Tyre pressures. Oops.
carlosthejack...
PostPosted: 10:01 - 10 Apr 2013    Post subject: Tyre pressures. Oops. Reply with quote
Been back commuting on 2 wheels the past week or so, and noticed that the front end was a bit unresponsive. "Must get the tyre pressures checked", thought I, and dug out the relevant info, 36psi front, 42 rear. Unfortunately, due to work etc, I didn't have time until this morning on this, my only day off in a run of 15 days on. I wasn't wrong. 24 front, 28 rear. No wonder it was handling like it was being ridden through sludge. The run home from the garage was wonderful, even took some twisty detours, just to make sure I wasn't imagining it. What a mahoosive difference.
I will now make a solemn promise, in the presence of the mighty nobcat, that I will forevermore keep on top of my tyre pressures. Ta. Thumbs Up
Sable
PostPosted: 10:06 - 10 Apr 2013    Post subject: Reply with quote
Yikes! I never used to check mine. Did once when the handling was super bad like yourself, pumped them up, and realised what a difference it made. Check the pressure roughly every 2 weeks now ^^ I start noticing it even when a couple of PSI out now.
P.
PostPosted: 10:07 - 10 Apr 2013    Post subject: Reply with quote
Lol J.M's XJ600 was handling a bit badly, sluggish turning etc, checked pressures, 10 in rear and 15 in front Laughing
GrantT
PostPosted: 10:08 - 10 Apr 2013    Post subject: Reply with quote
Try 10psi! When I first passed my test the bike had been sitting for a few months, rode around for a few days with the bike strightening up in corners and all kinds of wierd things, you soon learn!
sidewinder
PostPosted: 12:48 - 10 Apr 2013    Post subject: Reply with quote
try to check mine at least once a week. Very Happy
Why do bikes have such high tire pressures compared to cars ? eg:
Sable
PostPosted: 12:53 - 10 Apr 2013    Post subject: Reply with quote
My Langster bicycle with Armadillo's used to need 80 - 100 psi. Now that took some work with the foot pump! ^^
carlosthejack...
PostPosted: 14:04 - 10 Apr 2013    Post subject: Reply with quote
I tend to have my Ribble at 100psi! Easy enough with a track pump...
Islander
PostPosted: 14:25 - 10 Apr 2013    Post subject: Reply with quote
When I first bought my Hornet I rode it round for a few days and thought the front end was a bit fruity to say the least. So I checked the tyre pressures only to find that the rear was spot on at 42psi but the front was inflated to 46psi instead of 36psi.
That explained that then. Laughing
Sable
PostPosted: 14:32 - 10 Apr 2013    Post subject: Reply with quote
I have a Halfords pump only. Embarassed Too tight for fancy pumps!
Kradmelder
PostPosted: 14:37 - 10 Apr 2013    Post subject: Reply with quote
You forget that time flies and you haven't checked pressures. I was away easter holiday in the cage. before that cant remember when last checked pressures. I got back on the bike and the front end felt heavy.
checked and it was 1.7 bar instead of 2.4. !.7 is for like riding in sand!
2011 KTM 990 Dakar
2009 BMW 1200 GS
snikks
PostPosted: 14:43 - 10 Apr 2013    Post subject: Reply with quote
It'll be to do with the contact patch being smaller vs the weight it has to carry would be my guess - hence why racing bicycles with their tremendously thin tyres often have pressures of 100psi+.
- CBT: 02/01/11 Theory: 26/04/11 Mod 1: 19/05/11 Mod 2: 19/08/11
- 2007 Honda XL125V Varadero (Sold), 1999 Yamaha FZS600 Fazer (Sold), 2001 CBR600F
Easter Bunny
PostPosted: 15:32 - 10 Apr 2013    Post subject: Reply with quote
Interesting, how do you normally check the pressures?
If I'm in a hurry I rely on the garage gauge to be accurate if its at home I use the old style pen gauge
How accurate are the digital gauges the old ones weren't so
Sable
PostPosted: 15:36 - 10 Apr 2013    Post subject: Reply with quote
the new ones ain’t so either.
Easter Bunny
PostPosted: 16:00 - 10 Apr 2013    Post subject: Reply with quote
I've never double checked them tbh
Sako
PostPosted: 21:44 - 10 Apr 2013    Post subject: Reply with quote
Have to say I check mine every week.
covent.gardens
World Clap Champion
PostPosted: 22:23 - 10 Apr 2013    Post subject: Reply with quote
I check mine every couple of months and they always need doing when I do.
I'm terrible
Caught the oil at just below minimum mark on the last check too Rolling Eyes
soforene This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
PostPosted: 22:40 - 10 Apr 2013    Post subject: Reply with quote
Mine are always at the wrong pressure and I make sure they're kept that way. The pain of having a bike that sometimes takes a pillion. Neutral
Same goes for the suspension.
Good enough reason to get another bike with one seat and set how I like it. Smile
Timmeh
PostPosted: 10:30 - 11 Apr 2013    Post subject: Reply with quote
I managed to ride my CBR from Lincoln to Derby having unwittingly picked up a slow puncture.
It started to feel really wierd towards the end, so I got it home and discovered I had just 6psi in the rear.
How the fuck it managed to stay on the bead is beyond me.
Gotta hand it to the 2CTs, still didn't let me down.
UrbanRacer
PostPosted: 10:32 - 11 Apr 2013    Post subject: Reply with quote
I didn't check mine once before a trackday, the heat i put into the tyres caused the pressure to jump up to 50psi.
Then this happened
https://urbanracing.net/bike/bmw/4.jpg
Kradmelder
PostPosted: 10:34 - 11 Apr 2013    Post subject: Reply with quote
Then this happened
not sure if that is worse than this. but the leg action is similar.
2011 KTM 990 Dakar
2009 BMW 1200 GS
Acemastr
PostPosted: 10:35 - 11 Apr 2013    Post subject: Reply with quote
My car is 34psi Front, 44psi Rear Smile
2016 Toyota Tacoma Limited
Timmeh
PostPosted: 10:36 - 11 Apr 2013    Post subject: Reply with quote
UrbanRacer wrote:
Then this happened
Doing it like a pro. I presume you let go at some point?
Alpha-9
PostPosted: 10:40 - 11 Apr 2013    Post subject: Reply with quote
Didn't check my YBR pressures for months, finally did it and it was miles out, the front was like 40 and the back was like 21 or something
Was retarded Laughing
Fzr-600 1999
UrbanRacer
PostPosted: 11:25 - 11 Apr 2013    Post subject: Reply with quote
Timmeh wrote:
UrbanRacer wrote:
Then this happened
yep, I hung onto to it for a few meters but i was making the situation worse, The bike started to turn which could have then flipped and i could have ended up properly hurt.
I walked away from that unhurt and the crash bungs protected all of the expensive bits.
The last post was made 12 years, 294 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.83 - MySQL Queries: 14 - Page Size: 127.6 Kb
