| tomh |
 tomh Scooby Slapper
| Hobgoblin |
 Hobgoblin Trackday Trickster
 Posted: 21:07 - 09 Apr 2012 Post subject: |
good work tom!  ____________________ Plodding along on my CG |
| _Iain_ |
 _Iain_ Banned
| tomh |
 tomh Scooby Slapper
 Posted: 16:11 - 10 Apr 2012 Post subject: |
More progress done on the bike today. I've stripped the bike down to the frame leaving just the rear wheel/swingarm and front end attached. I've only just recently refurbished the forks (I'll find the pictures of this later) and I've tided up the wiring in the headlight so I didnt see the need in stripping it.
First job of the day is to fill the centerstand hole with metal epoxy putty. Just need to file it down, redrill the hole and paint it.
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0306.jpg?t=1334072923
No pictures for this part but I've had the engine out and washed the frame with soapy water and a scrubber. Thankfully nearly all the rust on the frame was just surface rust and came straight off. There were a few small patches including the picture in my last post, so I've sanded them down and painted them in hammerite.
Engine and rear mudguard refitted:
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0311.jpg?t=1334073122
I've used a wire brush on the rusted metal plate, painted it with some hammerite and put it back on the bike.
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0312.jpg?t=1334073240
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0313.jpg?t=1334073320
Wiring loom put back in place:
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0314.jpg?t=1334073439
Airbox back in along with the battery:
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0315.jpg?t=1334073586
New indicator relay fitted, it should be a lot nicer riding having my indicators working again.
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0316.jpg?t=1334073534
How it stands now:
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0320.jpg?t=1334074146
Not much left to do now,
- Sort the rear brake pivot out and paint the brake pedal,
- Clean and refit air filter,
- Clean up body panels,
- Clean the rear shocks,
- Refit the chain.
One problem I still need to sort out is my new forks I've fitted, there off a older CG and a slightly diffrent design so when you fully tighten the front wheel spindle it pulls the fork legs in and binds the wheel. If I don't fully tighten the wheel I loose braking power as the drums shoes are not tight in the drum.
My solution to this is to make longer wheel spacers, I've got a spare wheel spacer which I'm going to cut down once I work out what size the spacer needs to be.[/img] |
| tomh |
 tomh Scooby Slapper
| bikertomm |
 bikertomm World Chat Champion
 Posted: 18:10 - 11 Apr 2012 Post subject: |
Nice one mate looking good!
What did you use to clean the engine casing / block?
Mines basically the same and I want to get it looking clean!
 ____________________ 07' Honda Hornet now full powaah! My guide on performing an oil change! |
| tomh |
 tomh Scooby Slapper
 Posted: 18:44 - 11 Apr 2012 Post subject: |
Thanks, my engine is the one bit where I've not really needed to do much to get it looking clean though, the person I got it off repainted the engine cases just before I bought it so all I needed to do is scrub it down with some soapy water to get it looking good again.
You can see it from around when I first got it in the first pic.
Not got much else done today, I've drilled out the pivot hole on the frame and painted it up. The brake pedal is painted in black ready to go back on the bike but I've gone through several drill bits trying to drill out the old split pin on the pivot pin. I need to do get some new drill bits to finish that off. Until then I can't put my rear brake pedal back on.
I've also made a new wheel spacer for my front wheel which would have fit perfect if I hadn't of lost it somewhere I'm not looking forward to trying to take the front wheel off on my own without a center stand though...
Once them two jobs are finished I'm going to get all the body panels back on and get my MOT sorted.
I'm not going to bother repainting the bike as I'm planning on buying a old 250cc+ bike that I can restore as I've really enjoyed stripping this bike down, it will also motivate me to get my test done  |
| pendulum |
 pendulum Traffic Copper
 Posted: 20:53 - 11 Apr 2012 Post subject: |
This is exactly what I want to do with my CG, clean it up a bit and deal with all the surface rust because it looks bad.
A bit scared of painting though as I've hardly done any painting before. Just read this:
Hammerite Paint is specially formulated to be applied directly onto rusty metal with minimal surface preparation.
Is it really that simple? If so I will give it a go pretty soon!
Anyway. Just wanted to say. Your thread is useful.  |
| blurredman |
 blurredman World Chat Champion
 Posted: 22:05 - 11 Apr 2012 Post subject: |
I have a '91 CG.
I did the exact same thing, and my god the rear of the frame (where the back plastic mounts on) was very bad.
All surface rust however and it was still extremely solid. A little hammerite goes a long way!
Good progress! ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 - 40k, 1989 MZ ETZ251 - 52k. |
| deleted111 |
 deleted111 World Chat Champion
 Posted: 10:08 - 12 Apr 2012 Post subject: |
I ditched my centre stand and fitted a sidestand, best thing I've ever done to my CG.
Good work so far!  |
| Tim.. |
 Tim.. World Chat Champion
| Hobgoblin |
| tomh |
 tomh Scooby Slapper
| tomh |
 tomh Scooby Slapper
The last post was made 14 years, 218 days ago. Instead of replying here, would creating a new thread be more useful? |
