| camby |
 camby Nearly there...
 Posted: 11:58 - 26 Dec 2008 Post subject: Ticky CG |
Hi just done the cylinder head on my cg and its really ticky and smokey anyone know what causes this? seems to be running perfect other than that.
Camby  ____________________ VFR400 NC24 & YBR 125  |
| bladerunner |
 bladerunner World Chat Champion
| camby |
 Posted: 12:41 - 26 Dec 2008 Post subject: |
Hi yeah iv checked the clearances should I beable to get the feeler gauge right under?
The valve seals were in it (second hand head)
Guides look fine, its had a new piston and rings aswel.. ____________________ VFR400 NC24 & YBR 125  |
| bladerunner |
| Ichy |
 Ichy World Chat Champion
 Posted: 12:53 - 26 Dec 2008 Post subject: |
The ticking is likely to be valve clearance, either they were tight before and you never heard them or they are too big now. Is it a regular ticking that changes with revs?
Smoke might be down to oil from assembly. Otherwise the valve stems or seals are not as good as you think they are or the head gasket is leaking into the bore. Is the new piston and rings the right size? did you measure the ring gap when fitted? ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| NiteMare |
 NiteMare Spanner Monkey
| camby |
 Posted: 14:13 - 26 Dec 2008 Post subject: |
Hi thanks for all th replys the ticking is fixed now still really smokey think ile just try replacing the valve seals once i figure out how to. Doubt its excess oil from the rebuild ive ran it for ages and it just keeps comming.. ____________________ VFR400 NC24 & YBR 125  |
| Hutchysrs50 |
 Hutchysrs50 World Chat Champion
| Xenocide |
 Xenocide Scooby Slapper
| Hutchysrs50 |
| Finglonga |
 Finglonga World Chat Champion
The last post was made 17 years, 286 days ago. Instead of replying here, would creating a new thread be more useful? |
