| scorchy |
 scorchy L Plate Warrior
| Hutchysrs50 |
 Hutchysrs50 World Chat Champion
| Jeansy001 |
 Jeansy001 Nova Slayer
 Posted: 20:39 - 23 Aug 2009 Post subject: |
On my CBR 400 the oil ight comes on in neutral and when i turn it on.
check the oil if its fine then its a wiring problem and just ignore it. just check the oil nice an regularly to make sure the bikes not misreading how much oil is in the engine. if the light stays on all the time then you need more oil
hope this helps  |
| scorchy |
| scorchy |
| Kickstart |
 Kickstart The Oracle
 Posted: 21:18 - 23 Aug 2009 Post subject: |
Quite common on 2 strokes for the oil light to come on in neutral to show that the bulb still works.
On most 4 strokes (not Yamahas) the oil light is an oil pressure light so comes on when you switch the ignition on as without the engine running there is no oil pressure.
Most Yamaha 4 strokes use an oil level warning light, but with these they normally wire them up to come on when the ignition is on but the engine isn't running so they appear to work the same as the pressure warning lights.
| Barry_M2 |
 Barry_M2 World Chat Champion
 Posted: 21:23 - 23 Aug 2009 Post subject: |
Its a KMX125 guys, a 2 stroke, not a 4 stroke.
The oil light on the KMX is refering to the 2 stroke oil level in the tank. Completely different to an oil light on a 4 stroke engine, which refers to oil pressure.
It'll be flickering becuse there is no battery, but also more than likely because its low on 2 stroke oil. Dont confuse this with gearbox oil.
Oh, and a KMX doesn't have an alternator.
 ____________________ ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
https://www.bikechatforums.com/profile.php?mode=viewprofile&u=4332 |
| redline |
 redline Derestricted Danger
| scorchy |
 Posted: 21:57 - 23 Aug 2009 Post subject: |
Thanks for all your replies,
Barry_MC21
Are you saying that the light should come on when it requires 2 stroke oil? Shouldnt it be lit all the time then, not just when in neutral?
redline
Am I right in assuming then that this is normal when in neutral and should go out when in gear unless the the 2 stroke oil is low?
Thanks again all, if I can get to the bottom of this and its not a problem I'll probably go buy it!
all the best,
Andy |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 23:55 - 23 Aug 2009 Post subject: |
| scorchy wrote: | Thanks for all your replies,
Barry_MC21
redline
all the best,
Andy |
your assumptions are all correct
go buy it  ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| Jeansy001 |
| Jeansy001 |
 Posted: 07:43 - 24 Aug 2009 Post subject: |
Barry_MC21
redline
all the best,
Andy |
I can now help you here now were clear its 2 stroke. on my aprilia the oil light always came on in neutral, it would also sometimes flicker if the oil was moving about in the tank. your best bet is just to take a peek in the tank and look at the oil feeder pipe and make sure its all running down the pipe nicely. take it out for a test ( if the bikes fine he wont mind ) and see what the light does while your riding ____________________ CBR 400RR,cant get much more fun than that on the road |
| RudiRulez |
 RudiRulez Two Stroke Sniffer
| Phil_D |
 Phil_D Two Stroke Sniffer
| Ariel Badger |
 Ariel Badger Super Spammer
The last post was made 17 years, 43 days ago. Instead of replying here, would creating a new thread be more useful? |
