Bike alarm
stranger12
PostPosted: 22:54 - 02 Apr 2014    Post subject: Bike alarm Reply with quote
Hi all,
Now that i have two relatively expensive bikes and they look shiny i am paranoid about someone nicking them .
I have bought an extra disc lock with alarm( already have two and they are nit cheap, one £60 xena 14mm and one £25 oxford) third one is £30 xena 6mm.
Also have almax 3 on one bike and cheap oxford chsin on the other .
Still a bit worried overnight and have put a walki talkie in there with vac enabled .
I think I should install alarm for both bikes. I have seen some on ebay for £30 which have a fob and 110 speaker. Is it worth doing ? Can they cause any electrical issues etc?
SV650 Red
R6 Red
stranger12
PostPosted: 22:55 - 02 Apr 2014    Post subject: Reply with quote
Just to add, i am not relying on the alarm to stop nicking them but rather deterrent which can also alert me as my flat is very close to where the bike is located
Maybe i could use below as i am rather after the sound so something like below would do but wanted to know if any one has an experience of using them
https://www.ebay.co.uk/itm/Motorcycle-Alarm-System-Easy-Fit-Motorbike-ATV-Quad-Scooter-/161120759301?pt=UK_Motorcycle_Parts&hash=item25838bae05
I am not sure if the ones which are wired to the ignition provide better security
SV650 Red
R6 Red
Doovy
PostPosted: 23:00 - 02 Apr 2014    Post subject: Reply with quote
What used to be generally known as the Cyclone alarm.
I've got one. Very good. Simple and straightforward, to the battery. Arms via fob and is very loud. I can unlock/lock mine from my third floor flat and hear it arm itself in my garage down at ground level Thumbs Up
PostPosted: 23:01 - 02 Apr 2014    Post subject: Reply with quote
Chain both together using the Almax.
Fit alarm to one of them, one of the Cyclone V2's will be fine. Moving one will set the alarm off.
stranger12
PostPosted: 23:08 - 02 Apr 2014    Post subject: Reply with quote
I was actually thinking of that as i am not using an anchor point but rather those u shaped stands which you can cut through it or undo the bolts but if both bikes are chained together it will be very difficult to cut the chain and the can't move both bikes together
SV650 Red
R6 Red
stranger12
PostPosted: 23:12 - 02 Apr 2014    Post subject: Reply with quote
Is it a particular brand or any cheap Chinese would do the job? There are some on ebay for £20 and datatool. For £70 but think i am just paying for its name rather than quality.
SV650 Red
R6 Red
Doovy
PostPosted: 23:22 - 02 Apr 2014    Post subject: Reply with quote
The link I gave you. Those are the ones that most people recommend. Rebranded from Cyclone. Search for 'Cyclone alarm' on here for reviews.
Get that. It's a motion detecting loud alarm that goes straight to battery. No ignition wiring. Simple.
stranger12
PostPosted: 23:26 - 02 Apr 2014    Post subject: Reply with quote
Vert cheap i shall just get it to test.
Also found it on ebay
https://www.ebay.co.uk/itm/EASY-FIT-Only-Two-Wires-Motorcycle-Bike-Scooter-Trike-Alarm-DIY-Installation-/330972216301?pt=UK_Motorcycle_Parts&hash=item4d0f7b3bed
Much appreciate your help. I bought two, one ncs and one hawk for both bikes
By the way one of my bikes will get sorned, will it drain battery if the bike is not used lets say withi 1 month or so?
SV650 Red
R6 Red
-Matt-
PostPosted: 01:34 - 03 Apr 2014    Post subject: Reply with quote
Cyclones are good - particularly with a disc lock alarm already - and generally, i'd be much more worried about having no anchor point. Alarmed or not if its easy to cut whatever its chained to it could be in a van very quickly Sad mammoth double bridged anchors are decent and only cost 30-40 quid.
