| Paris2 |
 Paris2 Nearly there...
 Posted: 19:21 - 30 Jul 2013 Post subject: Beams strong enough? |
How strong are thee beams?
https://i138.photobucket.com/albums/q276/parsalanpark/image-15.jpg
They are obviously supporting the roof of the garage, but Cathay bear much weight themselves. I want to hang a punch bag from them, probably weighing around 40-50kg. Is this a bad idea or should they hold up fine?
Cheeaaaaaaaaars ____________________ Current Ride: Daytona 600 |
| fatpies |
 fatpies World Chat Champion
| metalangel |
 metalangel World Chat Champion
| Al |
 Al World Chat Champion
 Posted: 19:41 - 30 Jul 2013 Post subject: |
I've climbed on those sort of trusses loads of times. I think they'd take the weight but the movement of the bag swinging about might cause an issue.
I'm not sure how strong those metal joins are either?
I'd probably brace the beams overlapping the bit where the joins are with some more wood and then use a fence post or scaffold bar laid across the beams the other way to hang the bag from. ____________________ Yamaha FZR400RR 3tj
My Instagram Thingy |
| Paris2 |
 Posted: 20:33 - 30 Jul 2013 Post subject: |
That's what I'm worried about, the movement of the bag. If it is bashed around too much (which it should be) it may cause problems. Ill see if I can distribute the weight more and add some support in there. I obviously don't want to damage the roof supports, as the roof may come down  ____________________ Current Ride: Daytona 600 |
| Fisty |
 Fisty Super Spammer
 Posted: 21:03 - 30 Jul 2013 Post subject: Re: Beams strong enough? |
Hmmmmm you been chatting to Krad? You sure thats a bag you want to hang? ____________________ Quietly and consistently taking the piss.
Fatter and faster than Fret |
| T0MMY |
 T0MMY World Chat Champion
| Ariel Badger |
 Ariel Badger Super Spammer
| Rogerborg |
 Rogerborg nimbA
| angryjonny |
 angryjonny World Chat Champion
| binge |
 binge Emo Kiddy
| BTTD |
 BTTD World Chat Champion
| swampy |
 swampy World Chat Champion
 Posted: 23:02 - 30 Jul 2013 Post subject: |
You sure its only a punch bag you want to hang from there...
https://www.bikechatforums.com/viewtopic.php?t=276185
 ____________________ "I hate to advocate drugs, alcohol, violence or insanity to anyone, but they've always worked for me." Hunter S Thompson
"Faster, faster, faster, until the thrill of speed overcomes the fear of death..." Hunter S Thompson |
| kestrel |
 kestrel Nearly there...
| Paris2 |
 Posted: 23:20 - 30 Jul 2013 Post subject: |
I'll look into some extra wall support I think, though the beams are pretty strong.
And yes swampy, it's for a punch bag. I no longer have a motorbike in there so am turning the garage into a mini gym. (Though I am super sad about not having a bike anymore ) ____________________ Current Ride: Daytona 600 |
| swampy |
| Paris2 |
 Posted: 23:32 - 30 Jul 2013 Post subject: |
Gone. Had to sell as I now need a car for work and can't afford both. I'll hopefully be back on two wheels next year, even if it is another cheap old Suzuki  ____________________ Current Ride: Daytona 600 |
| stinkwheel |
 Posted: 00:57 - 31 Jul 2013 Post subject: |
Structurally speaking. It would be best to hang it off the ridge beam, then it's all in compression, even if swinging.
This would probably result in altogether too much swing though. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| mistergixer |
 mistergixer World Chat Champion
 Posted: 04:06 - 31 Jul 2013 Post subject: |
Personally I'd go with a bracket bolted into the wall, bag won't swing as much either.
 ____________________ Space Monkey #7
Mistergixer's videos on YouTube |
| cb1rocket |
 cb1rocket World Chat Champion
| Im-a-Ridah |
 Im-a-Ridah World Chat Champion
| pits |
 pits World Chat Champion
 Posted: 11:52 - 31 Jul 2013 Post subject: |
I think your best option would be to get a heavy duty metal plate with a ring welded into the centre of it, then fix it to the beam with some long M5 bolts  ____________________ Stinkwheel: You have no right to free speech
00:33:00 Blau Zedong: the CB400 is my favourite road bike |
| BTTD |
| map |
 map Mr Calendar
 Posted: 16:15 - 31 Jul 2013 Post subject: |
| Sload |
 Sload World Chat Champion
The last post was made 12 years, 251 days ago. Instead of replying here, would creating a new thread be more useful? |
