| Author |
| grahamd1 |
 grahamd1 Trackday Trickster
 Posted: 13:27 - 19 Nov 2011 Post subject: Loooong project CD175 |
I took my test (too many years ago) on my trusty cd175, so I have hankered to find another, but the cost of them is silly on fleabay, then I came across this wreck for not a lot, and well, just had to have it (even the wife nagged me to get it, as she remembers my old one well). and voila one 1972 CD175 that has spent the last 20+ years in the back os someones shed. I drove 140miles this morning to collect it, and its amazing what you can squeeze into the back of a Picasso
https://i314.photobucket.com/albums/ll431/grahamdrry/CD175/ebayp2.jpg
https://i314.photobucket.com/albums/ll431/grahamdrry/CD175/IMAG0276.jpg ____________________ XV1100, XV750
CD175 (Rebuild)
CF70 (Chaly - Rebuild), |
| Back to top |
| grahamd1 |
 Posted: 15:05 - 20 Nov 2011 Post subject: |
Wahay, got the engine out, however do have a problem with the carb, more on that later.
https://i314.photobucket.com/albums/ll431/grahamdrry/IMAG0285-1.jpg
Took the top off the carb so I could pull out the throttle slide so that I could take the engine out complete with carb BUT, the damn slide is stuck solid (crud fuel!!!) and wont budge, with the throttle cable stuck in situ. So I took the carb off to enable me to get the engine out, but I'm buggered if I can get the cable or slide out of the carb, I've soaked it in penetrating oil and paraffin, but so far no go, and I dont want to damage it, suggestions ? ____________________ XV1100, XV750
CD175 (Rebuild)
| Back to top |
| hadden |
 hadden Trackday Trickster
| Back to top |
| virus |
 virus World Chat Champion
| Back to top |
| pepperami |
 pepperami Super Spammer
| Back to top |
| grahamd1 |
 Posted: 17:38 - 21 Nov 2011 Post subject: |
In the end I took some cutters to the throttle cable (having checked I could still get a replacement), and that allowed me to bring the carb into the house for examination. Took the top off and wiggled the inner throttle cable till it came clear of the slide, then again sprayed and soaked the carb in brake cleaner/wd40/penetrating oil. Went back a few hour later, and nope still not moving, so I tool the rear fly screen (a small mesh over the air intake), and could just see the bottom of the slide, so using a small bit of wood wedge shaped, I kept pushing and working it in, till it moved a little bit, then more spray, more wedging, untill it came out. What was holding it was cruddy sediments of old fuel, almost like tar. Tonight I'm going to strip it right down, and give it a soak in the ultrasonic bath.
I've also removed the handlebars (not sure if they are saveable), and the front headlamp cowl with the speedo. Just tried a drill in the speedo and that works fine, BUT its discoloured over the years of neglect so I'd like to strip the speedo down and give that a clean. But its made of metal and although I can get the screws out of the back (talk about rusty), its clear that disasembly requires the guts to come through the glass front aperture, and from what I can see the glass is held in by the front chrome (ISH) bezel, formed over a lip around the speedo. So removing the glass so I can get at the guts is gonna be a bugger.
Whilst playing yesterday, I discovered it had a cheapo tin horn fitted, rather than the original oem part (I loved the sound of the original), but luckilly I found someone selling an original, so its on order. Also no iginition switch (hard wired), so again found someone with an original one with braket and original Honda keys. the helmet lock and steering lock keys are also missing, but they look servicable. I did a search on the net and if I send my helmet lock to a specialist they will cut a key to match (steering and helmet lock are the same key), for about £12. ____________________ XV1100, XV750
CD175 (Rebuild)
| Back to top |
| grahamd1 |
| Back to top |
| CHR15 |
 CHR15 Turbo nutter bastard
 Posted: 20:13 - 21 Nov 2011 Post subject: |
if your rebuilding the engine, might as well get it soda blasted. it ill bring it back to factory finish. ____________________ Turbocharged drag thing / project death weapon / GK73A
Ste: I'm not entirely sure how you'd go about verbally abusing someone with a potato but I'm sure it's possible. |
| Back to top |
| grahamd1 |
| Back to top |
| grahamd1 |
 Posted: 12:26 - 23 Nov 2011 Post subject: |
Currently stripping down the carb, YUK the bottom was 1/2" of dried crud, tried brake cleaner and crappy carb cleaner from Halfrauds and nothing seemed to touch it, so I brushed it out with the dremel (copper wire brush). Again brake cleaner and carb cleaner wouldn't touch the stains left, so I called in on my local car garage, and got a tin of this, its the bees knees, first blast does nothing, second blast and the stain starts running, a quick wipe with a cloth, and another blast and it looks clean. I'm going to soda blast (from an article on here) the outside once I've repaired my compressor.
