Aerox speed issue PLEASE HELP!
Hettrick44
PostPosted: 22:30 - 28 Aug 2009    Post subject: Aerox speed issue PLEASE HELP! Reply with quote
Hi all,
I have just bought a 2002 yamaha aerox which has a viper sports exahust, kevlar belt and 6g rollers all installed by the previous owner. However the bike only hits 38mph on a flat but can do 70 with ease down a hill. When i hit about 50 down a hill i can feel the next power band come into play and the bike takes off.
Is there any wany i can make the last power band come into play on the flat so i can get more flat speed? I want to be able to do at least 45 on a flat.
Any help appreciated!
Hettrick
"When the flag drops the b.s stops"
2002 Yamaha Aerox - proud 16 year old can't wait to move on to something bigger Smile
TUG
PostPosted: 19:28 - 29 Aug 2009    Post subject: Reply with quote
Theres no power bands in your bike... a power band is when your bike hits it peak performance making its most power. all engines do it even 4ts (though very short an small).
Your bike probably needs the carb setting up correctly, i wouldnt know where to start personally, maybe mixture is off?
Haz ER-5, innit!
rockers
PostPosted: 22:54 - 29 Aug 2009    Post subject: Reply with quote
sounds like the belt is slipping, mate had same problem, different scooter but same prob and it was the belt
TUG
PostPosted: 23:01 - 29 Aug 2009    Post subject: Reply with quote
Depends how bad the belt has worn, if a belts on its way out if will fail and slip.
Haz ER-5, innit!
W
PostPosted: 04:15 - 30 Aug 2009    Post subject: Reply with quote
Could be your rollers are too light, is it a 50? If so, why does it have 70mph on the clock?
It could also be running lean/rich, have you checked your spark plug?
Hettrick44
PostPosted: 17:56 - 30 Aug 2009    Post subject: Reply with quote
Hi all thanks for the replies,
How do you check that the belt is worn im a newbie to this?
I know how to get at the belt i just don't know how to tell how worn it is?
Also, it is a 50cc and the clock only goes to 50mph but we got 70mph from the gap between where 50mph is on the clock and where the needle ends up.
Also, the rollers are heavy at 6g.
PostPosted: 12:23 - 31 Aug 2009    Post subject: Reply with quote
it wont do 70, so dont worry..your speedo tells lies.
You could try running it hard and then pulling the spark plug, if its all shitty and black, or horribly white, your mixture/carb could do with some sorting.
Im not sure how to check belts as ive never owned a moped, but some guys here are ace at it.
Dont expect it to do 70, hell dont even expect 50...its meant to do 30, and as your sig say your 16...legally you arent allowed over 31mph?
But hey! Check your carb Smile
Noxious89123
PostPosted: 19:35 - 31 Aug 2009    Post subject: Reply with quote
The faster you go, the more inaccurate your speedo will read... Especially if it's out of it's working range.
The last post was made 17 years, 13 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.54 - MySQL Queries: 14 - Page Size: 54.61 Kb
