| mic |
 mic Brolly Dolly
| gdj444 |
 gdj444 Borekit Bruiser
 Posted: 20:21 - 03 Apr 2014 Post subject: |
Could be carb diaphragms, common problem with these engines. From memory there are two (?) a small side one part number 270026, and a bigger one with a spring which I think was part number 391681.
Worked in a lawn mower parts dept for 10 years and obviously still have some memory filled up with what is now useless information
May be completely wrong though, am sure a mechanic will be along shortly to prove the ex parts monkey an idiot
Jonesy |
| smegballs |
 smegballs World Chat Champion
 Posted: 20:22 - 03 Apr 2014 Post subject: |
Good chance it is the fuel pump diaphragm in the carb. The rubber goes floppy with age and hence doesn't do much pumping.
Good news is that they cost less than a fiver delivered from ebay!
I replaced one on a rotavator last summer, bloody thing would very occasionally fire for a few seconds but that was it. New diaphragm and it fire up and ran lovely.
If this engine is old enough to have points, I'd strongly recommend replacing the diaphragm as a matter of course, they are dirt cheap, and it is something quick and simple to rule out when trying to diagnose intermittent problems. |
| Pete. |
 Pete. Super Spammer
 Posted: 20:37 - 03 Apr 2014 Post subject: |
I don't know about the horizontal shaft engines but every vertical shaft non-starter I ever had was tight valve clearances. Fixed in a few minutes by filing the pushrods down a bit. ____________________ a.k.a 'Geri'
| Snodvan |
 Snodvan Spanner Monkey
| doggone |
 doggone World Chat Champion
 Posted: 20:50 - 03 Apr 2014 Post subject: |
| mic |
 mic Brolly Dolly
| Raffles |
 Raffles World Chat Champion
| mic |
 mic Brolly Dolly
 Posted: 14:32 - 05 Apr 2014 Post subject: |
New spark plug £2.99 and it starts first time and does a great job thanks for the advice and whatnot ____________________ zzr600 |
| stevo as b4 |
| mic |
 mic Brolly Dolly
| Snodvan |
 Posted: 17:00 - 05 Apr 2014 Post subject: |
Ah, same machine as I have. I have not used it for a few years but it is stored in a nice dry garage and I am sure would be ok if I needed it.
When I bought it I also bought the wheelbarrow kit ie Take off the digging tines and replace them with a pair of big tread wheels. A wheelbarrow scoop then fits on top of the platform and - behold, a powered wheelbarrow. I shifted a lot of stuff in mine over the years. I still have the wheels and barrow scoop but have not used it for ages. Some of the "bits" that attach the scoop to the machine are missing - but given a need I could improvise. However, much of the need has gone as I gave up my allotment around 2004.
Snod ____________________ 04 (UK Reg) BMW F650cs, but really 02 first Reg in Holland |
The last post was made 12 years, 228 days ago. Instead of replying here, would creating a new thread be more useful? |
