NSR Overheating
TGE125NSR This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 16:30 - 29 Jul 2003    Post subject: Reply with quote
Start motor about £60ish
Flush out the coolant, and refill it. Thats assuming that the owner has put any coolant in it Razz
And it doesn't need a technical section, it needs an NSR section!
M1ke
Ped Boi
PostPosted: 16:33 - 29 Jul 2003    Post subject: Reply with quote
Just do what scotty does when his overheats, stop every couple of mile and take a piss on it. Wink
TiN
Pocket Tin
PostPosted: 16:40 - 29 Jul 2003    Post subject: Reply with quote
Is it actually overheating, or are you going purely by the temp guage reading? Could be a dodgy thermostat for false readouts. Otherwise, is the coolant topped up?
TiN
dotgems.net
Scotty
Scooter Boi
PostPosted: 17:20 - 29 Jul 2003    Post subject: Reply with quote
What, it worked didn't it.
Ok it smelt for a week, but at least i didnt have to replace parts of the engine.
Possibly one of his gaskets it blowing.
Does it get hot then drop, then hot again?
or does it just slowly rise?
Does it bubble over, like after you turn the engine off can you here the water being cooked in the top end.
Does it over flow out the water top up?
Regards
Scott
Ropehead
PostPosted: 17:45 - 29 Jul 2003    Post subject: Reply with quote
it could be the impela wheel that pnmps the coolent round.
Head gasket cousing it to over heat
Blacked coolant system
too much coolent
too little coolent
dodgey thermostat (least likely)
Scotty
Scooter Boi
PostPosted: 18:03 - 29 Jul 2003    Post subject: Reply with quote
Sounds like the same problem mine had, 20 min job replacing the base gasket and problem solved
Regards
Scott
PostPosted: 21:15 - 29 Jul 2003    Post subject: Reply with quote
Is the radiator hot, or does the engine get hot with the radiator staying cold?
Does the engine use any water?
If the head or base gaskets are gone it is likely to use some water.
If the coolant cannot circulate properly then it is likely the engine will be hot while the radiator stays cold. This can happen is the water pump is not working, the thermostat is sticking or also if the antifreeze mix in the cooling system is too strong (should be about a 50/50 mix of water and antifreeze)
The last post was made 23 years, 53 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.36 - MySQL Queries: 14 - Page Size: 65.74 Kb