PostPosted: 02:14 - 03 Apr 2014    Post subject: Reply with quote
I had nothing but problems with the Cyclone V2 alarm I fitted. It would randomly go off outside certain houses on the way home from work whilst riding. As you can imagine the alarm shrieking as the bike went past with indicators flashing at 2am is not something I appreciated let alone the owners of the houses.
After a few shitty emails from and to Cyclone they sent out another fob to reprogram it and it did not fix the issue. They ignored my last few emails and the alarm was ripped out of my bike and given away.
One of the last letters from them included the now immortal line in my memory. "We are not responsible for outside interference effecting the alarm."
The reply went along the lines of "Neither am I and you have sold me a product that is not fit for use."
The Disapproving Brit
PostPosted: 08:34 - 03 Apr 2014    Post subject: Reply with quote
+1 for the Cyclone/NCS alarms. I've had one on every bike I've owned, and they've always managed to include a wiring diagram that works for it. For the price they're too cheap not to get.
Current Bikes: 1983 Honda VF400FD / 2003 Honda VT750 Shadow
Bike Test Passed 18/03/09, Car Test Passed 14/05/13
stranger12
PostPosted: 11:48 - 03 Apr 2014    Post subject: Reply with quote
well below are the picture of what I used to tie the chain around. They are hollow and have two bolt/nuts on each leg to secure it to the floor.
https://i60.tinypic.com/34pi1pf.jpg
2
https://i57.tinypic.com/hrzrzl.jpg
are anchor points easy to install? do i need drilling etc ?
I am thinking of getting one from Almax which is around £50 but seems very expensive .
if the anchor point is going to be screwed in they i guess the thief can just unscrew it and no need for cutting .
I may be missing something hence why am I asking .
SV650 Red
R6 Red
mudcow007
PostPosted: 12:15 - 03 Apr 2014    Post subject: Reply with quote
pretty sure anchor points, are "normally" drilled into the floor then ball bearings are hammered into the head of the bolt so they cant be undone
like dis
-Matt-
PostPosted: 12:19 - 03 Apr 2014    Post subject: Reply with quote
Do you own the property - if its somewhere you own/staying longterm you may be able to ask permission to concrete something like this in. These are the most secure as theres litearlly nothing to attack besides the chain itself - you simply dig a hole, whack some gravel in the bottom to help drainage and then fill it with concrete and plonk the 'Y' inside. You can get non-branded anchors like this for very cheap maybe 10-20 quid.
https://50.6.224.4/images/new-copy-trans.gif
https://yanchor.com/images/ground%20anchor%20300.JPG
If thats not an option you're looking at about 30-40 quid minimum for a decent retail one. They're near impossible to remove [get permission if you're renting before installing it]. They use raul-bolts placed into drilled holes [I use resin inside the holes too personally to additionally reinforce it]. Then you hammer small ball-bearings into the heads of the bolts so they can't be unscrewed [again - I squirt a load of resin over the bolts on top of the bearing to further block it off].
https://www.demon-tweeks.co.uk/oncirrus/3/images/product/enlarge/pjb_red-alert-anch.jpg
GhostRider
PostPosted: 12:52 - 03 Apr 2014    Post subject: Reply with quote
Could always get one of these as an additional measure:
https://www.ebay.co.uk/itm/Car-Vehicle-Children-Personal-GPS-Tracker-GPS-GSM-GPRS-Realtime-TK102B-Magnet-/161060205514?pt=UK_In_Car_Technology&hash=item257fefb3ca&clk_rvr_id=613695142058
Using one on mine, and the GPS is very very accurate.
On standby (no fence enabled) the battery lasts about a week and a half for me. Now you can wire it up to your lighting system, for example, so it charges only when the bike is on. I wouldn't recommend hooking up directly to the battery, as it'll flatten the battery (as happened to me earlier this week!!). But in any case, you can either remove the unit to charge it, or as said wire it up so it charges in a non-detrimental way.
Should it even got pinched you simply ring the sim card in the unit, 30 seconds later you get a text message with google map co-ordinates showing where it is.
