£6 Carb Balancer
PostPosted: 14:31 - 10 Apr 2011    Post subject: £6 Carb Balancer Reply with quote
Clicky
Running beautifully now. Less vibey, more low down grunt.
https://i15.photobucket.com/albums/a376/ms51ves3/DSCF3308.jpg
https://i15.photobucket.com/albums/a376/ms51ves3/DSCF3310.jpg
m0l0t0v
PostPosted: 18:55 - 19 Apr 2011    Post subject: Reply with quote
Would be more helpful if there was a link Wink
PostPosted: 19:51 - 19 Apr 2011    Post subject: Reply with quote
Where's it gone? Shifty
m0l0t0v
PostPosted: 20:17 - 19 Apr 2011    Post subject: Reply with quote
Back to it's rightful place Wink
cb1rocket
PostPosted: 21:17 - 04 May 2011    Post subject: Reply with quote
i'm at a loss of how this has been set up.
Am I right in saying its a continous piece of tubing with parts of it fill with oil and the ends attached to the vacumm nipples?
2 litre
PostPosted: 23:18 - 04 May 2011    Post subject: Reply with quote
Yes.
PostPosted: 23:53 - 04 May 2011    Post subject: Reply with quote
Strangely enough, I've just bought 5M (£2.50) of air tubing to do just this at the weekend. Using ATF is easier to read as it's red Thumbs Up
PostPosted: 18:16 - 05 May 2011    Post subject: Reply with quote
Didn't have any, and this was an old bottle of 2 stroke oil that's never going to get used. Yes it is 2 stroke oil, even though it's golden and not red/blue/green.
PostPosted: 18:38 - 05 May 2011    Post subject: Reply with quote
Did you find you had to pinch the tube at all to stop fluctuations, or was it fairly smooth to read untouched?
PostPosted: 12:17 - 07 May 2011    Post subject: Reply with quote
No pinches Thumbs Up Just the tube in a 'U' is all I used.
PostPosted: 17:31 - 10 May 2011    Post subject: Reply with quote
How did you get on, Shaggy?
PostPosted: 18:05 - 10 May 2011    Post subject: Reply with quote
I found that carb #2 on a CB500 requires a spigot adaptor to put the tube on. Which I don't have Sad
https://dz99.fw.hu/carb_synch_CB500.pdf
I'm just wondering now if a brake caliper bleed nipple might fit...
PostPosted: 19:36 - 10 May 2011    Post subject: Reply with quote
That sucks a bit Neutral
herulach
PostPosted: 20:00 - 27 Sep 2011    Post subject: Reply with quote
I'd forgotten about this, will save me some cash for a carbtune. What ID does the hose need?
YBR 125>FZS600
sickpup
Old Timer
PostPosted: 20:37 - 27 Sep 2011    Post subject: Reply with quote
No but the thingy from a Scottoiler would.
2wheelsteve
PostPosted: 22:11 - 27 Sep 2011    Post subject: Reply with quote
Magic Smagic Very Happy
Ride Safe
PostPosted: 18:41 - 29 Sep 2011    Post subject: Reply with quote
Finally Smile
https://www.bikechatforums.com/files/manometer2.jpg
For next time :-
1. Use a longer bit of wood.
2. Or less fluid.
3. Put it on the floor, not on the bike. Otherwise when you overadjust, the fluid goes over the top bend and heads to your carb. Meaning you kill the engine, and have to wait to get the fluid back in the loop again. Meaning the carbs will run out of fuel restarting it. Again.
The last post was made 14 years, 350 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 97.58 Kb
