NSR 125 Piston sizes
Rncv
PostPosted: 20:43 - 24 Aug 2014    Post subject: NSR 125 Piston sizes Reply with quote
Hi,
Currently rebuilding a Honda NSR 125 for my cousin. I've got the engine apart here and I'm looking to order a new piston.
I've read different stories in different places about what size piston ect ect.
There are 5 different pistons to choose from, A B C D & E.
This corresponds to a letter stamped on the barrel. I guess that the barrel I have is a D type by what is stamped below the exhaust port?
https://i61.tinypic.com/10xr1o1.jpg
If this is the case, when ordering pistons through wemoto they only offer a 54mm and oversized ones which doesn't correspond with the 53.961mm for a D type Rolling Eyes
Any help would be much appreciated! Thumbs Up
Current: 01' Bandit 600, 92' Goose 350
Previous: Lots!
PostPosted: 20:59 - 24 Aug 2014    Post subject: Reply with quote
The piston sizes Honda list are for accurate clearance. Wemoto are listing over size pistons (which is a bit strange as the NSR has a plated bore so cannot be rebored, unless modified with a steel liner fitted). All the sizes Honda list are equivalent to the standard piston size (ie, aftermarket they are not caring about the exact clearance).
Rncv
PostPosted: 21:08 - 24 Aug 2014    Post subject: Reply with quote
Thanks for the reply,
Would a piston from wemoto suffice? even though its 0.04mm bigger or would it be better of to get a piston from honda?
Cheers.
Previous: Lots!
PostPosted: 21:48 - 24 Aug 2014    Post subject: Reply with quote
Not sure what size it is. Seems to be just listed as standard without saying which standard.
The min size of an E piston (smallest) from Honda is 53.956 and the max size of an A piston is 53.980. So the that range is 0.024mm
alains
PostPosted: 10:01 - 26 Aug 2014    Post subject: Reply with quote
go to https://www.davidsilverspares.co.uk
they have all you need to rebuild your top-end
piston D ref : 13104 KY4 901 (~£40)
i've got all spares refs , if you need it send me a pm
with it you need : rings,piston pin,clips,small end bearing,oil seal(valves shaft),base cylinder seal,head gasket
The last post was made 11 years, 273 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 3.72 - MySQL Queries: 14 - Page Size: 46.18 Kb
