Welding up a car exhaust
Cigaro
PostPosted: 08:50 - 29 Jan 2010    Post subject: Welding up a car exhaust Reply with quote
Hi all
The pipe on my car has rusted through and snapped at the join with the backbox. I am wondering if it is worth trying to stick weld it or if it's pointless even trying?
Any tips for welding stuff this thin with an arc welder? I'm pretty shit at welding yet but I've been practicing a lot.
Cheers.
pepperami
PostPosted: 10:27 - 29 Jan 2010    Post subject: Reply with quote
i`ve tried welding corroded joins on exhausts before Shocked , in the main it does`nt work and unless your a good/professional welder, you will end up with even less exhaust Shocked Confused as you blow holes in it Laughing
well thats what happened to me!!!! Laughing
poke a bit of metal in the hole and wiggle it about and see how much more corrosion there is around that hole.
you may be only able to see a small part of the corrosion from the outside, but inside a lot more may be rotten.
Ichy
PostPosted: 15:08 - 29 Jan 2010    Post subject: Reply with quote
With a stick welder it would be better to plate the hole, start the arc on the patch piece and run onto the exhaust to reduce the agresssiveness and heat of the arc. You could also consider puddle welding the plate. This assumes that you can find some decent material to weld the plate to Laughing.
Another option is to get some pipe with an ID close to the OD of your exhaust. Split the pipe in half, clamp around the split, and weld the two halfs back together.
Generally not worth the trouble welding monkey metal exhausts with a DIY arc welder but if you can get your hands on a carbon arc torch then you can have a go at brazing a patch on there.
ZRX61
Victor Meldrew
PostPosted: 02:29 - 30 Jan 2010    Post subject: Reply with quote
It's gonna end in tears.. Wink
reggie
PostPosted: 02:39 - 30 Jan 2010    Post subject: Reply with quote
dont even try it with a stick welder you will end up chaseing holes
you could just replace the back box with a bit of pipe Twisted Evil what car is it btw ?
when the shit hits the fan make sure its facing the other way.
kingsmith
PostPosted: 01:10 - 31 Jan 2010    Post subject: Reply with quote
by the time you have fucked around trying to weld the back box , you might as well get a new one fitted.
10 mins in an exhust place job done. i never bother with trying to fix exhaust anymore just not worth it.
so cheap now a days, well unless you have some realy expensive system. but most not so.
luck Thumbs Up
honda cg 125 copy cheap and crap, perfect for work..
suzuki gsxr600 srad 2000
passed 12/11/09 happy boy
Ariel Badger
PostPosted: 10:08 - 31 Jan 2010    Post subject: Reply with quote
You can do it but do not use Mild Steel rods. Go to a specialist welding supplier and as for some "Gapex" rods, specify the grade for welding rust to nothing other than cruddy carbon and oil.
Good luck.
Robby
Dirty Old Man
PostPosted: 13:30 - 31 Jan 2010    Post subject: Reply with quote
Welding thin stuff, unless you're good at welding, isn't going to work.
For an easy gypsy repair, the exhaust repair kits in halfords are ok. You get a metal sleevey thing and lots of exhaust putty, I add lots of jubilee clips as well. I did one of these repairs on my woman's car where the front pipe had split on the flexi joint, a month later and it's still holding. I think the kit cost just under a tenner.
andybon
PostPosted: 16:57 - 31 Jan 2010    Post subject: Reply with quote
As already said it will probably be less hastle to get a new one.
The one on my car blew through on one of the boxes. When i had a closer look it had gone further down the exhaust. Chances are if its gone in one place, Theres another part ready to blow through somewhere else.
Designed by a Genius. Built by a Craftsman. Ridden by a t**t
temeluchus
PostPosted: 17:00 - 31 Jan 2010    Post subject: Reply with quote
As Ichy said, youd have more luck brazing a patch on than welding.
binge
Emo Kiddy
PostPosted: 22:11 - 01 Feb 2010    Post subject: Reply with quote
Polo 1.4?
The middle and rear are sleved together on them exhaust systems. If it's rusted enough to cause a break on the join, You will be lucky to get away with replacing just the middle or rear box.
Off memory, Middle and Rear on a polo is roughly ?90, Fully fitted in our place.
