| Author |
| minesweeper |
 minesweeper Whoah there!
 Posted: 12:14 - 16 Aug 2002 Post subject: speedo broke |
My speedo needle is no longer spinning around went out for a hack half way through it jsut went to 0 now wont move even at redline in 6th what could be wrong gents? the cable?
matt |
| Back to top |
| TiN |
 TiN Pocket Tin
 Posted: 12:18 - 16 Aug 2002 Post subject: |
heh...I have the same problem! ...except that I probably cause it, 'cos I took it apart in the first place
Anyhoo, to check your speedo cable, simply unplug it from your clocks, and then watch the end of the cable whilst moving your bike forwards/backwards. If the cable is ok, then the cable should rotate.
Alternatively, you can just go a ride, and keep an eye on your Odo/tripmeter. ____________________ TiN
dotgems.net |
| Back to top |
| minesweeper |
| Back to top |
| Joe Camel |
 Joe Camel Nova Slayer
 Posted: 00:27 - 17 Aug 2002 Post subject: |
check the wheel end chaps, if the cable is intact possible cause is the drive tab has broken off in the hub, if so, hmmmm problem. Need hub drive,
CYA  ____________________ ***THE VOICES MADE ME DO IT***
***NOT STOCK & TWO SMOKIN BARRELS*** |
| Back to top |
| EuropeanNC30R... |
 EuropeanNC30R... Gay Hairdresser
| Back to top |
| Dylan |
 Dylan Trackday Trickster
| Back to top |
The last post was made 23 years, 353 days ago. Instead of replying here, would creating a new thread be more useful? |
