Car Related: Damaged Engine
janner_10
PostPosted: 15:10 - 12 Nov 2013    Post subject: Car Related: Damaged Engine Reply with quote
So a guy at work has a Kia Sportage - 3 years ol and 63k miles.
Driving home the other night and the oil light comes on then the engine cuts out. Pulls over and tries to start it, which it did but sounds rough so stops and calls the AA.
Long story short - AA man didn't like the symptoms so towed to his local KIA dealer.
Its still under its 7 year warranty and after inspection, the garage has said it looks like the wrong type of oil was used at servicing - which isn't true - he has used the low ash diesel stuff.
Anyway, have a gander at the pic of the sump when they dropped it. Any thoughts?
https://i42.tinypic.com/hwfznn.jpg
PostPosted: 15:18 - 12 Nov 2013    Post subject: Reply with quote
I think there is probably some particulate contamination in the oil there that the filter might have missed.
Best get him to strain it through an old pair of tights to check for any fine metal particles. I think he might have chipped one of the piston skirts a bit.
Formerly known as
P.
Oil change, start her up.
oldpink
PostPosted: 15:20 - 12 Nov 2013    Post subject: Re: Car Related: Damaged Engine Reply with quote
janner_10 wrote:
Any thoughts?
yeah its pretty f***d think he needs a new Engine Thumbs Up
m3-paul
PostPosted: 15:43 - 12 Nov 2013    Post subject: Reply with quote
Bit of JB Weld and whack it through a parts washer will see it right.
On the other hand, Shocked . I haven't seen an engine that trashed for a very long time. Hard to believe what the Kia technician is saying. Trying to get of a big warranty claim?
Yamaha TZR250 - love the smell of TTS!!!!
CBR900RR Fireblade - so much fun
janner_10
PostPosted: 16:05 - 12 Nov 2013    Post subject: Reply with quote
Spot on - they are trying to wriggle out of it - he has had it serviced by an independant mechanic but with Kia parts purchased through the dealer themselves.
He has brought the proper oil for each service too. Has us stumped as to what has caused it.
Formerly known as
P.
PostPosted: 16:16 - 12 Nov 2013    Post subject: Reply with quote
I run el boggo standard gash oil in the Varadero, the oil has no particles or swarf in there upon change time and it works 100 times harder than that car.
Head to higher people in Kia Thumbs Up
JonB
Afraid of Mileage
PostPosted: 16:45 - 12 Nov 2013    Post subject: Reply with quote
On the Civic forum I frequent a lot of people have said the 7 year Kia warranty isn't what it's cracked up to be and you have to read the small print very carefully.
I think on the whole Iridium spark plugs and a powerband would have prevented that tbh.
DrDonnyBrago
PostPosted: 17:35 - 12 Nov 2013    Post subject: Reply with quote
I will be interested to see to what lengths they will go to avoid paying out. I did think that a 7 year warranty on cheap car seemed a bit good to be true.
Nemo
PostPosted: 18:04 - 12 Nov 2013    Post subject: Reply with quote
How can they tell the wrong oil was used just at looking at it?
We had this with a guy recently, yamaha recommend yamalube but he used castrol. Our argument was that all oil is governed by api and they're all to the same standard. He fought it and won.
Also, surely that much damage can't be caused just through oil?! If it is then... daaaaayam
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
J4mes
PostPosted: 18:45 - 12 Nov 2013    Post subject: Reply with quote
As long as the oil used meets or exceeds what they recommend then I can't see them wriggling out of it on that score.
It's properly lunched though Shocked
PostPosted: 19:28 - 12 Nov 2013    Post subject: Reply with quote
I would love to see what has been destroyed in the engine to leave that mess. There is a complete gear wheel in that mess Laughing . Oil pump drive maybe?
Neighbour had a couple of Kia Sortento 4x4 things. Did about 200k miles between them. Not sure how many engine they went through but at least 2 complete engines and a major top end rebuild. Doesn't really give you any confidence.
janner_10
PostPosted: 20:07 - 12 Nov 2013    Post subject: Reply with quote
We thought it the remains of the oil pump also - the saga is ongoing with Kia currently as the dealer has sent the photos off to them.
New engine job either way though.
sabian92
PostPosted: 20:33 - 12 Nov 2013    Post subject: Reply with quote
If they moan and wiggle just quote the Sale of Goods Act and say it wasn't fit for purpose.
That engine is fucked. Laughing
MartQ
PostPosted: 20:37 - 12 Nov 2013    Post subject: Reply with quote
Should be ok if it's put back together, just use some cheap oil and add half a jar of marmite. Fuel consumption will also be massively improved and emissions virtually negated and as a bonus a 750% increase in engine power.
Failing that I would not give up having a go at the dealership.
If they are claiming that the wrong oil was used, it is up to them to prove it via laboratory tests which will probably be just as expensive as sorting the problem in the first place.
andym
PostPosted: 20:38 - 12 Nov 2013    Post subject: Reply with quote
Isn't that a couple of piston rings on top of the pile?
MattEMulsion
PostPosted: 21:36 - 12 Nov 2013    Post subject: Re: Car Related: Damaged Engine Reply with quote
Oil pressure light??? Was there actually any oil left in it or had he run it dry?
Yamaha YZF-R6
PostPosted: 21:37 - 12 Nov 2013    Post subject: Reply with quote
Not sure, as one looks bent and a ring would just snap.
FirebladeRuss
PostPosted: 22:21 - 12 Nov 2013    Post subject: Reply with quote
That's proper fucked.
Twitter is for people who can't STFU even when they're by themselves
Derivative
PostPosted: 02:17 - 13 Nov 2013    Post subject: Reply with quote
Will it blend?
https://1.bp.blogspot.com/-bzFqJmqgkTM/UChvEkWwKuI/AAAAAAAAA1c/Dwa1kMxo-uI/s1600/yes_logo.png
janner_10
PostPosted: 05:28 - 13 Nov 2013    Post subject: Re: Car Related: Damaged Engine Reply with quote
Oil was full on dipstick when the AA man dipped it - which leads us to think it may be the oil pump that has failed.
PostPosted: 13:10 - 13 Nov 2013    Post subject: Re: Car Related: Damaged Engine Reply with quote
Understatement of the year. Laughing
Bubbs
PostPosted: 14:50 - 13 Nov 2013    Post subject: Re: Car Related: Damaged Engine Reply with quote
It looks like you've been panning for gold in a river right outside a breakers yard.
gavcarter
PostPosted: 15:10 - 13 Nov 2013    Post subject: Reply with quote
Using dynamite to drop a sump is sometimes not a good an idea as it first sounds........
piazza
PostPosted: 16:14 - 13 Nov 2013    Post subject: Reply with quote
It looks like instant gasket has been used for a sump gasket, cheap mechanic or is that what they gave your guy for a service item?
The last post was made 12 years, 110 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 127.9 Kb