You could probably buy the bits from an autoparts supplier for about ?70, And fit them yourself.
Ben
Ariel Badger
PostPosted: 00:02 - 02 Feb 2010    Post subject: Reply with quote
Ben
After smashing your knuckles on rounded nuts and spending six hours in A&E getting bits of rust scraped from your eye the ? 20 for fitting may seem a fair deal.
binge
Emo Kiddy
PostPosted: 06:55 - 04 Feb 2010    Post subject: Reply with quote
LOL!! Laughing
I say the same sort of thing to SO many customers.
Obviously we get the parts through at a ridiculous price so selling them on at a smige more than a customer RRP means we still make money on them.
We had one fella who bought a Frontera back box for about ?100 from us.
We just rang PartCo and asked what it would be for walk in trade, And did it for the same price.
Our fitted price was about ?130 IIRC.
And then a few days later he came back wanting the middle section. Again, Reduced it to the RRP from Part Co, Which was about ?80. Our fitted price was little over ?100.
NOW, If he'd just come in with the car in the first place. And said "Whats the best price you could do me on an exhaust for this Fully fitted?"
I'd of probably done it for around the ?180/?200 mark anyway. And then it would of come guaranteed too! Laughing
Not to mention I can have it up in the air, Gas Axe the old system off, And have a new system fitted in under half an hour.
Beats laying on your back on your drive way, Squinting so you dont get rust in your eyes etc.
I've been there and done it, back in the day when I had my old Mini's. Laughing
dansrockin
PostPosted: 12:20 - 04 Feb 2010    Post subject: Reply with quote
ive got a peugeot 206 gti180 that i had the same problem with last week. the bit of the mid pipe that goes up over the rear suspension was looking like swiss cheese and making a noise like thunder! the back box was also ballsed up with the heat shield skin being half ripped off from having hit something on the road.
the quote from pug was just under ?800!!! for a mid pipe and back box. i went to several exhaust places and they all said they couldnt get the parts for this car. on ebay there are a few places selling stainless steel exhausts for around ?350-400, but a freind from work had a go and managed to cut out the shit from the pipe and make and weld plates over it, and also reskin the back box for the mighty sum of ?15!! it looks like new, is gas tight all over, has replaced all the lost power and saved me a fortune!
it might go again somewhere else but im getting rid of the car in march to be a full time biker so as long as it last til then im not bothered!!! lol
dan
There is a gap of 248 days between these two posts...
ZanderJay This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
Blue_SV650S
PostPosted: 10:21 - 11 Oct 2010    Post subject: Reply with quote
Give it a go ... I always figure 'gotta be worth a try' Smile
Here is my latest arc-magic ...
https://www2.bikechatforums.com/viewtopic.php?t=202880
I have also repaired minimoto expansion chambers (split down the join). Again, not pretty, but it works ... just make sure you have some thin rods.
Blue_SV650S
PostPosted: 14:52 - 11 Oct 2010    Post subject: Reply with quote
CHR15 wrote:
10 months on im pretty sure he's fixed it
Didn't notice OP date Embarassed
kawakid
PostPosted: 23:48 - 11 Oct 2010    Post subject: Reply with quote
Some people (i.e. me) try and do as much themselves as they do not trust the garage profession from previous experience, they fear for their car/bike. Also the vast non mechanically minded public o not know if they are being ripped off or not. My friend moved from Halifax to Manchester 15 years ago, he still comes back to Halifax even taking a day off work to have his car serviced and repaired. (He does not trust any garages near to him).
There's also a bigger mark up on things than you say. My local garage wanted £100 for a wishbone fitted. They cost £28 at the local parts place (The ones that supply garages)
I've a twin and a 4.
binge
Emo Kiddy
PostPosted: 00:55 - 14 Oct 2010    Post subject: Reply with quote
Suspension work comes under mechanical in our place. Parts are a LOT cheaper to buy direct from the supplier.
Exhausts however, dont differ much from buying a box from PartCo / SC's / Euro Car Parts, or having one fitted through a fast fit center at a discounted rate.
As for the trust side of it, it's fully understandable. I deal with a lot of unsure customers who've had previous bad experiences in other garages.
The last post was made 15 years, 323 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 105.15 Kb
