| J.M. |
 J.M. World Chat Champion
 Posted: 20:22 - 10 Jun 2013 Post subject: Snap! |
Don't you just hate it when this happens...
https://i.imgur.com/vO0Uq6U.jpg
Removed 7 successfully. 6 removed just the nuts. 1 removed the stud with the nut firmly attached. One snapped the stud.
What would be your preferred method to get this out? I will be attempting it tomorrow evening, probably around 6 or 7pm as to give it some extra soaking time.
At least now I can give the exhaust a good going over to get it all Chromed up and new looking. Will also get it properly welded up as to get rid of my bodgetastic repair that I did.
Edit: also how would you best clean up the remaining studs? Wire brush? Tap and die set? ____________________ 2004 R1 & 2018 XSR900 |
| Clutchy |
 Clutchy World Chat Champion
 Posted: 20:44 - 10 Jun 2013 Post subject: |
Thats pretty shitty, really feel for you, hopefully some heat and mole grips will get em out, if not weld a nut onto it? ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
Guide to pass your test with no lessons! |
| cb1rocket |
 cb1rocket World Chat Champion
 Posted: 21:54 - 10 Jun 2013 Post subject: |
get 2 nuts on there if u can and impact wrench it out, otherwise as above said, weld a nut and get it off. Mole grips will just chew up the stud further! ____________________ Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852 |
| MattEMulsion |
 MattEMulsion World Chat Champion
| J.M. |
| Islander |
 Islander World Chat Champion
 Posted: 22:25 - 10 Jun 2013 Post subject: |
Soak the bugger with repeated applications of proper penetrating oil for a couple of days before you attempt anything.  |
| iMark |
 iMark World Chat Champion
 Posted: 22:29 - 10 Jun 2013 Post subject: |
Oil, more oil and even more oil... then try the 2 nuts...
Plenty of WD-40 over night and Mole Grips worked for me but it fucked up the stud pretty bad.. but they got replaced anyway  ____________________ K8 GSXR 1000
"G" : you got him to have a look at a forum which seems to have established a picture of an erect penis in a cat's mouth as it's mascot and thought he might consider it ok? |
| mr.z |
 mr.z World Chat Champion
 Posted: 22:35 - 10 Jun 2013 Post subject: |
Theres a little known products called "freeze & release"
It has a penetrating oil + freezes the thing you are attacking.. worked great the few times i've needed it. ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| J.M. |
| G |
 G The Voice of Reason
| Clutchy |
 Posted: 08:40 - 11 Jun 2013 Post subject: |
Out of interest, now don't shoot me down too hard...
Could you put the exhausts back on with new studs where they have come out, where they haven't could you just put a locktight nut on the stud and tighten up? Or would that not work? ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
| Islander |
 Posted: 09:20 - 11 Jun 2013 Post subject: |
Nylock nuts have nylon inserts and exhausts get pretty hot...  |
| Matt B |
 Matt B World Chat Champion
| J.M. |
| J.M. |
 Posted: 12:27 - 11 Jun 2013 Post subject: |
That's a really interesting piece of kit; I've never seen one of those before! ____________________ 2004 R1 & 2018 XSR900 |
| Matt B |
| stonesie |
 stonesie World Chat Champion
| gavbriggs |
 gavbriggs Crazy Courier
| J.M. |
 Posted: 19:36 - 19 Jun 2013 Post subject: |
I got a phone call from the small local garage at 1pm today (only took the head down this morning), saying that they had tried welding the stud to remove it but were simply unable to do it and I would have to take it to someone more specialised.
https://i.imgur.com/C94Ae6S.jpg
Dropped the head back off in my dad's garage on the way home. As I turned up tonight, I was greeted with this:
https://i.imgur.com/LJrInV3.jpg
Dad's are awesome  ____________________ 2004 R1 & 2018 XSR900 |
| iMark |
 Posted: 20:01 - 19 Jun 2013 Post subject: |
| J.M. |
 Posted: 20:05 - 19 Jun 2013 Post subject: |
Should clarify, I wasn't expecting him to do anything to it. I'm just keeping my bike/bits in there whist I work on it as I have nowhere else safe (from kids or weather) to work on it.
Tomorrow is cleaning up and grabbing 2 new studs. Then it's pretty much on to the reassembly soon! ____________________ 2004 R1 & 2018 XSR900 |
| BTTD |
 BTTD World Chat Champion
| Vincent |
 Vincent Banned
 Posted: 21:53 - 19 Jun 2013 Post subject: |
JM, if you can get them, use deep-domed nuts on the new studs, they help to stop the studs rotting.  ____________________ Space Is Deep |
| J.M. |
| Raffles |
 Raffles World Chat Champion
The last post was made 13 years, 148 days ago. Instead of replying here, would creating a new thread be more useful? |
