| Author |
| Bod |
 Bod Traffic Copper
 Posted: 13:53 - 01 Sep 2004 Post subject: That topic again Counter-Steering |
Hi all was watching a video about this today and I can't get my head round it. If I want to go round a right hand bend, push the left side of the bar? So when you are going round it what do you do next........  |
| Back to top |
| Adam_P |
 Adam_P World Chat Champion
 Posted: 13:55 - 01 Sep 2004 Post subject: |
It probably happes naturally when you ride anyway, but as the bike comes out of the bend you just need to push slightly the other way and it will all come back into line.
The best thing to do... go and find a nice quiet road with some bends and TRY IT.
You'll soon see what it does and how it works. ____________________ Colin McRae MBE 1968 - 2007 RIP
Orwell Rolls in his Grave
God is imaginary |
| Back to top |
| fazed |
 fazed Korn is my hero!
 Posted: 13:56 - 01 Sep 2004 Post subject: |
you do it naturally without realising , Try and actually do it and it could end up nasty  |
| Back to top |
| Bod |
 Bod Traffic Copper
| Back to top |
| sv_cath |
 sv_cath Could Be A Chat Bot
 Posted: 14:13 - 01 Sep 2004 Post subject: Re: That topic again Counter-Steering |
No no no!!!
To go right, you push the right side of the bar away from you, this makes your weight go forward and to the right, therefore leaning the bike to the right.
When you've got round the bend gently just gently move your weight back to a neutral position and you're back in a straight line!
Does that help? |
| Back to top |
| ProXimaCore |
 ProXimaCore Dougal
 Posted: 14:13 - 01 Sep 2004 Post subject: |
Interesting experiment to try is to find a big open space. Maybe an empty carpark. Come to a stop, then pull away while turning the bars slightly to the right for example. You'll continue to to turn right untill you reach a certain speed, then the bike will start to turn the other way all of a sudden. I usually have a play with it when turning out of a junction. You'll see it happen right before you. ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing  |
| Back to top |
| fuzz |
 fuzz World Chat Champion
 Posted: 14:17 - 01 Sep 2004 Post subject: |
When you're riding in a straight line, gently push the handle bars left or right momentarily. You will feel the bike want to lean in the opposite direction. You must be going quicker than about 15mph for this to work, otherwise you stay straight up and turn in a circle like a push bike!  ____________________ https://www.bikepics.com/members/fuzzbcf/
Bikes: '99 NSR125R, '00 SV650S, K1 GSX-R600, '97 CB500, K3 SV1000S, '16 VFR800 |
| Back to top |
| The Tot |
 The Tot World Chat Champion
 Posted: 15:33 - 01 Sep 2004 Post subject: |
Countersteering comes instinctively when you pull a fast sweeping bend... You don't know that you're doing it but you are... there's a nice sweeping left hander which drops in elevation at the end of my road and that's when i notice countersteering in action as I AM NOT turning the handlebars to the left... but oddly to the right, bike is leant to the left. Don't try to MAKE yourself do it as FAZED said since it could be nasty. Nearly had a spill on my ped doing it. BTW, correct me if i'm wrong but a good example of counter steer might be found in speedway racing  ____________________ The Tot 2019 Z1000SX - 2007 R1
Never argue with autism |
| Back to top |
| Claud 14.7 to 1 |
 Claud 14.7 to 1 World Chat Champion
 Posted: 16:10 - 01 Sep 2004 Post subject: |
I practice it. Not in a few weeks though. I will again. . .
Works well for dodging cars in emergencies, becuase you can dodge quickely out of the way. Make sure you are practicing in the dry though.
Good for tipping the bike hard into turns.
Good for fast change of direction at high speeds.
Good for smooth cornering
You will doing it naturally, but if you gently try it, and practice you will realise how it imporves your cornering.
You can also use it to adjust your line on roundabouts for example. As it can dip the bike in further quicky.
If you practice it, it becomes in-built into your brain and when you do need it you can utilise it, it is second nature.
E.g. When that car pulled out on me i had to use it for the first time, i didnt even think about it, it just happened and i avoided the car.
| Back to top |
| Mr C |
 Mr C World Chat Champion
 Posted: 16:19 - 01 Sep 2004 Post subject: |
| Back to top |
| bennyb24 |
 bennyb24 Renault 5 Driver
 Posted: 17:42 - 01 Sep 2004 Post subject: |
ride along at about 50 in a dead straight line, gently push one of your handles forwards ! be amazed at strange results !
