 mrbluesbox Scooby Slapper
 hmmmnz Super Spammer
 Posted: 16:33 - 24 May 2007 Post subject: |
well you are only using roughly 75odd watts at any one time not including the drain from the coil,
but i would say it will probly be ok as you are only 20watts over standard, roughly the same amount as the indicators when they are running, you may find with the new lamp that when you turn on the indicators, that it will dim,
the only other thing is weather the cable is large enough to take it,
35w = 2.9 amps
55w = 4.5amps
so you will need a at least a 0.5mm2 cable to handle, which i think minium you will have a 0.75mm2 cable
so i think you should be ok ____________________ the humans are dead
I kick arse for the lord
