synthdemon |
 synthdemon L Plate Warrior
 Posted: 16:35 - 21 May 2004 Post subject: NSR125RN - been stood, won't start |
HELP!!! My beloved bike has been stood for a few months, have charged battery (alternator works). Have changed petrol. Have checked airbox and carb. It's trying, and the pistons move when pushed in first gear.
I need to get this bloody thing sold quick so any help would be appreciated.......
1993 NSR125RN Italian Import (exhaust dead, fork seals dead, chain/sprockets dead) no t or t
(If anyone is interested, the bidder on ebay fell thru) contact me for more info
Ta, Pete ____________________ I didn't steal your fridge man. |
jimbo |
 jimbo Borekit Bruiser
 Posted: 19:17 - 21 May 2004 Post subject: |
0). Is the side-stand up, and is it in neutral and is the engine kill-switch on run?
1). Check for a spark. If no spark could be:
Dirty sparkplug.
Dodgy/corroded kill switch/side-stand switch/clutch switch/ignition switch. Check for obvious corrosion, give them a squirt with WD40 or disconnect them.
Dodgy coil, loose HT lead, loose sparkplug cap.
Dodgy CDI (unlikely if it was working before storage)
2).Check to see if the sparkplug is damp after you've been turning it over for a bit. If not, probably fuel.
Check fuel tap.
Check fuel filter.
Check fuel line.
Check to see if carb float bowl is filling. Make sure the carb bowl is drained of old fuel. If it's full of good fuel, you might have a clogged jet or water in the float bowl. Strip it down, clean it out.
If still no luck, then hard-wire the starter motor to the engine kill switch and sell it as an electric bicycle.  |
synthdemon |
Valentino Mossy |
 Valentino Mossy World Chat Champion
jimbo |
synthdemon |
The last post was made 21 years, 106 days ago. Instead of replying here, would creating a new thread be more useful? |
