| reorg |
 reorg Two Stroke Sniffer
| twotakt |
 twotakt World Chat Champion
 Posted: 18:42 - 05 Feb 2008 Post subject: |
Hi,
I've also experienced this problem with my Rs125, what plug are you running at the moment?
With the BR10EG I found that if I rode the bike at slow speeds the plug would foul and therefore fail to ignite and cut out. This is because this plug runs cold(er) and is unable to burn all the fuel/oil mix.
What I did was run my bike on a BR8EG this plug burns hotter is less likely to foul at low speeds. HOWEVER, if you do run this plug then don't highly rev the bike, this hot plug WILL burn a hole in your piston if you highly rev the bike. But it will save your bike from cutting out at the traffic lights.
Hope this helps,
Jack ____________________ R.I.P. Tareree Shiimi, 1985-2008 |
| iooi |
 iooi Super Spammer
 Posted: 18:50 - 05 Feb 2008 Post subject: |
Sooted up plug, you are running too rich.
Whats the air filter like ?
Choke not stuck on is it ?
I would have a look in a manual and find the base setting for the carb and work from that, doing plug chops till you get it right. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| truslack |
 truslack World Chat Champion
 Posted: 19:37 - 05 Feb 2008 Post subject: Re: aprilla 125 drama`s |
| reorg wrote: | hi guys i have a problem with my rs125, the other day the bike was hard to start and when i got it going, it would always stall when i stopped at traffic lights etc, so when i got home i took out the battery and charged it over night and i also took out the spark plug and it was covered in soot, so i got a new plug and put it in but the bike is still very hard to start, and when it does it will idle normally then when i go to pull away it will just stall, i`ve tried adjusting the pilot screw and the air/fuel screw but they don't seem to be having an effect on the idling of the bike,
any ideas what i can try next, or can anyone recommend a good bike mechanic near Blantyre
thanks guys |
Is the choke on the 125's controlled by a small lever under the right hand fairing? If so check it is still connected properly, my RS got stuck at full choke once or twice till I sorted out the problem. ____________________ Current: Suzuki RG 125 Gamma, Honda H100, Triumph Tiger 800XC, Suzuki SV650 (minitwin) |
| reorg |
| Timmeh |
 Timmeh World Chat Champion
| ginge51 |
 ginge51 Nova Slayer
| reorg |
 Posted: 15:34 - 18 Feb 2008 Post subject: |
nah still wont fire up,
it seems like it wants to start tho,
the battery ran out of power after about 5 mins of trying to turn the engine over so i put it on charge and the fault light came on indicating a fault on the battery, so i went up to halfords and got a new battery, done everything in the new battery instructions, filled it with the acid, charged it for 2 hours, then put it in the bike and nothing no power when i turn the ignition on, no lights totally dead,
so i put the old battery back and and there was power to the ignition and lights, so i charged the new battery over night and put in this morning and still no power with the new battery
so im about to take it back to halfords and try a get a replacement.
so old battery i get power
new battery no power doh.gif |
| reorg |
| truslack |
| hyperactive |
 hyperactive L Plate Warrior
| reorg |
| hyperactive |
| stirlinggaz |
 stirlinggaz World Chat Champion
The last post was made 18 years, 24 days ago. Instead of replying here, would creating a new thread be more useful? |
