This any good for bleeding?
5v3d3b0
PostPosted: 20:26 - 28 Sep 2007    Post subject: This any good for bleeding? Reply with quote
I need to bleed my rear brake...
https://cgi.ebay.es/Purga-automatica-aire-del-freno-para-Moto-Automoviles_W0QQitemZ330169391530QQihZ014QQcategoryZ79074QQrdZ1QQssPageNameZWD7VQQcmdZViewItem
It says it's a one way tap that doesn't let neither liquid nor air back in so no doing/undoing the nipple 100 times. Will this be crap? If not I'll get one
PostPosted: 20:38 - 28 Sep 2007    Post subject: Reply with quote
Wouldn't like to say. TBF I've never had a problem with a bit of pipe.....
Finglonga
PostPosted: 21:13 - 28 Sep 2007    Post subject: Reply with quote
As above. Thumbs Up
Thats a waste of money for such a simple job.
Andy Sez....
F.Y.Y.F.F.
PostPosted: 00:20 - 29 Sep 2007    Post subject: Reply with quote
What does it look like?
A bit of plastic tube and a jamjar Very Happy
Your gran will have the jamjar and a bit of plastic tube from your battery overflow will do - pennies Thumbs Up
nynfortoo
PostPosted: 00:45 - 29 Sep 2007    Post subject: Reply with quote
It should work fine, as long as it isn't a piece of shit.
They make bleeding brakes easier and quicker. They aren't compulsory or even slightly necessary, but they're useful.
alun111
PostPosted: 07:34 - 29 Sep 2007    Post subject: Reply with quote
Agreed. Note you may have to resort to the good ol' simple piece of tube and the original method to get it going if there's lots of air in there, then start with the valve tube.
cheekythomas
PostPosted: 13:16 - 29 Sep 2007    Post subject: Reply with quote
Nothing beats the basic piece of pipe, the valves are ok to shift fluid through in a hurry, but i would still use the old method to do a final bleed.
If you use a pipe and have a upwards bend in it so theres always a bit of fluid above the nipple, its foolproof.
MattHirst
PostPosted: 15:12 - 29 Sep 2007    Post subject: Reply with quote
I tried using one (ok, it had been in the garage going on 10 years...but never used!)
And it totally sucked..the valve did let oil through and no air the other way but it was a lot easier after i cut the valve off, filled the jamjar with old brake fluid and just left the end of the pipe in the jar.
Works wonders i tell ya!
Oh and the packet that mine came in said 79p on it so your getting ripped off Laughing
5v3d3b0
PostPosted: 16:53 - 29 Sep 2007    Post subject: Reply with quote
Is it actually easy to bleed brakes then? You all make it sound like a 5 minute job.
I've never done it before and I need to do the rear desperately
cheekythomas
PostPosted: 17:32 - 29 Sep 2007    Post subject: Reply with quote
Dead easy...
PostPosted: 18:10 - 29 Sep 2007    Post subject: Reply with quote
Shocked
Oil in your brake system?
cheekythomas
PostPosted: 18:14 - 29 Sep 2007    Post subject: Reply with quote
Brake fluid is made from oil so i assume thats what he means. Wink
PostPosted: 18:40 - 29 Sep 2007    Post subject: Reply with quote
aaaa, though he was putting a bit of 10w40 in there or something. Laughing
wikiwiki
PostPosted: 18:50 - 29 Sep 2007    Post subject: Reply with quote
I've never bled brakes before, but before I do it would be nice to get pictures on how it's done.
Stupid, me, I need pictures to understand. Laughing
I won't just bleed the brakes for the hell of it, I need my bike every day and it ain't broke (yet).
Any detailed info around on techniques?
alun111
PostPosted: 19:22 - 29 Sep 2007    Post subject: Reply with quote
In that case, i'd definately hold back until you've got a couple of days where you don't need the bike. Bleeding brakes is easy but you CAN have problems. If you don't know brakes you'll need that extra time to figure out what's wrong.
rsooty
PostPosted: 20:58 - 29 Sep 2007    Post subject: Reply with quote
https://www.lexls.com/tutorials/brake/bleeding.html to bleeding brakes.
Just found it quickly and there are pictures. Although for a car the principles are the same...
Tools
Brake fluid (check the service manual to find out which type is correct)
Ring spanner to fit bleed nipples
Piece of tubing that fits tightly over the nipple (better if it is clear)
Jar or some sort of container to drain fluid into
Guide
1. 1/4 fill the jar with clean fluid, this prevents air being sucked back up the pipe whilst bleeding.