Don't try and always think about counter steering, I tried riding like that and spent a couple of weeks going very slowly and generally riding like a plonker
have a look at this picture..... if you look closely you can see how far "the wrong way" the front wheel is pointing !
https://www.picman.co.uk/data/20040811FocBra/EVE%20GRP%202%20INTER/BENSON%20B/DSC_1511.jpg |
| Back to top |
| california_rookie |
 california_rookie World Chat Champion
| Back to top |
| mrchips |
 mrchips World Chat Champion
| Back to top |
| Bod |
 Bod Traffic Copper
| Back to top |
| izzi81 |
 izzi81 Could Be A Chat Bot
 Posted: 22:55 - 01 Sep 2004 Post subject: |
The only way to know what it is is to try it. I couldn't get my head round it either until I tried it out - and found it had much more of an effect than I expected! So if you're going to experiment just don't use too much force, it doesn't make much at all to move the bike  ____________________ "The problem with the French is they have no word for 'entrepreneur' " George W Bush
Age doesn't matter unless you're a cheese
https://www.bikepics.com/members/izzi81 |
| Back to top |
| Bod |
 Bod Traffic Copper
 Posted: 09:14 - 02 Sep 2004 Post subject: |
Ok will give it a go later today.  |
| Back to top |
| RUF_Rider |
 RUF_Rider Two Stroke Sniffer
 Posted: 10:58 - 02 Sep 2004 Post subject: |
i use it on the minimoto  |
| Back to top |
| Visitor Q |
 Visitor Q $25 whore
 Posted: 11:06 - 02 Sep 2004 Post subject: |
I almost exclusively used it. It is a very agressive way to ride but helps you get the utmost handling from your bike. Claud that is normal, if theres space you dodge cars, if there isnt you try and headbutt the front of a car, but you still always tend to try. I cant understand people who T-bone cars completely striaght on, surely some avoiding action must of occurred.
Anyhew it is very useful, helps you corner faster, dodge faster, and generally ride more agressively. For a Right handed, push the right hand side away from you gently, harder you push the faster you corner. So no throwing the bar away from you please, or youll be getting intimate with firstly a hedge and then the AA. ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
From September 2014 to January/February 2015 I will not be using any English, nor reading any. As such, I won't be on here. PM at will, but I won't be checking/posting unless in emergencies. Certainly not for the first couple of months. Please berate me savagely if I break that rule... |
| Back to top |
| Ninja |
 Ninja Caption Abuser
| Back to top |
| Mr C |
 Posted: 15:50 - 02 Sep 2004 Post subject: |
you simply can't ride any bike without counter steering at any speed above trotting pace
try it
at 40mph on a straight road take your hands off the bars and try to steer the bike
it takes massive weight shifts to make it lean and it is VERY slow to react
and it gets tougher the faster you go
the only way to lean (steer) a bike is to counter steer, you just don't know you are doing it, and yes it works on push bikes if you can go fast enough  ____________________ 187.3bhp = 201mph |
| Back to top |
| Claud 14.7 to 1 |
 Posted: 16:03 - 02 Sep 2004 Post subject: |
Note: It does not have to be an aggressive style at all. It does help to smoothen out cornering when applied with moderation. I know Ricardo will have to use it, if he rides fast.
You do do it anyway, but if you try it you will be emphasising the normal actions used to move the bike.
Try and you will see. Its hard to explain exactly how you can use it . See for yourself. As soon as you move the bars gently the bike will move. You only need slight movements.
I practiced in a straight with no cars around. After i progressed to using it to tip the bike around bends.
You can always use it to stand the bike up again, when its lent over. All this will fall into place, when you try it. |
| Back to top |
| stinkwheel |
 Posted: 16:35 - 02 Sep 2004 Post subject: |
A picture tells a thousand words.
This is a right hander!
You should be able to work out which bar end to push from that. (don't try to do what he is doing unless you have a foot of suspension on both ends and balls of steel, I used that as an extreme example to demonstrate the technique.) ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
| Mr C |
| Back to top |
| Andy99 |
 Andy99 Spanner Monkey
| Back to top |
| Bod |
 Bod Traffic Copper
 Posted: 08:03 - 03 Sep 2004 Post subject: |
I am still confused to be honest about it. When I am in a straight line and lets say I want to go right, so I push the left bar and it goes left? Am I not pushing it far enough?  |
| Back to top |
The last post was made 21 years, 164 days ago. Instead of replying here, would creating a new thread be more useful? |
