| MIKEY B |
 MIKEY B Crazy Courier
| Cheza |
 Cheza Nitrous Nuisance
 Posted: 17:13 - 29 Dec 2003 Post subject: |
You should be able to order one from a dealer with the chassis number i think. Might cost you though! ____________________ Pink Rhino Rider  |
| Demonic69 |
 Demonic69 The Pink Rhino
| MIKEY B |
| Demonic69 |
| MIKEY B |
| Demonic69 |
| Dusty |
 Dusty King of the Rim
 Posted: 17:31 - 29 Dec 2003 Post subject: |
As far as I know it'll probably be a fair bit cheaper to get a new ignition than to get a key from the manufacturer, they tend to charge ridiculous prices because they can.
The only drawback as you say, is that it's unlikely to fit your rear seat lock, although I would assume the seat lock is not as sophisticated as the ignition? You might be lucky. I used to be able to take my DT's seat off with a screwdriver.  ____________________ Gallery |
| MIKEY B |
| TiN |
 TiN Pocket Tin
 Posted: 19:33 - 29 Dec 2003 Post subject: |
I dunno if Suzukis are the same, but the key number was stamped on the ignition barrel on my Blade. You'd have to remove the ignition barrel, and it should be stamped near the steering lock pin (if there is a number).
It's about £12.50 for a set of 2 keys, and it's a lot less hassle than getting a new set of locks. Failing that, you might be able to get a key cut from the ignition barrel itself. ____________________ TiN
dotgems.net |
The last post was made 22 years, 259 days ago. Instead of replying here, would creating a new thread be more useful? |
