Chemical paint strippers that work?
andym
PostPosted: 06:24 - 15 Sep 2015    Post subject: Chemical paint strippers that work? Reply with quote
Bike related question, but figured it belonged more in RB.
Since it seems the VFR is going to be off the road for a bit I figured I'd start doing all the work I planned to do over 2 years ago... 1 of the jobs is getting several layers of paint off the wheels.
I know Nitromors was shit a few years ago (have they improved it any yet?), also a couple of other strippers I've used have had worse results on gloss paint (ended up buying a heat gun for the doors).
So is there any paint strippers that actually work these days? If so anyone got any links please
MCN. This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 07:32 - 15 Sep 2015    Post subject: Reply with quote
The active chemical removed from Nitromors is dichloromethane.
https://www.youtube.com/watch?v=B58GSXZg-d4
eBay can provide. You'll die, every kitten within 10 miles will explode, etc.
PostPosted: 16:56 - 15 Sep 2015    Post subject: Reply with quote
Paramose.
Basically old-school nitromorse. Slap it on, make a cup of tea, hose it and the paint off.
Only supplied for commercial use... in 5litre cans on ebay. You need to send a letter confirming it's for commercial use before they'll dispatch.
We have a can at work for "ahem" cleaning grafitti off the the building. Absolutely not for stripping the paint off my motorcycle parts. No sir.
PostPosted: 17:09 - 15 Sep 2015    Post subject: Reply with quote
Be careful with the contact time not an issue on steel but the caustic solution will etch aluminmiminmum (not sure if Mag Alloy will also suffer).
Any marks 'you add' would need to be rubbed out that's all.
Gloves and Glasses and long sleeves and wash hands thoroughly BEFORE going to the toilet. Embarassed
It will loosen one layer at a time normally.
cyberglass
PostPosted: 17:44 - 15 Sep 2015    Post subject: Reply with quote
Can i just add dichloromethane back into my nitromores to get the same results as paramos ?
DL650 Vstrom 2004
DRZ400S 2003
Yamaha R1 2005
PostPosted: 18:04 - 15 Sep 2015    Post subject: Reply with quote
No, you are not allowed to. Police Police Police Police Police Very Happy
cyberglass
PostPosted: 18:12 - 15 Sep 2015    Post subject: Reply with quote
hahaha ok i wont be ordering and doing this then Wink
DL650 Vstrom 2004
DRZ400S 2003
Yamaha R1 2005
PostPosted: 20:36 - 15 Sep 2015    Post subject: Reply with quote
Remember the correct gloves.
I wear nitrile for the duration of the job then put on a pair of those big blue PU dipped ones when I'm actually handling the stuff.
Latex does nothing.
andym
PostPosted: 06:29 - 16 Sep 2015    Post subject: Reply with quote
stinkwheel wrote:
Paramose.
You couldn't sell me a litre could you? I have a lot of.... uh graffiti.... on my bike wheels.
Failing that I'll have a look at some of the other stuff on ebay
PostPosted: 08:57 - 16 Sep 2015    Post subject: Reply with quote
How do you package it?
In all hnesty, it's pretty cheap to buy.
You have to fill in a form declaring you're using it for commercial use. As far as I can tell, you having filled in the form ticks the check-box on their obligations if they get audited. I did not get the impression there was going to be a spanish inquisition if you filled it in as "AndyMoto Parts Refurbishment."
PostPosted: 09:46 - 16 Sep 2015    Post subject: Reply with quote
my GF is an industrial chemist, and she blames the EU. The EU removes all of the interesting chemicals from everything. Sad
wr6133
PostPosted: 09:52 - 16 Sep 2015    Post subject: Reply with quote
MarJay wrote:
The EU removes anything interesting from everything. Sad
EFA
weasley
PostPosted: 10:42 - 16 Sep 2015    Post subject: Reply with quote
Me too (an industrial chemist, not your girlfriend). This is why Tippex is now shit (same chemical was removed).
PostPosted: 10:44 - 16 Sep 2015    Post subject: Reply with quote
Derailleur post follows:
I got a 180º Excavator (a JCB) on Demo from work once. The salesman had to make out a invoice to 'MCN Plant Ltd.' to cover the accounts/billing nonsense.
Demonstrators were budgeted as free to prospective clients. But Cat Sales paid for it. I worked there and was owed a favour.
To hire a digger would have cost me £500 or more. Smile I also PDI-ed the beast before I drove it up the road. You know... Full tank of fuel and all fluids checked. Wink
I burst a front tyre too but managed to swap it out with an old scrapper in the yard before I brought it back. Cool
deeds
PostPosted: 17:48 - 16 Sep 2015    Post subject: Reply with quote
It doesn't seem to lift the paint like nitromors once did, it makes it go soft so you can wipe it off with a rag.
