| seeyalater |
 seeyalater Trackday Trickster
| stinkwheel |
 Posted: 17:26 - 10 Dec 2019 Post subject: |
Yes, get a new washer. They are usually either copper or aluminium. Copper ones can be re-annealed but they are cheap to replace.
I'm not going to be drawn into the usual epic oil debate. Consult the users manual, don't use anything of a lower grade than they recommend.
I personally fit a dowty bonded seal washer on sump plugs these days. Those can be re-used. Usually M12.
Be very careful not to overtighten the sump bolt, it is easy to strip them on motorcycles. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Baffler186 |
 Baffler186 World Chat Champion
| seeyalater |
| jaffa90 |
 jaffa90 World Chat Champion
| seeyalater |
| NJD |
 NJD World Chat Champion
 Posted: 17:46 - 10 Dec 2019 Post subject: |
The oil drain bolt (or sump bolt as you name it) can be re-used, and unless the head is damaged or corroded there's no need to replace it. You'll find the threads within well lubricated by the oil so should come undone with ease. You can, of course, order a replacement from places like Wemoto (online parts store) if you'd rather know what state your bike is in after buying it (I did when I recently got my CBF, and its always handy to have spares of various parts).
In terms of copper washers you can get assorted kits from Halfords for like £7-9. I've used it across a couple of bikes for banjo bolt's and sump plugs. Also, though, if you order a new bolt from Wemoto then it shouldn't be hard to find the washers on their too (probably about 0.50-0.99 per one as a guess).
In terms of oil I'd go 10w40 semi synthetic, but refer to your user handbook or workshop manual for guidance. As to what brand it depends how much you want to spend, and how often you want to change it. I used to buy 4L + 1L free for something like £26-30 for the ZR7 when I had it from Motul (5000 I think that was). On the CBF I've gone for Halfords (because money was tight at the time with the amount of work I was doing to it) and will probably change that when the weather improves.
As above make sure you research torque values for the bolt as stripping it can lead to a world of hurt, and even more so if the bike doesn't have a removable sump pan (as in the bottom of the engine is one complete part). Some people get confused about the direction to tighten and enlighten since the bolts are often upside down but set your ratchet the correct way (practice on another bolt) before tightening / loosening it and you can't go wrong.
When it comes to tightening the bolt thread it in by hand until it seats and then either torque up with wrench or nip it with a spanner or 1/4 ratchet (use a 3/8 and no idea of feeling and it will soon go).
Its advisable to run the bike on the stand after an oil change in neutral to check for leaks, turn it off and then let it settle to see how much you need to top it up by (drain, fill, start the bike and run for a minute or two, let it settle and refill). Then after that go for a ride and stop part way to see if there's any leakage.
Make sure you've got rags spare for the oil that will, probably, leak on the downpipes.
Also if you're doing it outside at this time of year think about asking a local shop to do it as it shouldn't cost more than half of an hour to an hour (depending how stingy their feeling). ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
| seeyalater |
 Posted: 18:31 - 10 Dec 2019 Post subject: |
| NJD wrote: | The oil drain bolt (or sump bolt as you name it) can be re-used, and unless the head is damaged or corroded there's no need to replace it. You'll find the threads within well lubricated by the oil so should come undone with ease. You can, of course, order a replacement from places like Wemoto (online parts store) if you'd rather know what state your bike is in after buying it (I did when I recently got my CBF, and its always handy to have spares of various parts).
Also if you're doing it outside at this time of year think about asking a local shop to do it as it shouldn't cost more than half of an hour to an hour (depending how stingy their feeling). |
Nice one thanks, the online place will be handy for bits. |
| Pete. |
 Pete. Super Spammer
 Posted: 18:35 - 10 Dec 2019 Post subject: |
Yes fit a new washer if you can. The washer deforms to make the seal oil-tight.
There's many an oil change done without changing it but then there's many a stripped plug thread too caused by pulling the sump plug up to stop it dripping.
Be warned, sump plug threads strip easily. Don't over-tighten it. ____________________ a.k.a 'Geri'
| NJD |
| Easy-X |
 Easy-X Super Spammer
| Riejufixing |
 Riejufixing World Chat Champion
| seeyalater |
| Confusion |
 Confusion Scooby Slapper
| seeyalater |
| RhynoCZ |
 RhynoCZ Super Spammer
| linuxyeti |
 linuxyeti World Chat Champion
| Easy-X |
 Posted: 17:40 - 19 Dec 2019 Post subject: |
| linuxyeti wrote: | If I'm likely to own a bike lng enough to be carrying out multiple oil changes, then, where one's available, I get a Stahlbus oil drain valve |
Oh yeah, those are kewl Definitely worth it on oil boilers and Chinese bikes. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| linuxyeti |
 Posted: 08:56 - 20 Dec 2019 Post subject: |
| Easy-X wrote: | | linuxyeti wrote: | If I'm likely to own a bike lng enough to be carrying out multiple oil changes, then, where one's available, I get a Stahlbus oil drain valve |
Oh yeah, those are kewl Definitely worth it on oil boilers and Chinese bikes. |
Put the first one I had on my VTX1300, after that, pretty much any bike I could get 1 for. Makes oil changes so much easier, hook the hose up to a pump, and drain the oil straight into an old oil container, no mess, nice & quick.
There's still the odd bike you can't do this with, and, the odd bike, where you can just use the pump to suck the oil out of the sump using the pump by feeding a hose down through the oil filler cap. ____________________ Beware what photos you upload, or link to on here, especially if you have family members on them |
| jaffa90 |
 Posted: 01:26 - 21 Dec 2019 Post subject: |
I don`t even replace the spark plug crush washer after cleaning it, do you???????????????? |
| RhynoCZ |
| chris-red |
 Posted: 13:11 - 23 Dec 2019 Post subject: |
I never/rarely bothered, however after 12 years I finally have my first drain plug leak. so I certainly will in the future  ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
The last post was made 6 years, 300 days ago. Instead of replying here, would creating a new thread be more useful? |
