| DRZ4Hunned |
 DRZ4Hunned World Chat Champion
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 11:59 - 10 May 2015 Post subject: |
10w40 is 10w40 if you believe in the mighty EU.
Mineral oils leave sediments in the engine.
Synthetic oils are the way to go, no sediments of it in the engine.
Car oils have friction modifiers, can/will make your clutch slip. When you run a dry clutch, it does not matter of course.
Motorcycle oils have no friction modifiers.
All the race spec nonsense on the bottle is just pure marketing, it is still a 10w40 no matter who or how at what race has won the GP.
Castrol oils might be the most counterfeited oils on the market.
I run Motul 5100 Ester, I don't know why or what the Ester does there, but I use it for 5 years now and every single engine I filled up with it works. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| DRZ4Hunned |
| Ben90 |
 Ben90 Brolly Dolly
 Posted: 12:37 - 10 May 2015 Post subject: |
Cheap for a litre, but litre bottles are a huge rip-off to begin with.
I buy Rock Oil Guardian 10w40 in 4l bottles for £17. If you're really not fussy then supermarket stuff is even cheaper (as above watch out for modifiers)
Add a few oil filters and that's a years worth of changes on a 125cc workhorse.
I did pick up the mini compressor from Aldi today. The quality is decent, it works well and has the screw-type valve fitting rather than those lever ones which break immediately. Well worth £10.  ____________________ Yamaha FZ6 S2 |
| Kickstart |
 Kickstart The Oracle
 Posted: 12:49 - 10 May 2015 Post subject: |
Almost certainly fine. Loads of people have used Castrol GTX with zero problems with the clutch (but GTX Magnatec regularly does cause problems). I routinely use car oils in bikes with no clutch problems (bike specific oil is a relatively new idea, and virtually no manufacturer bothered to specify bike specific oil until about 15 years ago).
Advantage of the synthetic oils is mainly that they last longer before they degrade. But on most bikes (and certainly a small air cooled engine) you are likely to be changing the oil to get rid of the contamination long before the oil has actually degraded.
That said, £5 for a litre of basic oil is not cheap.
K ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
| Pol Anorl |
 Pol Anorl Banned
 Posted: 12:50 - 10 May 2015 Post subject: |
nope wouldn't touch it again, i have the worst clutch slip ever so now its gonna cost me twice as much just to get propper bike oil. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
20:30:37 Pyro.: I don't sort of like men, I take every advantage to choke on dick.
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges |
| kramdra |
 kramdra World Chat Champion
| RhynoCZ |
| kramdra |
| Val |
 Val World Chat Champion
 Posted: 14:39 - 10 May 2015 Post subject: Re: Castrol 10w40 oil |
| kramdra wrote: | No, the engine is designed for and expects 10w40. Changing the thickness will not increase temperature stability, probably makes it worse. Also does not reduce oil consumption with dodgy rings (Ive tried).
Fully synthetic does not cook, that is its main advantage along with extended service intervals. It should be used with turbos, air cooled and high revving bike engines. Almost everything else will be happy with mineral, anything that says otherwise is marketing bollocks. |
Agree to disagree here there are big differences, motorcycle 4T oil has special additives:
https://www.lubrizol.com/MCEO/Hardware/Why-Not-PCEO.html
Are seriously suggesting that you will risk your engine for £3 pounds saving?
Just get good ester synt oil ok:
https://www.opieoils.co.uk/p-785-silkolene-comp-4-10w-40-xp-synthetic-ester-based-4-stroke-engine-oil-for-high-performance-motorcycles.aspx ____________________ Adrian Monk: Unless I'm wrong, which, you know, I'm not...
Yamaha Fazer FZS 600, MT09, XSR 900 |
| DRZ4Hunned |
 Posted: 14:52 - 10 May 2015 Post subject: |
I'll give this one a miss and get some fully synthetic then, always thought 4 stroke 125's were more robust but clearly not.  ____________________ DRZ400-SM
FZS600 |
| LongJohn22 |
 LongJohn22 Trackday Trickster
 Posted: 20:41 - 10 May 2015 Post subject: Re: Castrol 10w40 oil |
I'm super sceptical about articles promoting a particular type of product written by a manufacturer of such a product. Motorcycles are not the only vehicles that utilize the same oil in the engine with the gearbox, think of the original Mini. In my view, put a picture of a motorcycle on the front of an oil container and it immediately doubles the price. Just avoid the oils that contain friction modifiers. |
| temeluchus |
| weasley |
 weasley World Chat Champion
| LongJohn22 |
| stinkwheel |
 Posted: 17:57 - 11 May 2015 Post subject: |
Years of using it with nothing blowing up, sticking together that wasn't supposed to stick, slipping that wasn't supposed to slip or wearing out tells me castrol GTX is fine in motorcycle engines.
I have a 70k mile GPZ500 engine which did the last 62k miles on GTX. It's had a rebore and two head gaskets but the cams are is superb condition and the cams are what would get it if the oil was sub-standard. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 11 years, 161 days ago. Instead of replying here, would creating a new thread be more useful? |