Jewlio Iglesias This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 19:00 - 16 Sep 2015    Post subject: Reply with quote
https://www.youtube.com/watch?v=iQtd41JcMGg
Shocked
PostPosted: 20:42 - 16 Sep 2015    Post subject: Reply with quote
Some chap wrote:
starchem
Dichloromethane 90 to 95%
https://www.spraygunsdirect.co.uk/images/starchem-synstryp-paint-stripper-sds.pdf
stinkwheel wrote:
Paramose.
DICHLOROMETHANE 70-90%
PERSONAL PROTECTION
Arrow Self-contained breathing apparatus must be available in case of emergency.
Arrow Impermeable gloves.
Arrow Tightly fitting safety goggles. Ensure eye bath is to hand.
Arrow Impermeable protective clothing
https://www.agwoodcare.co.uk/pdf/P%20and%20V%20pdf.pdf
I did say you'd die. There needs to be a "not being sardonic" emoticon.
Suntan Sid
PostPosted: 20:46 - 04 Nov 2015    Post subject: Reply with quote
I wanted to remove some paint from some engine covers today.
Not wanting to spend hours with wet 'n dry, slowly removing the ends of my fingers, I decided to give some paint stripper a go.
I had some left from when I had used it previously, it hadn't worked very well and had left a lot of paint behind!
This was "Diall" brand "Paint and Varnish Remover".
I'm not going to say where I got this stuff, because, AFAIC, they're a bunch of robbing bastards!
Anyway I put each casing in a washing up bowl and covered both of them in a, thick, layer of goop.  As per the instructions, I waited an hour and recoated both parts with another, thick, layer of goop.
I left the parts for another hour then took a toothbrush to them, as per the instructions, and, believe it or not it actually worked.
I followed the exact same process last May, and, as I said 50% of the paint was still there, this time 99% of the paint had gone.
The only noticeable difference betwen the two processes, AFAICS, is that today it was wet and miserable outside.  The parts were outside all the time but under cover, the paint stripper didn't dry out, at all, today.
Previously, in warmer weather, leaving an hour between coats, the goop had started to dry.
If I need to do this again, in warmer weather, I will be covering the items with a carrier bag during the process and making sure they're in total shade!  I assume, today, that the active chemicals did not, simply, evaporate, like they must have done previously!
HTH
andym
PostPosted: 04:38 - 05 Nov 2015    Post subject: Reply with quote
This is one of the parts I wanted to clean up:
https://img.photobucket.com/albums/v320/andy36586/VFR/DSC_0175_zpszfdwkike.jpg
The dichloromethane on its own was a bit crap, nitromors was worse than crap, but mixed 2:1 it worked quite well (took me 2l to figure that one out).
https://img.photobucket.com/albums/v320/andy36586/VFR/DSC_0176_zpsg4p5rl49.jpg
And with a bit of shit rattle can painting:
https://img.photobucket.com/albums/v320/andy36586/VFR/DSC_0186_zpsvx8l54iy.jpg
https://img.photobucket.com/albums/v320/andy36586/VFR/DSC_0196_zpsxhkidcpx.jpg
Nowhere near a half decent job, but they look a bit better than they did
PostPosted: 14:42 - 05 Nov 2015    Post subject: Reply with quote
Umm. Dichloromethane is probably going to do utterly horriffic things to the structural integrity of that tyre.
Don't use it. Neutral
andym
PostPosted: 19:31 - 05 Nov 2015    Post subject: Reply with quote
Hasn't been near the tyre, the front wheel is going to be more interesting though as the whole thing is painted.... but the tyre needs replaced anyway
Snodvan
PostPosted: 19:48 - 05 Nov 2015    Post subject: Reply with quote
This stuff
https://www.screwfix.com/p/no-nonsense-paint-varnish-stripper-500ml/17091?cm_sp=Search-_-SearchRec-_-Area1&_requestid=241862#_=p
seems like it is the same that Sid describes (B&Q and Screwfix are of course "related"). I bought some today to remove ancient varnish off half a dozen solid brass door handles
QUITE IMPRESSED. Especially for a £5 relative to £41 for 4 litres of Nitromoors. The 1/2 litre size for the Screwfix gloop is also more practical. I spread the stuff over the handles, wrapped it all in ally foil and left it for a couple of hours. Opened up the foil and applied some more for an hour and ------ nice clean handles when I scrubbed all the gloop off. Needed a bit of Brillo pad to get a few final crusty bits off, but generally happy.
Snod
04 (UK Reg) BMW F650cs, but really 02 first Reg in Holland
The last post was made 10 years, 93 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 136.72 Kb