2. Find the brake fluid reservoir and brake nipples on front and rear wheels.
3. Start with the system furthest away from the reservoir.
Place the spanner and pipe onto the nipple and place the other end of the pipe into the jar, ensure it is fully submerged in the clean fluid.
4. Get another person to pump the brake of the system you are bleeding 4-5 times then hold the brake on until you tell them to release.
5. Now you undo the nipple approx 1 full turn untill fluid stops coming out.
6. Tighten the nipple up and once it is tight your friend can release the brake.
7. Check the fluid level of the reservoir and replenish if required.
8. If you are purely bleeding the brakes repeat stages 4-7 untill you stop getting air through the pipe. Once this is accomplished I would recommend repeating the stages 2 further times to ensure no air is still left in the system.
9. Once you are happy there is no air in that system you need to do stages 4-8 on the other system.
If you are renewing the fluid, which needs doing every 2 years and it does make a massive distance, instead of stopping when you no longer see air in the pipe you must carry on untill the fluid coming through is fresh and clean. You will notice the difference.
When you do this you need to make sure of a few things:
Make sure that you never have less then a half filled reservoir at any time, keep topping up.
Make sure no fluid gets onto the brake disc or pads, as it will have a drastic effect on your braking ability.
Make sure no brake fluid EVER gets onto any paint as it will dissolve it.
I would provide pictures, but cant be arsed. Laughing
If you have any queries I would recommend getting a haynes manual for your 'vehicle'. But if you want quick answers just post them and I will try to give you an easy to understand answer.
Hope you understand this.
Sooty
wikiwiki
PostPosted: 21:13 - 29 Sep 2007    Post subject: Reply with quote
Thanks rsooty, moochos helpos. Thumbs Up
puremagic72
PostPosted: 21:22 - 29 Sep 2007    Post subject: Reply with quote
Dont buy it, 1 way valve thingy dont work.
Just the old fashion way, bit of tube, jar with clean fluid in, any problems, just suck it up.
All takes time anyhow!!!!
Baz. Thumbs Up Thumbs Up
Make; cbr929cc blade Year; 2001
Gsxr 750 2000, alstare Corona, Current bike 1999 R6
(1) Kids in the back seat cause accidents; accidents in the back seat cause kids.
rsooty
PostPosted: 21:23 - 29 Sep 2007    Post subject: Reply with quote
https://www.totalmotorcycle.com/maintenance/brakes.htm
Found that 1 specifically for motorbikes. Looks ok and has pictures but pretty much says what I said, but with bad spelling.
Another point I should of made is this:
Once you have bled brakes always test them before you go for a ride. Ride slowly and apply the brakes to check them, then build your speed up and try an emergency stop. This way you know the brakes are working well. Otherwise you may end up not knowing they are crap until you go through some wall.
Sooty
jimbothe
PostPosted: 21:42 - 29 Sep 2007    Post subject: Reply with quote
Those tools are utter crap in my opinion. Bought one identical to the one you posted (first post) and it doesnt work properly.
Just went back to my jar of fluid and my trusty bit of pipe. Thumbs Up
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
Old Time Biker
PostPosted: 00:30 - 30 Sep 2007    Post subject: Reply with quote
Couldnt agree more!Dont rush it or you could end up busting a bleed nipple then you are in the shit.Take it steady Thumbs Up
IT WENT WHOOOOSH.........AND WAS GONE!!
5v3d3b0
PostPosted: 14:40 - 30 Sep 2007    Post subject: Reply with quote
This might seem like a stupid question but where do you get hold of a plastic tube that fits perfectly for you bike and is airtight?
rsooty
PostPosted: 15:00 - 30 Sep 2007    Post subject: Reply with quote
Go to a diy shop, should have something suitable there. B&Q should have something. If not, pop into your local garage, they will probably have a piece lying around they will have no problems giving to you.
Sooty
PostPosted: 19:15 - 30 Sep 2007    Post subject: Reply with quote
If you are totally stuck and can't find an old bit of battery vent tube, here you are.
https://www.airlines-pneumatics.com/webcat/Detprod.asp?ProductCode=S080044#technical
Louise
PostPosted: 15:31 - 02 Oct 2007    Post subject: Reply with quote
Do you need a pipe tho Confused
Did mine yesterday
Open nipple
push brake lever
hold
shut nipple ect ect Got the air out - & hopefully safe ?
The last post was made 19 years, 5 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.67 - MySQL Queries: 14 - Page Size: 129.69 Kb
