Indicators taking a good few seconds to engage
supZ
PostPosted: 11:18 - 10 Mar 2016    Post subject: Indicators taking a good few seconds to engage Reply with quote
Haven't had a chance to have a good look at this yet but I was wondering if anyone else has experienced this type of issue.
Got through my MOT on monday fine, I did mention to him the indicators are reacting slowly to the switch which he did agree with but they did work (eventually) so it's still a pass.
Basically, I'll flick the switch and it could take 5+ seconds for the indicators to start working, after which they flash fine but as you can imagine, 5 seconds later I'm most likely already round the corner and up the road so it's not that helpful.
My 1st thought is that the relay is on its way out which presents its own problems as honda, for some stupid reason, integrated it into the instrument cluster so I'm going to have to rewire the loom to bypass it (I've seen various guides on this, shouldn't be a problem but why honda?? why?)
I've ordered a load independant relay and may look to doing some rewiring this weekend.
So yeh, just wondering if anyone else has had the prob and would you think a relay swap fix the issue?
# Bikes a 2003 CBR954 FireBlade
# Indicators are standard bulbs, not LED
# Battery is fine, it's pretty new and kept on my smart charger most of the time. Bike starts and runs on the button every time
CBR954RR - Daily toy
CBR600RR - Trackbike
Minty
PostPosted: 11:29 - 10 Mar 2016    Post subject: Reply with quote
Was same on my 97 Fireblade. Sticky switch cured with silicone spray in the gaps either side of the lever hole. I give at another squirt every MOT.
My fingers smell of your mum.
Matt B
PostPosted: 12:02 - 10 Mar 2016    Post subject: Reply with quote
This.
Or WD40 will do the trick. Blast it in and work the switch back and forth a few times.
supZ
PostPosted: 12:19 - 10 Mar 2016    Post subject: Reply with quote
So you just reckon the contacts need cleaning up?
I should point out it's not like I'm holding the button left or right until it finally kicks in. I literally just flick it as normal and some time later it kicks in. That doesn't sound like a switch problem to me.
The switch isn't 'sticky', moves back and forth fine, cancels fine.
Why would cleaning the switch (not that it's a bad thing to do) help?
Minty
PostPosted: 12:21 - 10 Mar 2016    Post subject: Reply with quote
Mine did not feel sticky but did not respond instantly (a second or so).
It is free and easy. What have you to lose yo?
supZ
PostPosted: 12:26 - 10 Mar 2016    Post subject: Reply with quote
Can't hurt, just don't understand how it would help with my issue but more than happy to be proved wrong. As said, I don't think it's a switch contact issue
High beam switch sticks a bit so I need to 'lube' up the switchgear on that side anyway.
We'll see Smile
Minty
PostPosted: 12:38 - 10 Mar 2016    Post subject: Reply with quote
* results may vary.
My experience of automotive relays has been that they work or they don't. Have never had me a 'slow' relay. Stand to be corrected though. Thumbs Up
Matt B
PostPosted: 14:41 - 10 Mar 2016    Post subject: Reply with quote
Mine was doing exactly the same. Move the switch across, wait a few seconds, indicators blink. A squirt of WD40, some wiggling and pushing sorted it.
Try it or don't but it's a lot quicker and easier than stripping the switchgear apart and cheaper than replacing a relay that's not faulty.
Islander
PostPosted: 15:25 - 10 Mar 2016    Post subject: Reply with quote
As above, push the switch to one side and squirt some contact cleaner into the slot then work the switch. Push the switch to the other side and work it again. Repeat as necessary. Thumbs Up
supZ
PostPosted: 17:29 - 10 Mar 2016    Post subject: Reply with quote
Matt B wrote:
Try it or don't
I'm not rubbishing the idea, and I will def. be cleaning it up and spraying a bit of WD in to try it.
I'm just trying to understand how it could cause my indicators to activate a few seconds after pressing it.
I'm wondering if I'm not explaining myself well enough.
I could understand it if I was having to hold my finger on the switch until it made contact and started working but that's not what I'm doing.
For example, I would flick the switch left or right for barely an instant and walk off. 5+ seconds later, my indicator comes on.
I'm not having to hold my finger on the switch until it activates, I'm touching it, letting go, and then a few seconds later my indicators kick in.
As said, I'm just trying to understand the logic that a bad contact could cause that to happen, if I'm not even pressing the button when they finally activate Question
The reason I'm leaning towards the relay here is its a mechanical function of a bi-metalic strip under load and due to its very nature over time its logical that it could take longer to warm up and activate (very basic description there). That's why I reckon it's a relay issue.
But yeh.. will try the easy stuff first Smile
Matt B
PostPosted: 17:37 - 10 Mar 2016    Post subject: Reply with quote
That's all we are saying, try the easy/free job first. No guarantee it's your problem but it has been known to work. Thumbs Up
Islander
PostPosted: 17:48 - 10 Mar 2016    Post subject: Reply with quote
First you have to understand how flasher relays work. They rely on a heating coil wrapped around a bimetallic strip, when you flick the switch over it passes current through the heating coil to the lamp. That causes the bimetallic strip to heat up and bend, breaking the contact and turning the lamp off. It then cools and the cycle starts over.
If your indicator switch has oxidisation or crud on the contacts, then it won't pass the current needed to make the relay operate properly and that will introduce a delay. Clean the contact and the problem should go away. Use electrical contact cleaner for this as it'll not only shift any contaminants, but also leave a film of lubricant on everything. Thumbs Up
supZ
PostPosted: 17:57 - 10 Mar 2016    Post subject: Reply with quote
That actually makes sense!
Thanks for explaining a bit more guys, I get it now Very Happy
Idea
supZ
PostPosted: 18:01 - 10 Mar 2016    Post subject: Reply with quote
Vincent, yeh that's the one.
Cool cheers, that'll be good to see Smile
Islander
PostPosted: 18:34 - 10 Mar 2016    Post subject: Reply with quote
Where's the picture of the tiny ball bearings and springs pinging out in opposite directions? Laughing Razz
supZ
PostPosted: 22:19 - 10 Mar 2016    Post subject: Reply with quote
That's some awesome information there! Very nice indeed
I had a look at it when I got home from work and well.. mine looks a fair sight better than that one Wink
https://c2.staticflickr.com/2/1594/25054950943_66204e51ce_b.jpg
Ironically, the moment I tried it when it was apart it kicked in immediately. Neutral
I still gave it a bit of a squirt with WD40 on the sides and did the same to my high beam switch which is now moving freely, so that's something.
Put it all back together and it appears to be working fine again.. both annoying and not annoying that there doesn't appear to be anything wrong and it's coming on when expected but I'm not going to look a gift horse in the mouth so I'll see how it goes and if it starts playing up again I'll come back and follow your guide to dismantle it.
Thanks again for that by the way, that could help a lot of people Smile
mauzo
PostPosted: 01:24 - 11 Mar 2016    Post subject: Reply with quote
Vincent wrote:
Use a normal sized phillips/pozidriv screwdriver for the small screws and don't round them off, they can be stuck quite fast.
Presumably they're actually jizz screws, like everything else?
Thanks for that, I need to do mine soonish (and the starter button, which keeps cutting the headlight out).
'04 CG125, '07 CBF500
DrDonnyBrago
PostPosted: 11:57 - 11 Mar 2016    Post subject: Reply with quote
My 2001 CBR6f does that every now and then.
I take the switchgear apart, clean out all the manky grease and reapply the smallest amount I think I can get away with.
That cures it for a few years.
The last post was made 10 years, 232 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.14 - MySQL Queries: 13 - Page Size: 146.89 Kb
