| Author |
| wots |
 wots World Chat Champion
 Posted: 08:42 - 13 Jun 2014 Post subject: 250 Wet Dream |
This came up 0.5 mile from where I work. It'd been into the local rip off garage, charged 12 hours (reduced to 5), to tell him new CDI. Bought brand new CDI and brand new coil, but it didn't run. Listed as such on the ad, spent about £600 and gave up. I went over with a spare battery, and it fired up almost first go. Lumpy, as the carbs were gummed up. But it ran. Picked it up in a 4x4 and brought it home. £200 lighter. Still taxed until the end of the month, MOT expired. Needs a new rear tyre (cracked) and some bulbs for MOT. Everything else is tip-top, apart from some surface rust on the mudguard and rotten under the seat (the seat itself, not frame) it's near perfect. 7,900 miles on the clock and the condition suggests it's genuine. These are a love/hate bike, but a classic in this condition ('82 vintage) and at this price, awesome. Plan is, clean it up and get it running right. Then use it.
https://i1312.photobucket.com/albums/t525/wotsthestory/CB250N/10447530_10152476876576944_276492949820028866_n_zps50787cb8.jpg~original
https://i1312.photobucket.com/albums/t525/wotsthestory/CB250N/LiftHome_zpsd64bdc39.jpg~original ____________________ Currently: Yamaha DT 125 LC2,Repsol Fireblade, and Bumblebee MSX 125 |
| Back to top |
| pepperami |
 pepperami Super Spammer
 Posted: 13:00 - 13 Jun 2014 Post subject: |
I`m in the luv `em camp
Mine
https://i158.photobucket.com/albums/t87/pepperami_photos/IMG_1685_zps9f9a26db.jpg
I`v got a newish? set of forks, wheels, yokes, handlebars ready to go on mine all with new seals & bearings.
I need a little bit of work done on the engine (rebore and pistons &rings) but I`ve run out of money at the moment.
Hoping to have it all sorted before the end of the summer. ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
| Back to top |
| hmmmnz |
 hmmmnz Super Spammer
| Back to top |
| -Monty- |
 -Monty- World Chat Champion
| Back to top |
| wots |
| Back to top |
| _Iain_ |
 _Iain_ Banned
| Back to top |
| wots |
| Back to top |
| stevo as b4 |
 Posted: 20:33 - 13 Jun 2014 Post subject: |
I like it a bit too! It's a bit of 80's Honda mini Eurostyle lets pretend CB900F, which IMO is a good dream to have!
Oh and who on here found that nice old CB1100F in an old lady's shed type situation, and what became of it? |
| Back to top |
| Ed Case |
 Ed Case World Chat Champion
| Back to top |
| Shaft |
 Shaft World Chat Champion
| Back to top |
| wots |
| Back to top |
| djrikki |
 djrikki Brolly Dolly
| Back to top |
| wots |
| Back to top |
| chickenstrip |
 chickenstrip Super Spammer
 Posted: 21:38 - 13 Jun 2014 Post subject: |
Nice price, and always kinda liked their looks. But I think your plan falls apart where you say "then use it" IMO of course  |
| Back to top |
| wots |
| Back to top |
| Shaft |
 Posted: 22:03 - 13 Jun 2014 Post subject: |
| wotsthestory wrote: | As usual, bang on. Did a check, and only flag was has had a colour change. No idea what it was though.
There should be a VIN plate somewhere on the frame (can I see it just below the reflector on the downtube?) with a paint code on it, which would be easy enough to translate, I've a got list of paint codes somewhere.
The popular colour for a repaint was Candy Bourgogne Red, which faded like mad and didn't like petrol, they tended to go silver on the top of the tank, where the petrol vapour took the pigment out of the lacquer and revealed the base coat underneath (Tanzanite Blue did that as well).
Pay careful attention to those carbs, I think I had mine apart and ultrasonic cleaned two or three times, before I got it running right and not puking fuel out of the overflows.
I particularly advise paying a little bit more and using genuine rebuild kits, not pattern stuff, which isn't much cheaper and uses wildly inferior materials, especially the float bowl seals. ____________________ Things get better with age; I'm close to being magnificent........
| Back to top |
| wots |
| Back to top |
| Shaft |
 Posted: 22:20 - 13 Jun 2014 Post subject: |
This lot are the usual go to for Honda spares
https://www.davidsilverspares.co.uk/
When I took mine apart, it was obvious they had never been touched and I could've reused the original seals, but decided to go for some cheap rebuild kits instead; when I had to take them to bits again a couple of days later, the new seals were so swollen, they were almost unusable.
I don't remember the springs being especially strong on mine, but I don't think it's a part that's known for wearing out. ____________________ Things get better with age; I'm close to being magnificent........
| Back to top |
| wots |
| Back to top |
| wots |
 Posted: 12:55 - 14 Jun 2014 Post subject: |
Took it in for MOT, which it failed, but I knew it would. BUT it failed on the two things I had predicted, rear tyre cracked and side lights fail. Which it turns out looks like the ignition switch as they work in the 'park' position but not when ignition on. Ignition doesn't always cut the engine when turned off (though ignition goes off), so I'll whip it out and try and clean it, replacement is about £15. As soon as tyre is here it'll be back to have that done and a test pass!  ____________________ Currently: Yamaha DT 125 LC2,Repsol Fireblade, and Bumblebee MSX 125 |
| Back to top |
| stinkwheel |
| Back to top |
| Doovy |
 Doovy World Chat Champion
| Back to top |
| wots |
 Posted: 17:18 - 14 Jun 2014 Post subject: |
Air filter was incorrectly fitted (from what I can tell), it tucks all the way in allowing the intake to go down at the back of the air box. This wasn't happening. I've now changed this. I can get to rev past 4K when you've got it to about 7K, you can ride along almost up to the redline. Slipping the clutch in out to maintain the revs
I'll have another look tomorrow, it is progressively running better, however getting stuck in the middle of a carnival on the way back was fun. Police everywhere and I'm on a bike with no MOT and I had an Advisory marked as Dangerous on the fail sheet because of the cracked tyre. You've gotta laugh.
EDIT: Did a mileage check against old MOT's, appears genuine, it has had a couple of lay ups. Also, for about the last 4 years there has been an advisory for the rear tyre! It's totally knackered now though. ____________________ Currently: Yamaha DT 125 LC2,Repsol Fireblade, and Bumblebee MSX 125 |
| Back to top |
| wots |
 Posted: 17:09 - 17 Jun 2014 Post subject: |
| Back to top |
| P.addy |
 P.addy Red Rocket
 Posted: 17:13 - 17 Jun 2014 Post subject: |
Looks like my toilet... what on earth  |
| Back to top |
The last post was made 12 years, 107 days ago. Instead of replying here, would creating a new thread be more useful? |
