| Betco |
 Betco L Plate Warrior
 Posted: 19:32 - 15 Jun 2016 Post subject: Xtrs issue |
I'm not very good with this writing thing so I have made a video of what the issue is if anyone can help
Thanks Steve
https://youtu.be/GBXDZW211uE |
| charlie74 |
 charlie74 Trackday Trickster
| Betco |
| charlie74 |
 Posted: 20:05 - 15 Jun 2016 Post subject: |
https://www.youtube.com/watch?v=GBXDZW211uE
that's a clean link to your vid
and don't worry about your typing skills, you would be surprised at what we have managed to decipher,
just give us as much info as possible and what tools you have available and folks will do what they can |
| Evil Hans |
 Evil Hans World Chat Champion
| Evil Hans |
| Betco |
| charlie74 |
| Betco |
| charlie74 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 08:39 - 16 Jun 2016 Post subject: |
Tappet gaps are right, but were they done with the engine stone cold?
Although that sounds electrical. It's mis-firing rather than firing poorly.
Coil, or coil and lead? If it's coil and lead then it sounds like you've replaced everything in the ignition circuit, so I'd hazard a guess at a bad connection.
Either the main earth, the CDI plug, or check that the low tension leads on the coil at secure - I had both the latter two issues on my CG125 copy-engine, which produced similar behaviour.
If it's not that, I'd suspect the pickup coil on the stator, but I'd check all the connections first. ____________________ Biking is 1/20th as dangerous as horse riding.
| Snowdonia Rider |
 Snowdonia Rider World Chat Champion
 Posted: 08:57 - 16 Jun 2016 Post subject: |
When a similar problem happened with my bike it ended up being a problem with the spark plug cap not connected to the lead properly. ____________________ I want your clothes, your boots and your motorcycle.
My YouTube channel: https://www.youtube.com/c/SnowdoniaRider |
| Betco |
| Rogerborg |
 Rogerborg nimbA
 Posted: 11:21 - 16 Jun 2016 Post subject: |
Worth a try, it sound like something in the electrical system and you've ruled out pretty much everything else. I had to crimp my spade connectors a bit to get them tight on the (aftermarket, because racebike) coil. ____________________ Biking is 1/20th as dangerous as horse riding.
The last post was made 10 years, 121 days ago. Instead of replying here, would creating a new thread be more useful? |
