| eddclarke |
 eddclarke Brolly Dolly
| Dalemac |
 Dalemac World Chat Champion
| J D |
 J D World Chat Champion
 Posted: 07:16 - 15 Sep 2009 Post subject: |
Mine cost about 400 quid but the place i took it to are robbing bastards (Pro bike) ____________________ m0l0t0v wrote: Chris, just so you know, JD is a nutter
| Peter3hg |
 Peter3hg Trackday Trickster
| Handsome |
 Handsome World Chat Champion
| temeluchus |
| the grim reaper |
 the grim reaper World Chat Champion
 Posted: 16:05 - 15 Sep 2009 Post subject: |
Valve clearances are every 42k Kilometers, so 26,250 miles. The actualt check is so easy to do, rocker cover off, remove blanking plate to turn engine over and remove spark plugs. A set of feeler guages and away you go.
If you're paying someone else to do it, it shouldn't cost more than £200 tops, unless you're getting other things done at the same time. Also ask for the old shims, if they replace any.
Grim ____________________ Adverts don't always work: Remember that advert, where the army are running across the desert and they have a wounded man on a stretcher. They get to a ravine, the bridge is down and a caption pops up that says, 'What are you thinking?'. I don't know about you but I was thinking, 'Christ, I'm glad I'm not in the f***ing army'. |
| J D |
| temeluchus |
| the grim reaper |
 Posted: 11:36 - 17 Sep 2009 Post subject: |
| Temeluchus wrote: | | the grim reaper wrote: | Valve clearances are every 42k Kilometers, so 26,250 miles. The actualt check is so easy to do, rocker cover off, remove blanking plate to turn engine over and remove spark plugs. A set of feeler guages and away you go.
Its shim under bucket so the cams have to come out and the head but be partially disassembled so its not that easy unfortunately. |
Unless I'm missing something, surely the clearances can be checked without dismantling the engine and removing the cams??
| temeluchus |
 Posted: 17:03 - 17 Sep 2009 Post subject: |
Why is everyone on this forum such snotty bastards
Sorry yes check.... You dont need to dismantle the head but even if one shim has to be changed then the lot has to come off. ____________________ Some shite cruiser. Now with guns and FREEDOM! |
The last post was made 17 years, 29 days ago. Instead of replying here, would creating a new thread be more useful? |