Might not work so well if the bike is stored indoors somewhere, but better than nothing imo.
GhostRider
bugeye_bob
PostPosted: 13:24 - 03 Apr 2014    Post subject: Reply with quote
https://www.ebay.co.uk/itm/261429861789?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
these are very small and easy to stow away.
PostPosted: 13:45 - 03 Apr 2014    Post subject: Reply with quote
GhostRider wrote:
Now this I like the look of. I may have to invest.
GhostRider
PostPosted: 13:52 - 03 Apr 2014    Post subject: Reply with quote
TheDisapprovingBrit wrote:
For £25 you can't argue really, compared to a "proper" device that will cost ~£300 to purchase + installation fee + £100 annual subscription for the service.
I use that in conjunction with a cheap alarm (not cyclone but very similar), almax chain and Xena alarmed disc lock. Can't really do much more than that apart from ground anchor.
GhostRider
map
Mr Calendar
PostPosted: 14:03 - 03 Apr 2014    Post subject: Reply with quote
GhostRider
...but based on this thread is it any good?
Ghostrider wrote:
The tracker had died completely...I stuck it into the USB charger, checked at lunch time and it was at 50% so figured everything was going ok, till 5pm came around...
Genuine question as I was interested in the same unit.
GhostRider
PostPosted: 14:21 - 03 Apr 2014    Post subject: Reply with quote
To clarify, when I say the tracker had died completely, I meant the battery was fulled drained, after a week and a half on standby, where every other day I would call the device to monitor the battery life (it gives battery % along with the GPS co-ords).
So my check at lunchtime showed the battery at 50% i.e it was charging ok. My bike battery hadn't faired so well - but again I don't know how old the bike battery is so might not be the best example of what to expect.
In any case, a wiring mod to rig up to the lighting system , followed by a check of what is going back to the battery at revs, should clear up any doubt as to whether its a good idea to charge in situ or reside to sticking it in a charger at home every 1.5 weeks (the pain in the arseness of this will depend on placement of the device naturally).
GhostRider
Ribenapigeon
PostPosted: 16:30 - 03 Apr 2014    Post subject: Reply with quote
slap a gps tracker in. Theyre cheap enough and you can get permanently wired ones or ones that run on a battery.
I bought one of those cheap as chips chinese alarms off amazon. I dodnt get it for my bike as I already have a shmorgasboard of defences on it but just to experiment with. It works just fine but it didnt come with any wiring instructions. It was just a black box and a sounder with about a dozen wires which I had to test one by one with a multi meter until I worked out which was which.
woo
PostPosted: 18:00 - 03 Apr 2014    Post subject: Reply with quote
or if you can afford it get a real tracker from www.tracker.co.uk
Elen sila lummen omentielvo!
stranger12
PostPosted: 20:27 - 03 Apr 2014    Post subject: Reply with quote
bugeye_bob wrote:
Does this particular one work without a sim card? It doesn't mention anything about sim card and says built in gsm
SV650 Red
R6 Red
raesewell
PostPosted: 20:34 - 03 Apr 2014    Post subject: Reply with quote
The problem with trackers is that they only tell you where the bike is after it's been nicked. Best not to get it nicked in the first place
Yamaha FJR 1300 Normanton West Yorkshire
GhostRider
PostPosted: 20:41 - 03 Apr 2014    Post subject: Reply with quote
Hence the prior advice regarding almax chains, ground anchors, cyclone alarms and disc locks.
BUT should the worst happen, you want another trick up your sleeve - I believe if I'd had one in my GSXR I'd have stood a good chance of getting it back, or at least getting the cunts who robbed it arrested/knuckle dusted their jaw off when I went round their house.
Dayum, £500 on the nose? The other problem is that if it does get taken, there's every chance they'll set fire to the bastard, meaning an additional £350 down the drain, as opposed to £25 from a cheapy unit. Obviously the more expensive one had more advantages, but you gotta weigh up all the pros and cons really.
GhostRider
The last post was made 12 years, 158 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 138.13 Kb