This was the stuff I got (£2 a tin,,, bargin)
https://i314.photobucket.com/albums/ll431/grahamdrry/CD175/IMAG0293.jpg ____________________ XV1100, XV750
CD175 (Rebuild)
| Back to top |
| grahamd1 |
 Posted: 20:22 - 23 Nov 2011 Post subject: |
Tonight I managed to remove the swinging arm, and I'm a happy bunny its in great shape, and so is the bottom of the frame, even the bolt came out easy, and the barings look ok, no slop, just as well.
Took the front forks off the frame, rubbed them down with wire wool and oil, and they also have come up nice, but I want to strip them down to replace the fork seals, BUT I cant remove the chrome lower fork covers (manual says they are screwed on), the haynes manual talks of a "Special" honda tool "Peg Spanner" being required, fat chance after all these years. They suggest an alternative is a strap of chain? Tried using a leather belt, nothings moving, reluctant to use a chain in case I further destroy the remaining chrome.
Anyone ? ____________________ XV1100, XV750
CD175 (Rebuild)
| Back to top |
| grahamd1 |
 Posted: 13:48 - 24 Nov 2011 Post subject: |
This morning I took the forks to a local engineering company, and we tried all manor of clamps (oil filter, canvas webbing, chains), and NOTHING budged, out of deperation we cut some steel tube and drilled two holes with two 10mm bolts screwed in that fitted into the pre-cut slots (used by honda with their peg spanner), and ?
NOTHING, even 3 of us pushing and twisting (they fit like a bayonet, 1/4" turn then pull off), no way were they shifting. Took a micro camera and inserted it into the stanchions to have a look at the fork seals, and they are in great shape, so worse case I aint gonna change them
Got the swinging arm out of the frame last night, and I think where the enclosed chainguard has been removed sometime in the past, that has saved the old gal, by spraying chain oil over the frame and swinging arm. ____________________ XV1100, XV750
CD175 (Rebuild)
| Back to top |
| LongJohn22 |
 LongJohn22 Trackday Trickster
| Back to top |
| grahamd1 |
| Back to top |
| deleted111 |
 deleted111 World Chat Champion
| Back to top |
| grahamd1 |
| Back to top |
| grahamd1 |
 Posted: 19:49 - 26 Nov 2011 Post subject: |
| Back to top |
| herulach |
 herulach World Chat Champion
| Back to top |
| LongJohn22 |
| Back to top |
| grahamd1 |
 Posted: 17:07 - 27 Nov 2011 Post subject: |
Wahay, frame now naked, ran a wirebrush (on my battery drill) over the frame to check for any holes or problems, and shes good to go. So first coat of paint stripper has been applied, and rubbed off, second coat will be applied tomorrow.
https://i314.photobucket.com/albums/ll431/grahamdrry/CD175/IMAG0320.jpg ____________________ XV1100, XV750
CD175 (Rebuild)
| Back to top |
| grahamd1 |
| Back to top |
| grahamd1 |
 Posted: 17:17 - 27 Nov 2011 Post subject: |
| Back to top |
| grahamd1 |
 Posted: 16:52 - 29 Nov 2011 Post subject: |
Frame is almost stripped of paint, I'm amazed at the condition for a 40 year old Jap bike
So far 2ltrs of nitromors, and two copper wire brush attachments for the drill, worn down to the hub.
I also took the rear tyre off the rear wheel, NIGHTMARE, the rubber seems to have gone rock hard, took me over an hour with 3 tyre leavers (by the way Poundland has motorbike tyre leavers at the moment £1 each), damn tyre fought me every inch. I think the rim is a no,no I see Davis Silver has new rims, but doesnt mention spokes, also some time back someone mentioned somewhere that did wheels and offers a rebuild service ? Anyone ? ____________________ XV1100, XV750
CD175 (Rebuild)
| Back to top |
| Damon |
 Damon World Chat Champion
 Posted: 08:24 - 30 Nov 2011 Post subject: |
I'm liking this build very much. Keep up the good work
Gonna be great hearing it start up again after all these years! Are you going to replace the bearings in the engine? or just oil it and see?
Thanks,
Damon |
| Back to top |
| grahamd1 |
 Posted: 12:02 - 30 Nov 2011 Post subject: |
| Damon wrote: | I'm liking this build very much. Keep up the good work
Thanks,
Damon |
Gonna strip and rebuild ____________________ XV1100, XV750
CD175 (Rebuild)
| Back to top |
The last post was made 14 years, 353 days ago. Instead of replying here, would creating a new thread be more useful? |
