| abiteachuck |
 abiteachuck L Plate Warrior
| Paddy Blake |
 Paddy Blake World Chat Champion
 Posted: 22:33 - 16 Jun 2010 Post subject: |
I am not sure but I think there should be a wire from the points to a condenser then from there to the HT coil.
Is there a condenser in where the points are.  |
| abiteachuck |
| Paddy Blake |
| stinkwheel |
 Posted: 23:24 - 16 Jun 2010 Post subject: |
Scorched/burned points are a symptom of a duff condenser.
It would have to be totally mangled to give a dead short though. Even if it was, you should still have enough resistance in the primary windings to prevent a fuse popping. The coil might get pretty hot though.
I suspect you have a short circuit™* in the wiring leading from the points to the ignition coil or an internal short in the primary windings of the ignition coil.
A duff/disconnected zennor could also lead to fuses blowing (due to excess voltage) but only when the engine is running.
I did a wee sketch of an ultra basic points iginition system (not included ignition switch and fuse).
* "Short circuit" is a trade mark of the LUCAS Electrical Company. Patent No: 1562329A6 ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Odie |
 Odie World Chat Champion
| abiteachuck |
| abiteachuck |
The last post was made 15 years, 337 days ago. Instead of replying here, would creating a new thread be more useful? |
