do it in seconds.
It does still mean people will be dumb though.
Kawasaki Jimbo
PostPosted: 21:47 - 03 Jul 2026    Post subject: Reply with quote
True, that. I agree it will be revolutionary when applied to the right areas.
Rob W
PostPosted: 07:55 - 04 Jul 2026    Post subject: Reply with quote
Can you imagine it scraping all Delboy's videos and then passing that on as gospel?
It's bad enough with just that twat spouting it Confused
to v or not to v
PostPosted: 13:45 - 04 Jul 2026    Post subject: Reply with quote
to get the thread back on subject...
fitted a rear hugger from China. £60 as opposed to £135 from Pyramid.
Moto Guzzi V7.
PostPosted: 14:23 - 04 Jul 2026    Post subject: Reply with quote
More news on the Harley stuck brake light problem - the Breakout is Brake-on / Broke-on Wink
Did some diagnosing. The right switch cluster that also has the front brake switch is CAN-bus. Mostly anything you press goes over data-wires except the kill switch which is separate. If you disconnect the right switch cluster you can't turn on the bike but if you turn on the bike, disconnect the switch and then hit the kill switch it still turns off... hope that makes sense Laughing
Anyhoo, with the switch cluster connected and the front brake pulled in (with the engine cold) the brake lights work as expected. If you hold the lever in and at the same time disconnect the switch cluster the brake lights go off. Conclusion: 'front brake on' is a continuous 'ON' signal to the BCM not explicit 'ON' and 'OFF' signals.
The Plan: wait for the Old Fella to come back from a long run tomorrow. Hopefully the bike comes back with the brake lights stuck on. If so, we disconnect the switch cluster and see if the lights go off. If they do, it's the switch cluster. If they don't, it's the BCM and ker-ching, take out a second mortgage and send it to a Harley dealer.
BTW, to get at the connector for the switch cluster means unbolting the fuel tank. At this point we could probably do it blindfolded Laughing
Rob W
PostPosted: 08:32 - 10 Jul 2026    Post subject: Reply with quote
Swapped the USB-A charger for the fast charging USB-C one so I can actually charge my phone while using it on the bike.
RhynoCZ
PostPosted: 19:45 - 10 Jul 2026    Post subject: Reply with quote
What kind of amperage are we talking about?
Rob W
PostPosted: 21:08 - 10 Jul 2026    Post subject: Reply with quote
https://www.ebay.co.uk/itm/136287943734
Doesn't give an amperage I can see, but the USB-A one was 2.4 and the phone would drain in use. I think this is only 3 (?), but testing this morning and it charges now so I'm happy with it anyway.
https://iili.io/C0mH0ut.th.jpg
https://iili.io/C0mJ2RI.th.jpg
PostPosted: 23:52 - 10 Jul 2026    Post subject: Reply with quote
Changed it - see other thread. Embarassed
Triumph Trophy Launch Edition
blurredman
PostPosted: 08:13 - 13 Jul 2026    Post subject: Reply with quote
Swapped a good barrel and piston over. Sad
https://www.bikechatforums.com/download.php?id=107376
panrider_uk
PostPosted: 16:35 - 13 Jul 2026    Post subject: Reply with quote
Tank cover off
Airbox off
Handlebar covers off
Only want to swap the ignition barrel
Still got to do some dismantlng of the top end of the forks but the heat in my garage got the better of me.
PostPosted: 18:27 - 14 Jul 2026    Post subject: Reply with quote
Some solid progress with the Harley!
The Old Fella spotted a relatively cheap workshop diagnostics tablet on eBay that said it could do all sorts - module change, key programming, etc. - and who doesn't love another gadget Smile Anyhoo, we fired it up and managed to get live data streams of various things including front brake switch, rear brake switch and brake light. As you work the lever/pedal you see them mirrored on the tablet screen. "Hang on, is that brake light stuck on?!" We looked at the screen and this time it said the rear was on Thinking
The rear brake switch is an inline hydraulic pressure switch. I went to disconnect it and the brake lights started flickering on and off. In the end we discovered wiggling the blades on the switch (not the connectors on the loom side) would activate the switch. Finally! An easily reproduceable problem, so we have a replacement heading over next day from Amazon for £17.
Will it solve the problem? I have a feeling there are overlapping issues here but the handy thing with this tablet is getting separate data streams. If the brake light stays on again we can query the BCM and right hand switch cluster in isolation and definitely get to the bottom of which one is at fault.
panrider_uk
PostPosted: 20:08 - 14 Jul 2026    Post subject: Reply with quote
Bought a "new" Pan
I decided that 10 years of storage had caused the existing one to look somewhat sorry for itself and it was a lot of work to bring it back up to scratch (maybe I'll continue over the winter).
So I found an 02 plate one (7 years younger) with ABS/TCS in very good condition and went for it.
Handily it's the same colour so I'll have a good donor bike if needed.
to v or not to v
PostPosted: 23:17 - 14 Jul 2026    Post subject: Reply with quote
panrider_uk wrote:
Bought a "new" Pan
whats the attraction with this model?
Moto Guzzi V7.
panrider_uk
PostPosted: 00:06 - 15 Jul 2026    Post subject: Reply with quote
Great bike plus nostalgia
to v or not to v
PostPosted: 08:34 - 20 Jul 2026    Post subject: Reply with quote
washed the bike and fitted some second hand crash bars.
ordered the bolt kit from H&B for the bars and it was nearly £50 delivered Shocked
hopefully they will never be put to the test.
Moto Guzzi V7.
Rob W
PostPosted: 09:39 - 20 Jul 2026    Post subject: Reply with quote
Swapped back to the bar end mirrors that I'd installed previously. I'm a little bit, shall we say 'wide' and couldn't see a thing in all honesty from the Puig ones I'd installed.
Swapped back, and can see more from just one of these than I could from the Puig Laughing.
panrider_uk
PostPosted: 16:17 - 20 Jul 2026    Post subject: Reply with quote
Fitted the new ignition barrel to the old Pan
Thought it would be a fairly easy job.
Took two of us all day!
All electrics now working.
Shame it doesn't fire up.
Probably a blocked fuel system as it's been stood for years.
Page 61 of 62
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.54 - MySQL Queries: 13 - Page Size: 135.22 Kb
