How to derestricted your big bike from 33bhp
Noxious89123
PostPosted: 00:04 - 07 Jan 2009    Post subject: How to derestricted your big bike from 33bhp Reply with quote
The original thread I made when I did this was shite, as it was mostly me rambling along and a bit of guess work. I have since successfully derestricted my bike, so it's about time i made a better, clearer post about the subject, as the qustion crops up quite often.
The basic's of it are that you need to remove the fuel tank and airbox of your bike, to get to the carbs. How you do this depends on your bike, so get a Haynes and figure that part out for yourself!
Once you do that, you should see something like this;
https://img393.imageshack.us/img393/564/restrictorsjc9.jpg
These are the slides in the carb. They are not restrictors (I thought they were too at first. D'oh).
https://img172.imageshack.us/img172/2674/1004843v2tp3.jpg
There will be a washer in between each carb and the cylinder head, inside the carb rubbers. You will need to undo the clamps holding the rubbers onto the head so you can lift the carbs up. I lifted the carbs and rubbers off the engine and then stuck the end of a 1/4" extension bar into the hole in each washer and gently levered them out of the carb rubbers. Easy peasy. It worked fine on my bike, but be careful not to damage or split the carb rubbers! (Getting the washer back in this way would be a real pain in the arse, so be sure before you do this.)
https://img512.imageshack.us/img512/1551/1004900za3.jpg
These are the "carb cap" part of the restriction that is mentioned on the FI International certificates.. They sit under the carbtops but ontop of the rubber diaphragm. They stop it (and thus the carb slide and needle) from lifting up / opening up fully.
I didn't know about these (Because there is bugger all information about derestriction on the internet!). I only found out when I had the bike service and the mechanic mentioned it and asked if I wanted the job doing properly. He took them out for £20 under the counter. Thumbs Up
Be careful taking these out, because the diaphragms are very delicate and can tear. (Or so I was told. Didn't do this part myself, so couldn't say.)
Note: No doubt I'll have made some typo's in there somewhere, or something won't be quite explained clearly etc. If so, let me in here or by PM and i'll edit it!
Hope this helps!
m0l0t0v
PostPosted: 01:32 - 07 Jan 2009    Post subject: Reply with quote
Also, to be aware, not all bikes have the rubber parts. Razz
My Hornet didn't. It jsut had the washers in. And it was definately full power after that Wink
Purplepill
PostPosted: 01:47 - 07 Jan 2009    Post subject: Reply with quote
Cheers for clearing that up for me Thumbs Up I removed my own washers but was always curious as to what the 'carb caps' were, dont think my bike (CBR600F) had them but had heard of them being mentioned on other bikes.
Edit: Ah sh*t, it appears this IS a cbr600 Embarassed although mine was a 95'....according to your origional de-restriction thread it uses a different engine? If the washers were out but the caps in, do you have any idea what power it would make roughly? I pinned it to just over 150 (on the speedo Rolling Eyes ) so im guessing it didnt have caps, but curious, if it could still make 80 odd bhp with the caps in I guess its possible?
''He had the confidence of a baby-goat dared to tickle a t-rex's nutsack''
Noxious89123
PostPosted: 21:28 - 07 Jan 2009    Post subject: Reply with quote
If you hit over 150, i'd say it was making full power. Mechanic saying my bike would only be making about 50~60bhp.
Also, they're hard plastic, not rubber. Just to clear that up Smile
Purplepill
PostPosted: 02:33 - 08 Jan 2009    Post subject: Reply with quote
Nice one, it was definatly full power then, I dont have it anymore so was just curious/double checking Razz .
linolino1 This post is not being displayed because it has a low rating (Confusing). Unhide this post / all posts.
Naggedalot
PostPosted: 11:35 - 03 Jun 2009    Post subject: injectors! Reply with quote
Most bikes arenow fuel injected...: no carbs!!!
