| Bambam3 |
 Bambam3 Renault 5 Driver
 Posted: 11:10 - 07 Jun 2010 Post subject: What is this part? :/ |
Hi guys, recently removed the back tyre for the first time in order to get a puncture fixed at a shop.
All went quite well, except when I removed the thing from the side of the tyre/bike, on the opposite side of the sprocket.. a little thing fell out as I carried it into the garage with all the other bits.
It's a Honda XR125.
I've circled the main thing I think it fell off as I carried it away from the bike:
https://img143.imageshack.us/img143/6296/wtf2d.jpg
And here's a crude drawing of the part. It's pretty small, a few cm long/wide with a hole through the middle, cylindrical a bit. :
https://img717.imageshack.us/img717/6509/whatisits.jpg
I don't have pics as it's at a friends (closest to me at time of puncture). Going to pick up tyre now shortly so hopefully someone will clue me in before I get sorted and mess this up.
Cheers in advance.  |
| Raffles |
 Raffles World Chat Champion
| el_oso |
 el_oso World Chat Champion
| Dazbo666 |
 Dazbo666 World Chat Champion
| Grimnir |
 Grimnir Trackday Trickster
| Bambam3 |
| stinkwheel |
| Bambam3 |
 Posted: 12:55 - 07 Jun 2010 Post subject: |
Brilliant, cheers guys.  |
| Grimnir |
 Posted: 13:29 - 07 Jun 2010 Post subject: |
A far more informative pic! |
| yen_powell |
 yen_powell World Chat Champion
 Posted: 13:32 - 07 Jun 2010 Post subject: |
Isn't trunnion a most delightful word!
I must try and think of reasons to drop it into casual conversation. ____________________ Blackmail is a nasty word........but not as nasty as phlegm!
XT1200Z and a DR350 in bits |
| Dazbo666 |
 Posted: 13:58 - 07 Jun 2010 Post subject: |
Stinkwheel to the rescue. I recognised the part, but had no idea of the specific name  ____________________ 1st bike (Sept'06 - May'10) : 1991 GPZ500S / Current bike (since Nov 2009) : 2003 Suzuki Bandit 600N
Word of the day : DILLIGAF |
| Alexio |
 Alexio World Chat Champion
| Bambam3 |
 Posted: 17:54 - 07 Jun 2010 Post subject: |
That it was, big thanks guys.
Managed to put the wheel back on and rode home without killing myself. Accomplishment +1. |
| Pete. |
 Pete. Super Spammer
 Posted: 20:46 - 07 Jun 2010 Post subject: |
You should have had either one odd-shaped nut or a pair of normal nuts on the brake rod that went through that trunnion. Since you didn't recognise it I'll run you through the adjustment process that I use.
If you had one special trunnion nut with a larger hex and a half-round cutout that fitted against the trunnion, then you lift the rear wheel off the ground and wind the trunnion nut over and over the 'lumps' until you feel the wheel binding as you turn it by hand AFTER it has hit, then back off the trunnion nut until there is no drag at all. Finally test the system by turning the wheel with one hand and repeatedly pressing the footbrake with the other to make sure it runs freely when it releases each time.
If you had two normal nuts then wind the first one on whilst turning the wheel by hand. When you feel it starting to bind back off the nut two turns and check the wheel's not binding. Now run the second nut up to the first and lock them together to stop them loosening off. Now check the wheel for brake binding again. ____________________ a.k.a 'Geri'
The last post was made 16 years, 93 days ago. Instead of replying here, would creating a new thread be more useful? |
