Rough tickover on honda cb600
leep
PostPosted: 20:49 - 26 Sep 2011    Post subject: Rough tickover on honda cb600 Reply with quote
Hi,
I have a problem with my honda cb600 hornet 2001 3700miles
On tickover it sound like it's running on 3 cyclinders with choke on its fine and when riding it's fine,
New battery, plugs fitted and i have given the carbs a quick clean but did not remove slow running pilots i suspect #1 carb because when started from cold all headers warm up exept this one? any advice please. thanks
Quornholio This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
PostPosted: 20:59 - 26 Sep 2011    Post subject: Reply with quote
Blocked carb, or duff plug.
Slacker24seve...
PostPosted: 22:55 - 26 Sep 2011    Post subject: Reply with quote
As Ham says, check the sparks and swap the suspect plug. If not, Hornet carbs are a doddle to split and clean properly Wink
Send me your email address if you haven't got the workshop manual and I'll fire one over Wink
Banger rallies are ace
leep
PostPosted: 05:12 - 27 Sep 2011    Post subject: Reply with quote
It was the same with the old plugs in they had only done less than a 1000miles but with standing over last winter and running it up every few months i thought it may have fouled then up, but they looked perfect but i had already got new one's so i've put them in. so i will pull the carbs tonight after work hopefully, thanks for the advice i will report how i get on. thanks
leep
PostPosted: 22:04 - 27 Sep 2011    Post subject: Reply with quote
Hi, just pulled carbs off removed #1 pilot and it looks clean i could see light through it ? soaked it in some carb cleaner and blew it out with the airline and the jet inner did seem larger after.
when the fuel goes through this pilot jet does it come out the small hole on the engine side of the butterfly is this right?
Can i spray carb cleaner in the place where the pilot screws in and blow with the airline?
Because i can see this jet was not completely blocked could this still cause my rough idle?
thanks
leep
PostPosted: 21:53 - 28 Sep 2011    Post subject: Reply with quote
Carbs cleaned and back on but still not smooth on tick over sound like it intermittently runs on 3 maybe slightly better, Have not checked plugs yet but they are brand new NGK irdiums,
is there any thing else to check? i've just rebalanced the carbs.
The last post was made 14 years, 360 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.52 - MySQL Queries: 16 - Page Size: 50.76 Kb