`80 GP100, `79 KH100, `82 CX500, `82 CB250, `o7 Aprillia SR factory-R 50cc, `08 GSF650
Noxious89123
PostPosted: 21:12 - 03 Jun 2009    Post subject: Re: injectors! Reply with quote
*shrug*
PostPosted: 22:04 - 03 Jun 2009    Post subject: Re: injectors! Reply with quote
I would put a bet on that most people on restricted licences couldn't afford a brand new bike that's using FI Rolling Eyes
Noxious89123
PostPosted: 22:25 - 03 Jun 2009    Post subject: Reply with quote
That's a pretty good point, didn't think of that Laughing
Anyways, FI is for fag0ts. Laughing
binge
Emo Kiddy
PostPosted: 22:33 - 03 Jun 2009    Post subject: Reply with quote
Orly?
https://img.photobucket.com/albums/v358/binge/Photo0135-1.jpg
PostPosted: 12:50 - 04 Jun 2009    Post subject: Reply with quote
binge wrote:
Orly?
Faggot Wink
Danzio
PostPosted: 15:14 - 04 Jun 2009    Post subject: Reply with quote
the TL is a beautiful bike though Smile Thumbs Up
pleanty fast too Razz
Noxious89123
PostPosted: 21:00 - 04 Jun 2009    Post subject: Reply with quote
binge wrote:
Ya rly
https://upload.wikimedia.org/wikipedia/commons/6/6a/Yamaha_RD350LC_01.jpg
binge
Emo Kiddy
PostPosted: 22:59 - 04 Jun 2009    Post subject: Reply with quote
Noxious89123 wrote:
Thinking
https://img.photobucket.com/albums/v358/binge/Photo0277.jpg
(yes I know its not quite finished)
Noxious89123
PostPosted: 23:03 - 04 Jun 2009    Post subject: Reply with quote
You can't be suggesting your pitbike is more pimp than an LC? Confused Shocked
That would require a power level over 9000
nowhere.elysium
The Pork Lord
PostPosted: 23:05 - 04 Jun 2009    Post subject: Reply with quote
It can be when it's this pit bike...
Noxious89123
PostPosted: 23:07 - 04 Jun 2009    Post subject: Reply with quote
Yeah but everyone knows that the 350 is the shizzle.
Binge, put an LC motor in your pit bike Razz
nowhere.elysium
The Pork Lord
PostPosted: 23:13 - 04 Jun 2009    Post subject: Reply with quote
Why is there no 'This post was written by a loon' karma button? Laughing
binge
Emo Kiddy
PostPosted: 23:39 - 04 Jun 2009    Post subject: Reply with quote
LC = Liquid Cooled?
Erm, My TZR125 2 stroke engine is Liquid cooled. Its also 26bhp. Which is 19bhp more than the standard pit bike engine.
Ben
Jrod
Page 3 Girl
PostPosted: 00:11 - 05 Jun 2009    Post subject: Reply with quote
binge wrote:
Orly?
I raise you. Razz
https://img14.imageshack.us/img14/7673/photo0102g.jpg
Adrian89
PostPosted: 00:52 - 05 Jun 2009    Post subject: Reply with quote
Have you guys really restricted that kwak and the suzuki to 33bhp???
I'd love to pull up next to you at the lights, probably the only time my 400 would beat a 1000cc+ bike!
(you do realise chav's in tuned hatchbacks will be so smug with themselves if they think they've just smoked one of your bikes)
Adrian89
PostPosted: 00:55 - 05 Jun 2009    Post subject: Reply with quote
Have just re-read and think your not claiming to have restricted it but are claiming its not a bike for 'faggots,' my bad lol
Jrod
Page 3 Girl
PostPosted: 01:02 - 05 Jun 2009    Post subject: Reply with quote
I did once dream of restricting a 12r! I got called mad to consider it (i wasn't gonna keep them in long Razz)
c_dug
PostPosted: 11:34 - 05 Jun 2009    Post subject: Reply with quote
Binge i think he meant put an RD350 engine in it.
Either way that thing looks pretty damn fun.
(still got owned in the carbs vs FI with the RD pic though)
c_dug
edit:by thing i mean the pit bike
The last post was made 17 years, 134 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.41 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 138.17 Kb
