| samo |
 samo Two Stroke Sniffer
 Posted: 18:48 - 30 Jan 2012 Post subject: bike is slipping or something. |
Hi i got megelli 125m.
I was riding to college and noticed that when i pull the throttle back hard in first 2nd or somethimes higher gears the bike would act like the clutch is engaged partly The rpms would go up but no power to the rear wheel. Its never done it befor. I thought it was the chain but the chain has recently been cleaned and adjusted. It will also do it if your riding along the suddenly open the throttle all the way. Help plz |
| lorus |
 lorus Two Stroke Sniffer
| P. |
 P. Red Rocket
| samo |
 Posted: 18:56 - 30 Jan 2012 Post subject: |
what u mean clutch slip and is that all i got to do maybe. |
| samo |
| lorus |
| Paddy Blake |
 Paddy Blake World Chat Champion
| samo |
| lorus |
 Posted: 19:17 - 30 Jan 2012 Post subject: |
Do it now and test ride before you use it for college.  |
| Pete. |
 Pete. Super Spammer
 Posted: 19:22 - 30 Jan 2012 Post subject: |
Adjust the lever free-play and test ride it. If it's still slipping, come back and I'll tell you how to adjust the actual clutch.
Too many people think that the clutch adjustment is on the lever, but it's not - that's just the cable adjustment. Either might be the fault, but one is very often disregarded. ____________________ a.k.a 'Geri'
| samo |
| samo |
| Skudd |
 Skudd Super Spammer
| samo |
| Skudd |
 Skudd Super Spammer
| samo |
| cb1rocket |
 cb1rocket World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 21:45 - 02 Feb 2012 Post subject: |
Loosening off the cable isn't the same as adjusting the clutch.
Look where the cable goes into the engine. Somewhere near there will be a round cap or cover or rubber bung. Remove it and see underneath - you'll probably find a screw and locknut adjuster. Loosen the locknut and then turn the screw anticlockwise half a turn or so, then re-tighten the locknut. See if that stops it slipping.
The proper way to adjust it is actually to screw out the screw until you feel no weight on it, then screw it in until you fell it touch, then back it off half a turn or so. ____________________ a.k.a 'Geri'
| samo |
| Pete. |
 Pete. Super Spammer
 Posted: 21:05 - 03 Feb 2012 Post subject: |
Did you not look at the pushrod clearance adjuster as I described above, or does it not have one? ____________________ a.k.a 'Geri'
| samo |
| superstacker |
 superstacker Traffic Copper
The last post was made 13 years, 328 days ago. Instead of replying here, would creating a new thread be more useful? |
